| Rons Resto | |
+12ProjectParsons ARCANE Dirty Dave spennyp ANDYLHAM itsabuglife Wurz nomates Mr Scoops dubberatlast thecrewkid Splitfirebus 16 posters |
Splitfirebus DBS Old Timer
Number of posts : 1108 Age : 51 Location : Bristol My Ride(s) : 64 Deluxe Sedan Registration date : 2007-07-16
| Subject: Re: Rons Resto Thu Aug 20, 2009 7:33 pm | |
| Tricked ya..Still done nothin.. | |
| Subject: Re: Rons Resto Thu Aug 20, 2009 8:19 pm | |
| Where's your pics gone Paul?? | |
| Subject: Re: Rons Resto Sun Sep 20, 2009 3:47 pm | |
- Where's your pics gone Paul??
Pic's sorted | |
| Subject: Re: Rons Resto Sun Sep 20, 2009 4:11 pm | |
| After losing my way with Ron for a while I am back on it now Thought I would get on with the Pan... Cut out the worst part of the rust that was around the o/s jacking point... Found the rear member to be a little far to gone so chopped that out and fabbed up a new piece... Hey presto... Repair panel clamped in... Then welded and ground down... And spot welded at the rear... It's a shame the I had to go bigger than the repair panel but I obviously wanted to get back to sound metal. | |
| Subject: Re: Rons Resto Sun Sep 20, 2009 4:18 pm | |
| Fabbed up the patch and welded that in... | |
| Subject: Re: Rons Resto Sun Sep 20, 2009 4:39 pm | |
| After spending 8 Hrs working on the pan yesterday, I had a look at it this morning and I really am not happy with how the small repair panel has gone in, so I am thinking of replacing both pans with the Wolfsburg West Grey pans. At £500 a pair there not cheap but from what I have read the are the very best you can buy. The pressing and fit are perfect and they are made from 18 gauge steel. | |
ProjectParsons DBS Old Timer
Number of posts : 1431 Age : 42 Location : Burnham on Sea My Ride(s) : MK2 Jetta Turbo Diesel Registration date : 2007-03-22
| Subject: Re: Rons Resto Sun Sep 20, 2009 4:48 pm | |
| Repaired bits look pretty bloody neat from here... What didnt go to plan?
If I had to replace pans again, those would be what I'd like to use. I wanted them at the time but couldn't justify the cost, but the ones I used from coolair/mexico were so thin/mis-shapen I'd never use them again. | |
| Subject: Re: Rons Resto Sun Sep 20, 2009 8:49 pm | |
| Woo-Hoo. Ron's back!! | |
| Subject: Re: Rons Resto Mon Sep 21, 2009 6:57 pm | |
| Had a few hours free this afternoon so cut out both the old pans. | |
| Subject: Re: Rons Resto Mon Sep 21, 2009 7:02 pm | |
| Everything that is left now is 100% solid metal. The gearbox had a slight leak on the nose cone so over the years a little gearbox oil had dripped into the tunnel and as such the inside of the backbone is like brand new. So, off to order the new pans now | |
| Subject: Re: Rons Resto Mon Sep 21, 2009 7:07 pm | |
| I hate to say it but this could be going a little futher than I had anticipated. But hey ho, I've been and done it now | |
| Subject: Re: Rons Resto Mon Sep 21, 2009 7:30 pm | |
| in for a penny dude ........you know its gonna rock when you finish it .... if petrol still exists | |
| Subject: Re: Rons Resto Mon Sep 21, 2009 8:17 pm | |
| Subject: Re: Rons Resto Mon Sep 21, 2009 10:25 pm | |
| Subject: Re: Rons Resto Tue Sep 22, 2009 7:00 pm | |
| Ordered the floor pans today Should be here on Thursday | |
| Subject: Re: Rons Resto Tue Sep 22, 2009 10:18 pm | |
| cool glad your back on it bud, will look sweat | |
HRD DBS Old Timer
Number of posts : 1507 Age : 45 Location : Bridgwater!!!!!! My Ride(s) : Too many to list! Registration date : 2009-05-04
| Subject: Re: Rons Resto Wed Sep 23, 2009 8:25 am | |
| looking good mate, cant wate to see this finished, theres a lot of work going into this | |
| Subject: Re: Rons Resto Tue Sep 29, 2009 7:34 pm | |
| New floor pans turned up today at last... The quality of these pans is very good indeed, the pressings are almost perfect and they are a very heavy gauge metal. Spent an hour or two checking fitment and stamping out the 114 plug weld holes at 40mm intervals (Yes I know I'm sad) | |
| Subject: Re: Rons Resto Mon Oct 05, 2009 6:06 pm | |
| Managed to find a few hours over the weekend so trial fitted both pans... As I said before, the fit is really nice... Notice that the pressings are for a LHD car on the front of the left pan so I'll have to correct that. | |
| Subject: Re: Rons Resto Mon Oct 05, 2009 6:15 pm | |
| As I said before the pressings were wrong on the front of the left pan because the pans are for a LHD car. So, chop it out... Flatten the section... clamp in back in... Weld it up... | |
| Subject: Re: Rons Resto Mon Oct 05, 2009 6:18 pm | |
| Obviously had to slice the other two ribs, flatten and weld those up along with removing the welded on nut and filling that hole. | |
| Subject: Re: Rons Resto Mon Oct 05, 2009 6:22 pm | |
| Also managed to strip the gearbox down ready to be cleaned up and painted. Quite amazed that the box was still wearing it's original unsplit gaiters and oringinal clips... | |
| Subject: Re: Rons Resto | |
| Rons Resto | |
