Number of posts : 7198 Age : 52 Location : Wouldn't I like to know My Ride(s) : Rollercoaster Registration date : 2009-08-09
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Nov 25, 2012 10:19 pm | |
| Must be the same height as mine, thought mine was lower than that, perhaps the camera angle trickery... | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Nov 25, 2012 10:20 pm | |
| I think yours sits a lot lower than mine Dude. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Dec 01, 2012 10:32 pm | |
| I decided I needed to recommission SuperDry today. Rolled her out on to the drive, checked the wheel bolts from last week. Popped the shifter off and packed the socket full of grease and refitted it. Went to start it up and despite having a new starter on there and a brand new battery, whilst it put the red dash lights on, when I turned the key they dimmed, but there was no noise from the starter etc. When I had a bit of a nose at the earth cable from the battery I found this. I think there was a distinct lack of current being able to flow through this! Swapped it out for a pukka braided earth strap and it fired up instantly. Took it out for a drive, and broke down within 10 minutes. Had a bit of a nosey around and found the problem. A the back if the fusebox I'd piggybacked a feed for the tacho, and the spade connector had come off, taking with it the connection for the ignition switch. D'oh!! | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Dec 02, 2012 8:22 am | |
| I was pleased with the CSP shifter but there was an issue in that there was no lockout for reverse. So going to second from third could be a pain. Had a quick look in the Haynes and I've realised I'm missing a lock plate Number 9 (and the Spring (8 )) I'll have shufty around the autojumble today.
ARCANE DBS Old Timer
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Dec 02, 2012 2:33 pm | |
| I've definitely got the spring I will have a look for a plate. | |
Jam Man DBS Old Timer
Number of posts : 1687 Age : 51 Location : Lympsham Registration date : 2009-06-01
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Dec 02, 2012 3:48 pm | |
| I think there was one of those plates from my 71 bay in a box of old tat that Gunge had from me before we moved.
Might be wrong, might not be! | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Thu Dec 06, 2012 10:47 pm | |
| I've just ordered a new stop plate and a set of replacement plastic bushes for the gear linkage. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Dec 22, 2012 1:31 pm | |
| Just ordered a new set of belt line trim clips and screws. Fingers crossed they come whist I'm off.
Gonna pop the over-riders off and fit the shagged bumper trim too. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Dec 22, 2012 3:43 pm | |
| Noooooooo! Don't go drilling your bus, use 3M trim tape.. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Dec 22, 2012 4:39 pm | |
| Got a link? Surely it'll be better to use the pukka clips etc? | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Dec 22, 2012 4:42 pm | |
| old skool technology dude... ALL car manufacturers today bond trim on.... | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Jan 06, 2013 5:39 pm | |
| So, the CSP shifter still wasn't set up 100% so I thought I'd have another look. Upon inspection it seemed that the pin that retracts when the thumb button was pushed on the top of the shifter wasn't clearing the reverse stop plate underneath. I've added a couple if washers between the plate and the shifter base and it's much better, however, I think I need to tweak up some fasteners in the shifter base. Am I right in thinking these are torq screws? I can buy the bits/drives (whichever) tomorrow and have another look tomorrow night. I'm determined not to let this shifter beat me and I'm fed up finding reverse instead of second when changing down. Didn't get the pillar spot, bumper trim or beltline trim on yet though..... | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Jan 06, 2013 5:55 pm | |
| Torx security bits, with a pin in the middle. Your bit needs a hole in the middle to fit. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Jan 06, 2013 6:02 pm | |
| Cheers Dude. Halfrauds tomorrow then. | |
Bmtt4 Club GIMP
Number of posts : 1123 Age : 37 Location : Bridgwater My Ride(s) : MkV Golf GT Tdi 140 bhp, Mini Clubman 1380 Racer (No Quite!) Registration date : 2009-04-18
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Jan 06, 2013 8:02 pm | |
| or try weston fastners on oldmixon probably alot cheaper that halfrauds | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Jan 06, 2013 9:13 pm | |
| I'll try Patchway Auto's at lunchtime tomorrow. | |
Number of posts : 4830 Age : 51 Location : Highbridge My Ride(s) : 1972 Bay; Shitroen C4 Registration date : 2008-04-28
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Jan 06, 2013 9:45 pm | |
| if you dont have security tor-x bit you can use a strong flat bladed screw driver and break the pin off, if you dont have a normal tor-x bit then an allen key will work | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Jan 06, 2013 9:47 pm | |
| I've got some normal Tor-x but for the sake of buying a few bits I'll get them tomorrow. It's starting to piss me off now. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Jan 06, 2013 9:52 pm | |
| shame as i was in milton today and could of brought you a set | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Jan 06, 2013 9:56 pm | |
| No worries. I always buy anything I need to use now fella. I've always got it in the case of needing it again. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Jan 06, 2013 11:13 pm | |
| Just bought a 'ratty' Buddy Box for SuperDry to fit between the front seats. Will get the lid trimmed in red vinyl when it arrives. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Mon Jan 07, 2013 12:18 am | |
| So...did you buy three of them? | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Mon Jan 07, 2013 7:33 am | |
| You're a cunt! I've got one of these lined up for my bus!! | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Mon Jan 07, 2013 7:46 am | |
| I only bought the scruffy looking one.
If you're planning on getting one Carl I'd get a wriggle on, these 3 are his last and be ain't making any more. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Mon Jan 07, 2013 7:59 am | |
| Really Thanks for the heads up! | |
