| "The Joker 67" Bug resto | |
+38Shorty Road Rage tango_van ANDYLHAM SimonABT sonic23 eddie gordo moupster smudgevw dreadie Dylan ProjectParsons big dave WizBizMartin clockwork Big_Al vwroadster Bmtt4 delboy griff HRD Dirty Dave Cleverchap ARCANE Gungemyster slammervan nomates Mr Scoops Shamrockez vwbeetlebum Wurz renegade67 type25 dan dubberatlast Big Blue Betty itsabuglife thecrewkid joker 67 42 posters |
| Subject: Re: "The Joker 67" Bug resto Sat Jul 09, 2011 4:33 pm | |
| yep standard discs and calipers. got them from machine 7, german discs and trw calipers.
ive got to re-paint the calipers though. chipped the paint.
cheers for the nice comments , yours is looking sweet as well. | |
| Subject: Re: "The Joker 67" Bug resto Sat Jul 09, 2011 6:50 pm | |
| why did you opt for cross drilled? | |
Number of posts : 7198 Age : 51 Location : Wouldn't I like to know My Ride(s) : Rollercoaster Registration date : 2009-08-09
| Subject: Re: "The Joker 67" Bug resto Sun Jul 10, 2011 1:03 pm | |
| possibly in prep for a big motor......????? | |
| Subject: Re: "The Joker 67" Bug resto Sun Jul 10, 2011 4:15 pm | |
| cross drilled for the win , had on mine before, certainly noticed a difference with heat dispersion under heavy use. | |
| Subject: Re: "The Joker 67" Bug resto Sun Jul 10, 2011 4:17 pm | |
| brake pads defo wore out quicker though | |
| Subject: Re: "The Joker 67" Bug resto Mon Jul 11, 2011 4:29 pm | |
- why did you opt for cross drilled?
just for the sake of it really, they were drilled out by a motorcycle racer, the two rows drilled are so the x-drilling works correctly, and disperses heat correctly. | |
| Subject: Re: "The Joker 67" Bug resto Mon Jul 11, 2011 4:42 pm | |
| i only wondered as the engine is only 1641 isn't it ?...i remember my mate put some on his rs turbo and they were noisey...it always put me off buying tham ,but his were grooved as well ,so it may be the grooves causing the noise | |
| Subject: Re: "The Joker 67" Bug resto Mon Jul 11, 2011 5:26 pm | |
| Standard 1600 in this bad boy
| Subject: Re: "The Joker 67" Bug resto Mon Jul 11, 2011 10:06 pm | |
- i only wondered as the engine is only 1641 isn't it ?...i remember my mate put some on his rs turbo and they were noisey...it always put me off buying tham ,but his were grooved as well ,so it may be the grooves causing the noise
i had drilled and grooved on my rs turbo, they warped with in 1 month also had ebc red stuff, i was told they need running in hard as designed for heavy breaking, truth or not im not sure. This bug is going to be another of my favs for sure, nice work andy | |
| Subject: Re: "The Joker 67" Bug resto Wed Jul 13, 2011 8:36 pm | |
| I've got drilled and grooved on Robbie. No noises at all. | |
| Subject: Re: "The Joker 67" Bug resto Sat Jul 16, 2011 8:22 am | |
| Subject: Re: "The Joker 67" Bug resto Sat Jul 16, 2011 12:50 pm | |
| You not going to run red rear lenses? | |
| Subject: Re: "The Joker 67" Bug resto Sat Jul 16, 2011 1:13 pm | |
- You not going to run red rear lenses?
i have a set of us spec lenses | |
| Subject: Re: "The Joker 67" Bug resto Sat Jul 16, 2011 1:22 pm | |
| i love it ........NEVER show it to lisa | |
| Subject: Re: "The Joker 67" Bug resto Sat Jul 16, 2011 1:38 pm | |
| really coming together now, have you got a target date for completion? | |
| Subject: Re: "The Joker 67" Bug resto Sun Jul 17, 2011 9:40 am | |
| - baja 69 wrote:
- really coming together now, have you got a target date for completion?
as and when funds allow. andy | |
ARCANE DBS Old Timer
| Subject: Re: "The Joker 67" Bug resto Mon Jul 18, 2011 8:22 am | |
| Looking amazing Andy, really gutted for you about the door, what a total pisser! | |
| Subject: Re: "The Joker 67" Bug resto Mon Jul 18, 2011 8:38 am | |
| - ARCANE wrote:
- Looking amazing Andy, really gutted for you about the door, what a total pisser!
that wont take long to sort out, and will be able to keep it local repair. must have got damp under the primer. andy | |
| Subject: Re: "The Joker 67" Bug resto Tue Jul 19, 2011 7:53 am | |
| With those sticky pads to hold the loom in place in the engine bay andy, I hope you have screwed them to the firewall as well, as soon as you get a little bit of heat near them, the glue will fail, and the loom will be sucked into the fan! I know, I've seen it happen.
Unless you are fitting the proper fire retardant soundproofing over it all anyway!
Great job matey! | |
| Subject: Re: "The Joker 67" Bug resto Tue Jul 19, 2011 9:39 am | |
| Looking great! Can't wait to see the finished article! | |
| Subject: Re: "The Joker 67" Bug resto Tue Jul 19, 2011 1:46 pm | |
| - Big_Al wrote:
- With those sticky pads to hold the loom in place in the engine bay andy, I hope you have screwed them to the firewall as well, as soon as you get a little bit of heat near them, the glue will fail, and the loom will be sucked into the fan! I know, I've seen it happen.
i was thinking that, might try and get some that rivet on. | |
| Subject: Re: "The Joker 67" Bug resto Tue Jul 19, 2011 3:04 pm | |
| There should be a countersunk hole in the back, under where the cable tie goes, you could probably rivet through there. | |
blueridge DBS Old Timer
Number of posts : 1245 Age : 43 Location : highbridge My Ride(s) : 1973 Squareback,1999 golf gti,95 GMC Safari. Registration date : 2007-04-12
| Subject: Re: "The Joker 67" Bug resto Tue Jul 19, 2011 4:45 pm | |
| how about changing the sticky pads and cable ties to insulated p-clips ? http://www.ebay.co.uk/itm/50-UK-Branded-6-3mm-P-Clips-Midget-Kit-Caterham-TR6-MGB-/220816061065?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3369a9b289 | |
| Subject: Re: "The Joker 67" Bug resto Tue Jul 19, 2011 10:40 pm | |
| Got bloody hundreds of them! White or red, take your pick! | |
| Subject: Re: "The Joker 67" Bug resto Wed Jul 20, 2011 3:02 am | |
| Make sure they're heat rated, I could see if I can get you some aerospace ones. | |
| Subject: Re: "The Joker 67" Bug resto | |
