 Tango Van - 1972 westy..
Go to page : Previous  1 ... 9 ... 14, 15, 16, 17  Next
Tango Van - 1972 westy.. - Page 15 Empty
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyMon Nov 10, 2014 9:41 pm
Look up the prices...
Headers, heat exchangers.... affraid
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyTue Nov 11, 2014 6:02 pm
good work Rich !
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyTue Nov 11, 2014 7:13 pm
Meh! Had to replace both gaskets last night. Few hours work!
That and. Replacing vacuum hoses for brake servo. It's still taking too much / dropping the revs by 200rpm and is affecting the mixture... So may need to look ok at replacing the servo soon.
Test drive was to work in the morning! All fine.
Much better drive. Oil temp was noticeably lower - combination of exhaust sealed properly and manifolds sorted!!
Running at around 90deg C.
Pics later
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyTue Nov 11, 2014 7:29 pm
I'vd got a remote servo here I'm going to be flogging soon
Tango Van - 1972 westy.. - Page 15 Pbucket
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyTue Nov 11, 2014 10:59 pm
hmmm Question
will have a think scoops.. ideally looking to mount it in same place as current stock servo, however using a Brazilian bay set up inc new master cylinder.. saves having to sort new brake pipes etc..
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyTue Nov 11, 2014 11:19 pm
So...
As it was raining etc.. decided to try to get the bus as close to the garage as possible
Tango Van - 1972 westy.. - Page 15 494F6CE8-B15A-4EB7-8455-1B9C7C263C6D_zpsm4564fpx
Just happened to have some spare inlet manifold gaskets in stock
Tango Van - 1972 westy.. - Page 15 D07AD37A-578A-4EA4-AD95-3BDDF2489F4D_zpsl4vrip3r
Did the offending right hand side carb first.. bit of a pain, as chose to do it all in the engine bay as to avoid fuel spillages etc.. also quite worrying was how easily the nuts came off.. not that tight at all..
Tango Van - 1972 westy.. - Page 15 EAAF28DA-CDB3-4979-9918-01D0556A9804_zps9fzv0gl6
Removed old cracked gasket and plugged the inlets to avoid crap getting in as cleaning off manifolds.
Tango Van - 1972 westy.. - Page 15 62174EAB-12AC-429F-ACB1-8A1EC6BC4812_zpsznoxmy8l
Had to piece the broken gasket together to make sure nothing was missing..
Tango Van - 1972 westy.. - Page 15 AFA3DE2A-063A-4846-B3E9-6F36BAA18FA5_zpsnyi2iwh9
All cleaned and new gasket fitted..
Tango Van - 1972 westy.. - Page 15 2273144F-A9AF-401A-9E04-9ABDD0CAD183_zpsswcjomo1
Next was the left hand carb.. thought I'd better check it all whilst there..
Tango Van - 1972 westy.. - Page 15 83F5A3C8-72F4-4049-B20D-8034D62A51C3_zpsh5lnwxra
Just as bad.. but not completely blown yet.. fell apart as soon as I moved the manifold away from head..
Tango Van - 1972 westy.. - Page 15 22812387-245D-43FA-88D4-41BC14B47480_zpsgfqvdzrj
Replaced the vacuum connecting hoses to the balance pipes as had to undo them to move the carbs around.
All back in by midnight (started at 9pm ish) so not bad.
Test run was on the way to work.. had no engine temp reading on the gauge.. worked out I'd lent on the dipstick sender connection and had to replace the spade connection at work.
Engine running much better.. some slight pops at idle, but it was set up with a leaking header.. so needs a tweak. also have idle rpm a touch high at the mo.
However, on a better note it runs much cooler now!
After 25mile trip back from work in rush hour bristol traffic and 45-60mph on A38/A370.
Tango Van - 1972 westy.. - Page 15 8442B616-6D8B-4AED-9488-E9D8C6E4C23F_zpsd2c9upaq
Would normally be over 100 deg C..
Also, missed driving this bus in the dark/rain.. no intermitant wipers.. poor headlights (even though they are upgraded clear lens' euro sealed units with H4 lamps.. so main beam is essential at times.....
but love my blue led dash light mod I did a few years back Very Happy
Tango Van - 1972 westy.. - Page 15 6D828FFB-1C85-47FC-92A6-93C5CF7337EC_zpsuvzqpvlm
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyWed Nov 12, 2014 9:27 am
Looks like its been fighting all the way Rich - good to know its back fit and ready to go though Smile
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptySun Nov 16, 2014 7:15 pm
Yep.. Still fighting... Popped header off again. Got some fire gum paste to apply up by the copper gaskets. Need new 11mm outer diameter exhaust nuts.. Brass ones aren't tough enough! And a gasket for the muffler!
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyTue May 26, 2015 8:39 pm
So...
Time to sort this again...
Jobs to do:
Brazlian bay servo install as the stock servo has had it! This is not a straight swap...
New master cylinder to fit
New front to rear metal brake pipe to fit
New front brake flexi hoses to fit
Engine out
New pushrod seals to fit
New ht leads to fit
Need to make and fit new choke blanking plate gaskets
Oil change and new filter
Re-check and fit exhaust header with engine out. Still not sealing right
Plugs/valve clearances to set
Clean an re-paint tin wear and fan shroud
Clean and re-paint firewall
Clean and check starter solenoid
Put it all back in Wink
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyTue May 26, 2015 9:43 pm
powder coat the tin and firewall
worth every penny
Tango Van - 1972 westy.. - Page 15 B9d2fd24
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyTue May 26, 2015 9:49 pm
£120 for my tinware and firewall to be done at Nailsea.
Inclues media blasting and powder coating
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyFri May 29, 2015 2:19 pm
Jobs done so far...
Brazlian bay servo install.. inc new bracket made up
New master cylinder to fit - new front brake lines made up also.
New front to rear metal brake pipe fitted (for the brake servo hardline.. couldn't remove the old one so found some spare OG holes in the cross members - very tight fit and then primed and painted up in place)
New front brake flexi hoses to fit, inc new tabs and hard lines to the callipers all done
Fitted new vacuum hoses and non return valve: now no leak in the system and engine holds revs under servo.
Discovered: old feed pipe to m/c reservoir had no seals and was split, and remote reservoir was split in the bottom - enough to absorb moisture into the fluid.
Both ordered inc new seals and clips...
So: refit pipe and reservoir and then bleed brakes again on Sat morning... still air in the system)
then.
Still to do..
Engine out
New pushrod seals to fit (bought)
New ht leads to fit (bought)
Need to make and fit new choke blanking plate gaskets (bought gasket paper)
Oil change and new filter (bought oil, need to get filter)
Re-check and fit exhaust header with engine out. Still not sealing right (bought new copper gaskets)
Clean an re-paint tin wear and fan shroud (bought etch primer and paint)
get x2 new front tyres as walls are cracking
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyFri May 29, 2015 4:30 pm
Fook!
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyTue Jun 02, 2015 10:29 pm
Eyelids removed and chrome all cleaned up. Also refuted the stainless grill and tidied up edges
Tango Van - 1972 westy.. - Page 15 A5F115EE-9CB8-484A-AF76-D0FCD952A206_zpswqoab1ko
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyTue Jun 02, 2015 10:31 pm
Made my own hotstart relay setup
Tango Van - 1972 westy.. - Page 15 B124F404-27BF-4E6B-B600-B37AB0353046_zpswwurp3i5
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyTue Jun 02, 2015 10:34 pm
Servo removal
Tango Van - 1972 westy.. - Page 15 B56E02F3-3D1A-45BF-B2E5-3BC919EFD7E7_zpsdv6eebd1
Tango Van - 1972 westy.. - Page 15 9E0D8655-FE53-45D4-9321-081625174A5A_zpsjlyrukn3
Tango Van - 1972 westy.. - Page 15 74C16B60-4731-4BEC-BF33-BBA8BFCFE4CE_zpsfxwudumd
Tango Van - 1972 westy.. - Page 15 9E9B81C0-BDF0-4763-8B06-7D3AFFCE1995_zpscm6ofuih
Tango Van - 1972 westy.. - Page 15 6E3BD694-495A-47D2-9DB8-84F4356E8562_zpsgkwlxuyt
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyTue Jun 02, 2015 10:36 pm
Full of muck and rust inside servo. Brake reservoir full of muck and master cylinder knackered. Needless to say replaces all front pipe work and fully flushed out hardline to rear. Rear pipe from t piece already been replaced when I did brakes back in sept.
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyTue Jun 02, 2015 10:38 pm
New Brazilian servo and m/s
Tango Van - 1972 westy.. - Page 15 1CE3577C-7AF0-404D-8B51-49790E816CE4_zpsvyyblrq9
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyWed Jun 03, 2015 8:12 pm
Bracket sprayed up
Tango Van - 1972 westy.. - Page 15 398D1CEC-4877-428D-B156-3F9DD974CADD_zpswobouqrf
Tango Van - 1972 westy.. - Page 15 C4F73D4C-98C6-4939-8D2A-E56F150DD459_zpssh2lnvba
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyWed Jun 03, 2015 8:23 pm
Had to drill out original servo braket on the beam as new bolt pattern was smaller. This placed it too close to the edge so mad up some sandwich plates..
Tango Van - 1972 westy.. - Page 15 EEF8807B-7782-4CBC-A418-F9AF88E1D099_zpsnnzu8s5v
Made some spacers also behind the old bracket to ensure bellows don't pinch
Tango Van - 1972 westy.. - Page 15 85A6E8A2-874A-437A-8421-537A07E7A82C_zps6ijl4pj1
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyWed Jun 03, 2015 8:30 pm
Brake rod connected and thread / nut all cleaned up.
Tango Van - 1972 westy.. - Page 15 3838CF6F-F2DE-4D2B-8DE1-A169F250B03B_zpsacfwzbkc
Brake reservoir cleaned out and fitted up
Tango Van - 1972 westy.. - Page 15 61056194-1AF7-41FF-9DF7-F3DA8DA0960F_zpseni7bqhb
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyWed Jun 03, 2015 8:34 pm
Good work Squire.
I took the Mrs's Bug to Gonzo and then to the Failand for dinner.
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyWed Jun 03, 2015 8:45 pm
New front brake lines all made up and new flexi pipes fitted
Tango Van - 1972 westy.. - Page 15 32E20EC1-9255-4966-A28C-8777373288DB_zpsfm9hudwn
Tango Van - 1972 westy.. - Page 15 ED33F1B5-8B6B-428C-AC02-2D1C8A11B942_zpsj09df26u
Tango Van - 1972 westy.. - Page 15 04FE17DE-290B-4ACF-A035-C295A8756A3A_zpsf6ano1bo
Tango Van - 1972 westy.. - Page 15 EC2A23F9-EF2D-4313-971F-8519419C882C_zps0ofbg7q9
Also fitted all new hard line for vacuum pipe from front to rear of bus and painted up under chassis. Also new servo flexi brake pipe
Tango Van - 1972 westy.. - Page 15 DBE735BE-4E40-4643-A3FF-CBBCBA02A1C5_zpskofnidqm
In etch primer here so you can see it, but then 2 coats of satin black and lacquer to try and protect it
Tango Van - 1972 westy.. - Page 15 662B67BA-6971-4186-B6B4-A23AFBBC8B5F_zpsvenida5t
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyWed Jun 03, 2015 8:59 pm
All fitted up and bled.. Cheers Wizpop for your brake pedal skills, but then no pressure and fluid leaking out under master cinder!!!
Turned out that the feeder hose from remote reservoir was damaged and had a seal missing.. Also when removed it all that had a split in the base so was absorbing moisture etc...
So had sat delivery of parts from heritage and then all replaced and bled.. New pipe was wrong moulded shape, so had to heat it up gently and reshape it.
Old:
Tango Van - 1972 westy.. - Page 15 032740E9-0342-4787-A613-8AD0B7366916_zps4hrksunz
Tango Van - 1972 westy.. - Page 15 006F0AB1-9812-47DA-B543-2EB49EDD7B82_zps8hrzjou1
Tango Van - 1972 westy.. - Page 15 B2AC8E79-1C0A-42DC-9A64-AE65F1EE96A5_zpsvhcqedqc
New!!!!
Tango Van - 1972 westy.. - Page 15 E086E5BF-AB26-4103-9925-5E216BBD337B_zpsrf47qwug
Next to each other
Tango Van - 1972 westy.. - Page 15 B5EB3DCA-664C-4AAA-99C7-0664E3D30900_zps46ajo26o
But of a pig to fit but all in
Tango Van - 1972 westy.. - Page 15 9EEDFA66-37EB-4B7A-BE74-982256103635_zpskb89awse
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 15 EmptyWed Jun 03, 2015 9:22 pm
Friday night is... Engine out for new pushrod seals and a service, new leads etc...
Page 15 of 17Go to page : Previous  1 ... 9 ... 14, 15, 16, 17  Next
» 1972 Ruger .44 mag deer rifle (Deer Stalker Edition) ****Sold****
» Debbie Heald - HS Mile Record 1972 Video
» Manager Alan Brown - November 1972 (no money has been available to buy players.)
» 25 years ago - Scotsman wins the Wangaratta Gift!
» Muscle car commercials!!
