 "The Joker 67" Bug resto
Go to page : Previous  1 ... 12 ... 20, 21, 22
"The Joker 67"  Bug resto  - Page 22 Empty
PostSubject: Re: "The Joker 67" Bug resto    "The Joker 67"  Bug resto  - Page 22 EmptyFri Mar 30, 2012 3:58 pm
Took the car out the unit on tuesday night, to sort a couple of thinks out.
1 ) adjust the new steering box, as now starting to bed in.
2) straighten out the steering wheel.
3) get some castor shims as the steering does not straighten out very well.
4) clean underneath.
5) raise the rear slightly, as axle tubes are hitting the heat exchangers and arms are hitting the rear shock horns.
When it was jacked up i found a rear hub was leaking oil, so now new rear shoes again and hub seal kit. which is a bit of a pisser tbh.
next re-paint the passenger door, and that should be pretty much it.
also got a new tank sender coming as found the rubber seal was split when i filled up to go to volksworld.
PostSubject: Re: "The Joker 67" Bug resto    "The Joker 67"  Bug resto  - Page 22 EmptyFri Mar 30, 2012 4:06 pm
got a hub seal kit here for you if you need it dude ....and some caster shims
PostSubject: Re: "The Joker 67" Bug resto    "The Joker 67"  Bug resto  - Page 22 EmptyFri Mar 30, 2012 4:28 pm
cheers mate, if gungey makes it down can you give him the bits.
thanks again andy
PostSubject: Re: "The Joker 67" Bug resto    "The Joker 67"  Bug resto  - Page 22 EmptyTue Apr 03, 2012 9:12 am
great resto well done
PostSubject: Re: "The Joker 67" Bug resto    "The Joker 67"  Bug resto  - Page 22 EmptyMon Apr 23, 2012 6:20 pm
put some oil shocks on now and raised the back slightly, but the front has settled quite a bit, since takeing the gas shocks off.
door repainted and re-fitted.
PostSubject: Re: "The Joker 67" Bug resto    "The Joker 67"  Bug resto  - Page 22 EmptyMon Apr 23, 2012 9:00 pm
bit of a rake going on then??? Pics...
PostSubject: Re: "The Joker 67" Bug resto    "The Joker 67"  Bug resto  - Page 22 EmptyMon Apr 23, 2012 9:17 pm
not really levalled up the front a bit tonight, front panel less than 3" off the floor.
just got to level the rear side to side, about 14mm higher on l/h/r.
so got to play with the torsion bars.
PostSubject: Re: "The Joker 67" Bug resto    "The Joker 67"  Bug resto  - Page 22 EmptyWed Apr 25, 2012 7:56 am
ill be honest mate, this style of you car normally aint normally my cup of tea I'm more the german look type, but i really want your car !, its looks the dogs danglies, i must have been through your whole resto thread like 3 times last night, the work is incredible. you should be so happy with it, every things right and everything fits/looks right on the car,
can't wait to see it in ultra,
PostSubject: Re: "The Joker 67" Bug resto    "The Joker 67"  Bug resto  - Page 22 EmptyTue May 22, 2012 9:06 pm
Andy don't forget to update this thread with pics of shows and ultra feature itll finish it off nicely dude. Very Happy
PostSubject: Re: "The Joker 67" Bug resto    "The Joker 67"  Bug resto  - Page 22 EmptyTue May 22, 2012 9:36 pm
ill be honest mate, I'm more the german look type,
sausage in one hand ?
PostSubject: Re: "The Joker 67" Bug resto    "The Joker 67"  Bug resto  - Page 22 EmptyWed Sep 12, 2012 11:52 am
thought i might up date a bit.
Been to a few shows over the summer
picked up
top 10 custom aircooled at vw action.
"The Joker 67"  Bug resto  - Page 22 2012-09-03221954
"The Joker 67"  Bug resto  - Page 22 2012-09-03222006
"The Joker 67"  Bug resto  - Page 22 2012-09-03222028
Best car at Big sunday at croyde.
"The Joker 67"  Bug resto  - Page 22 DSC03575
"The Joker 67"  Bug resto  - Page 22 DSC03574
Best pre 67 aircooled custom at Bristol volksfest
also broke down twice,
1st
fuel pump burnt out
2nd
coil came away from fan housing on the m32 in bristol on the way to action.
all sorted at the moment now, i put it down to teething problems.
PostSubject: Re: "The Joker 67" Bug resto    "The Joker 67"  Bug resto  - Page 22 EmptyWed Sep 12, 2012 2:13 pm
^^^^ good skills Andy, all well deserved
whitebrow83
Male Number of posts : 126
Registration date : 2013-05-22
PostSubject: Re: "The Joker 67" Bug resto    "The Joker 67"  Bug resto  - Page 22 EmptyWed Nov 20, 2013 1:46 pm
I bought this car off e/bay, back in end 2006, from a guy he advised that the car was not that bad, and the top looked good from the pictures i had.
My face just dropped when it turned up. My stupid fault for not looking at the car. Will never trust anyone from pictures again.
so poo or bust i decided to carry on the resto.
this one of the pics i recieved before buying
"The Joker 67"  Bug resto  - Page 22 Fe_12
"The Joker 67"  Bug resto  - Page 22 41_11
"The Joker 67"  Bug resto  - Page 22 4c_11
"The Joker 67"  Bug resto  - Page 22 93_11
when staarted to strip down
"The Joker 67"  Bug resto  - Page 22 DSCN3679
"The Joker 67"  Bug resto  - Page 22 DSCN3681
"The Joker 67"  Bug resto  - Page 22 DSCN3683
"The Joker 67"  Bug resto  - Page 22 DSCN3682
"The Joker 67"  Bug resto  - Page 22 DSCN3687
"The Joker 67"  Bug resto  - Page 22 DSCN3684
"The Joker 67"  Bug resto  - Page 22 DSCN3686
"The Joker 67"  Bug resto  - Page 22 DSCN3689
the panels starting to go in, heater channels and floor welded together, inner raer arches 6 plates welded on top of each other.
"The Joker 67"  Bug resto  - Page 22 DSCN3696
"The Joker 67"  Bug resto  - Page 22 IMG_1073
"The Joker 67"  Bug resto  - Page 22 IMG_1078
"The Joker 67"  Bug resto  - Page 22 IMG_1074
"The Joker 67"  Bug resto  - Page 22 IMG_1079
"The Joker 67"  Bug resto  - Page 22 IMG_1082
"The Joker 67"  Bug resto  - Page 22 IMG_1086
"The Joker 67"  Bug resto  - Page 22 IMG_1088
"The Joker 67"  Bug resto  - Page 22 IMG_1128
"The Joker 67"  Bug resto  - Page 22 IMG_1129
"The Joker 67"  Bug resto  - Page 22 IMG_1130
"The Joker 67"  Bug resto  - Page 22 IMG_1134
"The Joker 67"  Bug resto  - Page 22 IMG_1138
"The Joker 67"  Bug resto  - Page 22 IMG_1139
"The Joker 67"  Bug resto  - Page 22 IMG_1140
"The Joker 67"  Bug resto  - Page 22 IMG_1141
"The Joker 67"  Bug resto  - Page 22 IMG_1142
"The Joker 67"  Bug resto  - Page 22 IMG_1143
Where did you get that lower rear firewall thingy panel from mate? The only thing I can find is a complete rear firewall from VWHeritage and Machine 7. Smile
I've learnt so much from this post.
PostSubject: Re: "The Joker 67" Bug resto    "The Joker 67"  Bug resto  - Page 22 EmptyThu Nov 21, 2013 11:22 pm
Do you mean these Rear Crossmember pieces?
http://www.machine7.com/section.php?xSec=1262
@ £44.50 each
If you just want the end closing pieces
http://www.machine7.com/section.php?xSec=1259
@ £7.85 each
Page 22 of 22Go to page : Previous  1 ... 12 ... 20, 21, 22
» Joker Collection
» Happy Birthday Joker
