| Ella - The 1985 Mexican Bandit | |
+24Shorty ANDYLHAM griff vietnam Road Rage clockwork Shamrockez vwbeetlebum MrsWizBiz Cleverchap HRD Bmtt4 SimonABT uselescrapytwit thecrewkid dubberatlast joker 67 ProjectParsons tango_van big dave nomates Gungemyster Mr Scoops WizBizMartin 28 posters |
| Subject: Re: Ella - The 1985 Mexican Bandit Thu Jul 21, 2011 9:18 pm | |
| I asked about the wheels and I wondered if the offsets were different. | |
| Subject: Re: Ella - The 1985 Mexican Bandit Thu Jul 21, 2011 10:18 pm | |
| Fair point Vietnam I'm not building my car to impress people,or to please them , if people think it's shit or amazing doesn't really do much or anything like that , building it for me how I want it :p Going for Similar stretch on the front toooo , I'm not stretching them on to bodge the front end together ether , the front will be sorted Properly with what ever is wrong and not bodged just by putting a stretch tyre on it , not my style ;p and wheels spacers all round to widen the track a bit and get the euro theme on it , | |
| Subject: Re: Ella - The 1985 Mexican Bandit Thu Jul 21, 2011 10:20 pm | |
| The car is is being built properly and will be safe otherwise it going on the road , no corners cut . | |
| Subject: Re: Ella - The 1985 Mexican Bandit Thu Jul 21, 2011 10:22 pm | |
| Might try the chalk idea , I'll pintch some from work tommoz :p | |
| Subject: Re: Ella - The 1985 Mexican Bandit Thu Jul 21, 2011 10:24 pm | |
| Looks good. can't wait to see this all fitted! | |
| Subject: Re: Ella - The 1985 Mexican Bandit Thu Jul 21, 2011 10:30 pm | |
| Few weeks more measuring to do and vietnams chalk idea , | |
| Subject: Re: Ella - The 1985 Mexican Bandit Fri Jul 22, 2011 2:34 am | |
| Have you measured the beam?? | |
MrsWizBiz Blitzen Regular
Number of posts : 191 Age : 32 Location : Weston super mare My Ride(s) : Bella bug - newbie beetle Registration date : 2011-01-18
| Subject: Re: Ella - The 1985 Mexican Bandit Sun Aug 14, 2011 7:03 pm | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sun Aug 14, 2011 7:15 pm | |
| Did you sort the offset problem out? | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sun Aug 14, 2011 9:03 pm | |
| Subject: Re: Ella - The 1985 Mexican Bandit Mon Aug 15, 2011 8:36 am | |
| Looking good bud. Will pop round later on today and have a look. Hurry up and get this finished summers nearly over!!!! | |
| Subject: Re: Ella - The 1985 Mexican Bandit Mon Aug 15, 2011 3:18 pm | |
| what was the prob with the front end? | |
| Subject: Re: Ella - The 1985 Mexican Bandit Mon Aug 15, 2011 5:43 pm | |
| Camber settings different on each wheel..I think that was the cause in the end... | |
| Subject: Re: Ella - The 1985 Mexican Bandit Mon Aug 15, 2011 10:04 pm | |
| Had some bad camber nuts I think, | |
| Subject: Re: Ella - The 1985 Mexican Bandit Tue Aug 16, 2011 9:35 am | |
| bad set i got from BBT when they were around | |
Number of posts : 1343 Age : 42 Location : Clevedon My Ride(s) : Something with a V6 under the hood! Registration date : 2006-10-08
| Subject: Re: Ella - The 1985 Mexican Bandit Tue Aug 16, 2011 2:33 pm | |
| Subject: Re: Ella - The 1985 Mexican Bandit Wed Aug 17, 2011 6:55 am | |
| Subject: Re: Ella - The 1985 Mexican Bandit Wed Aug 17, 2011 7:07 am | |
| Subject: Re: Ella - The 1985 Mexican Bandit Wed Aug 17, 2011 7:16 am | |
| Will try and pop round to give u a hand sorting out that ride height! U hit loads of reminder those rear arches! Looking sweet. | |
| Subject: Re: Ella - The 1985 Mexican Bandit Wed Aug 17, 2011 7:44 am | |
| back needs to come down a bit and front up | |
| Subject: Re: Ella - The 1985 Mexican Bandit Wed Aug 17, 2011 10:42 pm | |
| Update? Nearly there mate. Sorry I couldn't stay to help out earlier. hope the brake bleeding went well. | |
| Subject: Re: Ella - The 1985 Mexican Bandit Thu Aug 18, 2011 7:51 am | |
| brake bleading went wrong , the bias valve i ahve fitted leaks ! , connected up the pressure bleed kit and it started to leak :C, bit of set back , thinks in the unions that are on there , once that sorted the brakes will be bled lol
| Subject: Re: Ella - The 1985 Mexican Bandit Thu Aug 18, 2011 11:09 am | |
| think the problem was i mis read the instructions or lack of reading and was men t to double flare the brake line s going in and out of the bias valve :p attempt 2 tonight , hopefully can bleed brakes then leave under pressure for 30 mins to check for any leaks then lock it all of , | |
| Subject: Re: Ella - The 1985 Mexican Bandit Thu Aug 18, 2011 7:25 pm | |
| how did you get on?
have you double flared it the right way round? | |
| Subject: Re: Ella - The 1985 Mexican Bandit Fri Aug 19, 2011 9:22 am | |
| yep double flared and now the adapter for the bias valve has cross threaded ! damm
| Subject: Re: Ella - The 1985 Mexican Bandit | |
