 Tango Van - 1972 westy..
Azrael
23 posters
Go to page : Previous  1 ... 6 ... 8, 9, 10 ... 13 ... 17  Next
Tango Van - 1972 westy.. - Page 9 Empty
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySat Mar 03, 2012 11:21 pm
As to the brake servo takeoff, I just copied the original set up from when I had solexs and then the icts on there. It has a balance pipe between the carbs which then goes into one servo line to the front. I just wondered if I should trim the plastic elbows down I case they are affecting the flow inside the manifold?
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySun Mar 04, 2012 9:05 am
so the leaking carbs are just gasket problems then?
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySun Mar 04, 2012 9:11 am
I think so / hope so!!! I cant see where else it has come from.. I will blank off the chokes also this week and put new manifold to head gaskets in as the tinware has to come off.
I'm open to any other suggestions with where the fuel my be coming from... But looking at the soaked gaskets I guess it's them...
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySun Mar 04, 2012 9:23 am
Rich, it def looked to be gaskets yesterday Dude, they were soaked.
I'd say try them and see what happens.
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySun Mar 04, 2012 12:45 pm
I think big al said the larger webbers have problems with gaskets ......I think he made some himself ,and solved the problem
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySun Mar 04, 2012 1:05 pm
May order up some gasket sheets then. Does it have to be a certain type of material and thickness?
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySun Mar 04, 2012 1:10 pm
best off asking big al .....I've got some gasket material here if you need a bit
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySun Mar 04, 2012 1:19 pm
Just had a look. The gaskets on their are not an exact fit to the manifold: overlap the inner edge and aren't flush to the outer edge. So maybe making a set to match exactly the carbs/manifolds would be better.....and may stop the fuel leaking
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySun Mar 04, 2012 8:50 pm
Had a couple of hours on the bus today... mainly cleaning the gasket residue off the base of the carbs and then taking fan shroud out. big thanks to Wizbiz for helping to split the shroud apart... ready for a degrease this week and re-spray next weekend...
Fan taken out:
Tango Van - 1972 westy.. - Page 9 D2355de9
Alternator out:
Tango Van - 1972 westy.. - Page 9 F3ffec9e
Alternator cover plate to be resprayed:
Tango Van - 1972 westy.. - Page 9 E0aa47a2
The fan and dismantled parts so far:
Tango Van - 1972 westy.. - Page 9 1e841ed7
Naked block with fan shroud removed... got lots of room in there now!! Red paint is flaking of the block though.. annoying as no time to repaint that before VolksWorld show, so may just degrease and remove paint then spray block with some clear engine lacquer...
Tango Van - 1972 westy.. - Page 9 189f3a1b
Tango Van - 1972 westy.. - Page 9 E9210532
Disassembled bits on the drive:
Tango Van - 1972 westy.. - Page 9 5d2ed2cc
no pic of split fan shroud, will update tomoz..
inside was covered in oil/grime etc... which then gets deposited all over the heads... nice.
now only got to take off manifolds and top tin to repaint.
Then just do the reverse and re-assemble it all!! All just a result of a slight fuel leak on the carbs!!
and decide on fan shroud colour! (ring any bells Steph .... )
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySat Mar 10, 2012 12:49 pm
Today is the day!!
Sun is out. All Parts arrived from machine 7 (next day delivery and even they sent out a missing CSP choke blanking plate which arrived today!)
Tango Van - 1972 westy.. - Page 9 Dd50d5fb
Degreaser and towel at the ready (cheers Scoops) and rattle paints all lined up.
Just got to strip the remaining tin wear off, remove manifolds, degrease, rub back and prep for paint, spray and then refit it all back up. Job done then!
Tango Van - 1972 westy.. - Page 9 Bca6cd1c
More Pics to follow later!
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySat Mar 10, 2012 6:48 pm
Naked engine!
Tango Van - 1972 westy.. - Page 9 0d0d6442
Tinwear all removed ready for cleaning!
Tango Van - 1972 westy.. - Page 9 4f302008
Tango Van - 1972 westy.. - Page 9 8ddfc093
Fan shroud all cleaned up inside and out
Tango Van - 1972 westy.. - Page 9 0e606c37
Tango Van - 1972 westy.. - Page 9 Cc0b31b1
Done the rest of the tin and cleaned up the alternator.
Will pop back out later to apply some primer etc. just need to wait for the dust to settle in the garage and find a lamp and heater!
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySat Mar 10, 2012 7:08 pm
that tin you are missing on the RH head is the bit i found left over when i put mine back together. its quite an important bit as it channels the air from the fan around the head.
i will keep an eye out for some if you want?
the spare bits i have are the gearbox end that the heater risers fit on to
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySat Mar 10, 2012 7:30 pm
Yes, please do look out for that one!
I've got the front tin just missing that and the flaps...
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySat Mar 10, 2012 9:18 pm
1st primer coat done on all tinwear. Just gonna have a cuppa then lay down the next coat and hope to get some top coat on later!
Ideally then let it dry over night and pop it all back on tomorrow Smile fun times!!
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySat Mar 10, 2012 9:23 pm
now there is dedication right there! good work tango Wink
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySat Mar 10, 2012 11:46 pm
All done Smile
Just got to let the top coat dry over night and a little flat back and then the lacquer on in the morning.
Then while that drys I'm off to the swimming pool and hopefully it's dry enough to start fitting back together nice and gentle like....
Some pics in a mo..
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySun Mar 11, 2012 12:10 am
Hanging up on the line
Tango Van - 1972 westy.. - Page 9 5c1215ad
Tango Van - 1972 westy.. - Page 9 1a256b6a
Tango Van - 1972 westy.. - Page 9 E734d8c2
A few costs of primer on....
Tango Van - 1972 westy.. - Page 9 Ad003ad7
Tango Van - 1972 westy.. - Page 9 2864c739
Final top coat...
Tango Van - 1972 westy.. - Page 9 4ad81a60
Tango Van - 1972 westy.. - Page 9 631e399d
Tango Van - 1972 westy.. - Page 9 049dda32
Sorry about the image quality ...
Tango Van - 1972 westy.. - Page 9 Fc9d2c56
Also did backing plate on alternator and dipstick with some smooth hammerite. Nearly there. Just the lacquer in the morning and fitting it all together..
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySun Mar 11, 2012 8:15 am
Good work! One step closer to sandown Wink
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySun Mar 11, 2012 10:21 pm
Been busy this afternoon!
All tin prepped and lacquered (4 coats)
Installed main cylinder tin first after removing at much as possible of the flaking engine paint, and then lacquered with oil and heat resistant Gunk Engine Lacquer.
Re-cleaned carbs and manifolds and installed new gaskets. Removed choke system and replaced with new CSP choke blanking plates.
installed manifolds and carbs:
Tango Van - 1972 westy.. - Page 9 223c4cdc
Tango Van - 1972 westy.. - Page 9 71a02673
then built up fan shroud (as had split in half to paint) cleaning all rubber boots for the dipstick and alternator. The installed onto engine block.
Tango Van - 1972 westy.. - Page 9 98c1b80c
Tango Van - 1972 westy.. - Page 9 Dd411063
Tango Van - 1972 westy.. - Page 9 5302d279
Tango Van - 1972 westy.. - Page 9 D55a9510
Tango Van - 1972 westy.. - Page 9 20a5f6a8
reinstalled alternator (which was degreased and polished tongue ), new fanbelt and ancillaries.
Tango Van - 1972 westy.. - Page 9 04626abd
Tango Van - 1972 westy.. - Page 9 4e5e8272
Tango Van - 1972 westy.. - Page 9 Ccbb3b64
Tango Van - 1972 westy.. - Page 9 06129c65
Tango Van - 1972 westy.. - Page 9 2da6f6ef
started at 12:30pm and all back in and running at 7pm!
Not bad, bearing in mind having to wait for the lacquer to cure.
Also, cleaned and painted: alternator pulley, dipstick and wiper arms, and cleaned the garage!...
Started 1st time and
Just got the front tin to install, change the fuel filter, fix the reverse like switch in the week then time to road test.
Also, wipe down the fresh tin wear in a week or so.
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySun Mar 11, 2012 10:23 pm
Good work Dude!
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySun Mar 11, 2012 10:32 pm
nice much ....much better
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptySun Mar 11, 2012 10:46 pm
Just got to tidy up the wiring, so will pop to Maplins to get some heatshrink.
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptyMon Mar 12, 2012 10:26 am
I've got a meter of heatshrink I've not used. Think it's 3.5mm dia of you want it.
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 9 EmptyMon Mar 12, 2012 3:28 pm
good work rich
PostSubject: Failed MOT...   Tango Van - 1972 westy.. - Page 9 EmptyWed May 02, 2012 7:40 pm
So it needs....
new dust covers x4 for the track rod ends (which I knew about)
Tango Van - 1972 westy.. - Page 9 B20949d5
but..
also: new front shocks!.. the price of going low and hard!
Wouldn't be so bad if they were cheap ones.. but GAZ gas adjustable coilovers...so approx £240 pair.. and then springs on top £80...
Seals have gone on both, so leaking damper oil..
Tango Van - 1972 westy.. - Page 9 783ddb4e
Tango Van - 1972 westy.. - Page 9 1f36a03d
Tango Van - 1972 westy.. - Page 9 34665986
Tango Van - 1972 westy.. - Page 9 2ff572e7
Took them off tonight to measure up for replacement, or get them re-built up..
Tango Van - 1972 westy.. - Page 9 79240243
not a lot of room left on the lip of the arch without them on.. so if standard oil shocks on...
Tango Van - 1972 westy.. - Page 9 15baf253
Tango Van - 1972 westy.. - Page 9 A4f41ca4
but lots of room inside....
Tango Van - 1972 westy.. - Page 9 8e106b10
Page 9 of 17Go to page : Previous  1 ... 6 ... 8, 9, 10 ... 13 ... 17  Next
