 Rons Resto
Splitfirebus
16 posters
Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
Splitfirebus
Splitfirebus
Male Number of posts : 1108
My Ride(s) : 64 Deluxe Sedan
Registration date : 2007-07-16
Rons Resto - Page 6 Empty
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyMon Oct 05, 2009 6:25 pm
Really happy that the drive shafts, fulcrum plates and side gears all have very little wear at all.
Rons Resto - Page 6 Beetle012
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyMon Oct 05, 2009 7:32 pm
looking spot on paul.
nice when you have a good base to start with.
keeps the updates coming.
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyMon Oct 05, 2009 7:50 pm
looks good bud Wink
Splitfirebus
Splitfirebus
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 5:23 pm
Finish welding both pans in...
Rons Resto - Page 6 Beetle022
Rons Resto - Page 6 Beetle025
Then had to remove all the little brackets from the old pans and weld them on the new.
Throttle pedal...
Rons Resto - Page 6 Beetle027
Battery strap clamp / trim rest...
Rons Resto - Page 6 Beetle017
N/S trim rest...
Rons Resto - Page 6 Beetle026
Then fabricate the battery strap hold down thread and pan reinforcement piece...
Rons Resto - Page 6 Beetle023
Then weld that in...
Rons Resto - Page 6 Beetle020
Splitfirebus
Splitfirebus
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 5:29 pm
Then I had to weld up two holes that were drilled into the tunnel for seat belt mounts...
Rons Resto - Page 6 Beetle018
Rons Resto - Page 6 Beetle019
Rons Resto - Page 6 Beetle024
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 5:34 pm
nice work lover Wink
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 5:41 pm
yep, top show .....what tool do you use to finish the welds ,so they look like they've never been welded paul?
Splitfirebus
Splitfirebus
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 6:08 pm
I use two standard 4 1/2" 115mm grinders. The first fitted with a standard grinding disc to take the weld down to just above the surface and the second grinder fitted with a soft backing bad and either 24 or 36 grit disc's.
Like this...
http://cgi.ebay.co.uk/Backing-Pad-115mm-Angle-Grinder_W0QQitemZ310157970721QQcmdZViewItemQQptZUK_Home_Garden_PowerTools_SM?hash=item4836db0d21&_trksid=p3286.c0.m14
Unless its in a really hard to get to area thaen I use a air belt sander with 40 grit belts.
Like this...
http://cgi.ebay.co.uk/NEW-Sealey-professional-air-belt-sander-SA35_W0QQitemZ120476938051QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item1c0cfc2f43&_trksid=p3286.c0.m14
Splitfirebus
Splitfirebus
Thank you flower geek
Splitfirebus
Splitfirebus
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 6:13 pm
A few more hours and it'll be ready to goto the blasters.
AT LAST
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 6:17 pm
how are you going to blank all the holes , so grit don't get into the tunnel ,or the splines of the rear axle
Splitfirebus
Splitfirebus
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 6:54 pm
I'm going to cut out several different shape plates from mild steel plate and bond them on / over holes with silicone.
Then when it comes back just pull them off and clen up around the areas.
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 7:32 pm
good idea ....I tack welded mine
Splitfirebus
Splitfirebus
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 7:54 pm
Snob lol!
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 8:01 pm
Rons Resto - Page 6 Lol ........I think silicone is a better idea
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 8:18 pm
There are some truly awesome projects going on in this club at the moment.....
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 8:29 pm
thanks Rons Resto - Page 6 Icon_lol
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 8:32 pm
Yours was included in that dude....
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 8:35 pm
Rons Resto - Page 6 Icon_eek
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 8:42 pm
steve this is what i use, take top off with 40 grit then finish with and 80 grit.
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyWed Oct 07, 2009 9:15 pm
cheers ...top tips
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyThu Oct 08, 2009 6:38 am
Looking sweet me lover.. Top work.. afro afro afro
Splitfirebus
Splitfirebus
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyThu Oct 08, 2009 5:31 pm
Thank you flower bounce
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptyThu Oct 08, 2009 6:35 pm
Bloody hell Paul!!
you good!!
Splitfirebus
Splitfirebus
PostSubject: Re: Rons Resto   Rons Resto - Page 6 EmptySat Nov 07, 2009 6:04 pm
Had another couple of hours free today so dragged out the gearbox that I had steam cleaned the other week.
Made sure that all was sealed up and gave it a light sand blasting...
Rons Resto - Page 6 Beetle038
Rons Resto - Page 6 Beetle039
Then another good clean up and a coat of etch primer...
Rons Resto - Page 6 Beetle032
Rons Resto - Page 6 Beetle036
Then a coat of met silver base coat...
Rons Resto - Page 6 Beetle029
Rons Resto - Page 6 Beetle030
Rons Resto
Page 6 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
» '69 Rag top resto
» Bay Resto
» EMO Resto
» Cal Look to Resto Cal
» T4 resto thread
