| My 65 split bus | |
+24Russi666 renegade67 delboy leahcar52 Big Blue Betty Shamrockez eddie gordo purple73 slammervan nomates itsabuglife soapbox VWFRIZZ Cleverchap 1584cc lowriderbug vwbeetlebum Mr Scoops Impy Mcdub ANDYLHAM dubberatlast spennyp Dirty Dave thecrewkid 28 posters |
| Subject: Re: My 65 split bus Wed Jun 06, 2007 6:59 pm | |
| Subject: Re: My 65 split bus Wed Jun 06, 2007 7:15 pm | |
| Subject: Re: My 65 split bus Fri Jun 15, 2007 6:03 am | |
| Got a few little bits for her at Bristol.. Interior door handles front and back, cargo door stops and another fuel cap.. And a new better set of carb linkages.. You don't want pics really do you cos it's not that exciting | |
| Subject: Re: My 65 split bus Fri Jun 22, 2007 7:30 pm | |
| Well oh well looks like i've just ground my last grinder and welded my last weld Here you go peeps probably the last update.... The last bit of welding that needed doing is done.. Passenger side inner wing looked abit bubbly so had a look and it went to this.. So i cut the top panel off and the inner was gone as well.. So i cut that out as well And then welded the new piece. And ground it back flush Then cut and drilled a fresh top piece and welded it in Then ground it back smooth And a couple of coats of black I had real JOY doing it, even more when i saw the niegbours were looking so i made as much fooking noise as i could and was laughing at the same time | |
| Subject: Re: My 65 split bus Fri Jun 22, 2007 9:52 pm | |
| Subject: Re: My 65 split bus Fri Jun 22, 2007 9:55 pm | |
| Shame she is going really, I love that bus!! |
| Subject: Re: My 65 split bus Tue Jul 10, 2007 5:55 am | |
| As you know the old dog is staying to ruin my life a bit longer Anyway BVF i got a bargain front towel rail for her just need a pair of over riders now.. And the last 2 popouts that i needed and they are very good.. Gonna order a pair of hinges from CE and then it'll be time to cut up the dorrs | |
| Subject: Re: My 65 split bus Tue Jul 10, 2007 9:40 am | |
| Subject: Re: My 65 split bus Mon Jul 16, 2007 7:58 pm | |
| - thecrewkid wrote:
- As you know the old dog is staying to ruin my life a bit longer
Now how true were those words.. After give her a very little bit of a HARD time the other day i seem to only be firing on 3 cylinders.. I've used her a few times since and it's just getting worse.. Gonna try and get her to the unit this week and have a proper look at her sometime.... Is this the END of the session for the bus... Will she be getting pulled apart to a bare shell sooner then i wanted It's all good fun baby just you remember that | |
| Subject: Re: My 65 split bus Mon Jul 16, 2007 10:42 pm | |
| Subject: Re: My 65 split bus Tue Jul 17, 2007 5:55 am | |
| Hope it doesn't turn out to be anything too expensive Buddy. | |
| Subject: Re: My 65 split bus Tue Jul 17, 2007 6:22 am | |
| Subject: Re: My 65 split bus Sun Jul 22, 2007 7:20 pm | |
| I had a bit of free time today so dragger her to the workshop to sort the running probs out only firing on 3 cylinders number one not firing.. I wired in a starter buttom in the engine bay so i could turn it ove myself to check for a spark pulled both plugs 1+2 out remove the O/S carb stripped it and cleaned it.. Then with it all still stripped i spun the motor to check for a spark on 1+2 and it was good but the motor fired up ran and reved on 2 cylinders... So bolted it all back together changed the exhaust and it was all good ran fine.. Drove home fine reved better went better.. Pulled in to my road and bang back 3 cylinders.. | |
| Subject: Re: My 65 split bus Mon Jul 23, 2007 11:14 pm | |
| There you are then, your bus doesn't like your neighbours either! |
Number of posts : 1435 Age : 45 Location : Sitting in a room, in Exeter! My Ride(s) : 2005 T5 Transporter, 67 very original ozzy bug running a 1914 lump.. Registration date : 2007-05-07
| Subject: Re: My 65 split bus Sun Aug 12, 2007 5:41 pm | |
| So whats the lastest the dude? got your motor sorted out yet, and got them doors cut and windows in... you have plenty of time | |
| Subject: Re: My 65 split bus Sun Aug 12, 2007 5:44 pm | |
| Subject: Re: My 65 split bus Sun Aug 12, 2007 5:45 pm | |
| Hurry up then, the hour is near | |
| Subject: Re: My 65 split bus Mon Aug 13, 2007 6:36 pm | |
| The hinges have been ordered so SHOULD be here tomorrow but you know what CE can be like.. | |
| Subject: Re: My 65 split bus Mon Aug 13, 2007 6:48 pm | |
| Im waiting for my frame to glass seals i ordered 5 weeks ago too | |
| Subject: Re: My 65 split bus Tue Aug 14, 2007 3:38 pm | |
| Sh1t the bed 9:15 this morning they came through the door less then 24 hrs.... Watch this space for panel van doors being cut up... | |
| Subject: Re: My 65 split bus Tue Aug 14, 2007 7:06 pm | |
| Funny you should say that, just got my rubber from them today too | |
| Subject: Re: My 65 split bus Tue Aug 14, 2007 9:02 pm | |
| - delboy wrote:
- Funny you should say that, just got my rubber from them today too
Fnarr fnarr!!! | |
| Subject: Re: My 65 split bus Wed Aug 15, 2007 9:16 pm | |
| Some kind of a update coming to a thread near you SOON... WITH PICS | |
| Subject: Re: My 65 split bus Wed Aug 15, 2007 9:24 pm | |
| Right here you go.. Cargo doors. top less Window section placed up. Unwanted metal.. Then the next door. Both welded in with new CE pop out hinges and pop outs fitted.. | |
| Subject: Re: My 65 split bus | |
| My 65 split bus | |
