| Subject: Re: 71 Early Bay (formerly known as Superdry) Tue Dec 09, 2014 10:24 pm | |
| - Shorty wrote:
- I don't get why you need to put the bolt in? I don't see what help that bit was.... have I missed something?!
You screw the bolt in, then turn the head through 180 degrees and then use the punch to knock the guide out. Knocking the punch again the bolt you've just screwed in. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Tue Dec 09, 2014 10:30 pm | |
| - joker 67 wrote:
- stateside do valve guide fitting, based in herefordshire.
I may as well have a pop myself Andy if that vid is anything to go by. An evening and they'll be done. Just got to sort some tinware and then paint or powder coat it and I can get the other jobs sorted. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Tue Dec 09, 2014 10:46 pm | |
| I would go down your f in laws and use his press, and freezer | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Wed Dec 10, 2014 11:11 am | |
| if you have access to a press this would be much easier. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Wed Dec 17, 2014 9:17 pm | |
| My new firewall rocked up today. I need to get it cleaned up and I can then get the fuel tank back in. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Wed Dec 17, 2014 9:43 pm | |
| Nice. Cleaning and then spraying it ? | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Wed Dec 17, 2014 9:54 pm | |
| Def going to clean it, might give it a different finish rather than just painting it..... | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Thu Dec 18, 2014 8:19 am | |
- Def going to clean it, might give it a different finish rather than just painting it.....
Metalflake? | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Thu Dec 18, 2014 11:02 am | |
| scoops, I just did the valves guides and stem seals on my POLO CYL head.
Its not that bad to be honest.
Just keeping it all super clean and measure / mark it all up. you'll be fine.
Make sure you lap the valves in correctly and that there is a watertight seal.
To check the seal I used a bit of engineering blue to check the valve to valve seat mating surface. Then I partially rebuilt the head by installing the valves with the springs. Install the spark plugs. turn the head over (get it as level as possible) and fill the Chambers in the head with petrol to check for leaks. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Thu Dec 18, 2014 1:02 pm | |
| Nice one. Going to order the valves and guides tonight. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Thu Dec 18, 2014 1:10 pm | |
| - Big_Al wrote:
Metalflake? Actually thinking about some sort of graphics on it...... | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Thu Dec 18, 2014 6:02 pm | |
| How about a brand that's motor related, there's loads of good clothing motifs out there :p | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Thu Dec 18, 2014 9:15 pm | |
| I've got an idea but want to keep it under wraps at the moment | |
ServetaPaul DBS Old Timer
Number of posts : 1674 Age : 58 Location : BK, Highbridge My Ride(s) : 2000 XJR1300, 1971 GP125, 1969 Li150, 1975 C90, 1982 C90 Registration date : 2010-12-05
| Subject: Re: 71 Early Bay (formerly known as Superdry) Thu Dec 18, 2014 10:47 pm | |
| How about a putting the magazine article on it ? | |
Graham NBC DBS Pervert
Number of posts : 556 Age : 60 Registration date : 2010-01-30
| Subject: Re: 71 Early Bay (formerly known as Superdry) Fri Dec 19, 2014 1:31 pm | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Fri Dec 19, 2014 10:22 pm | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Dec 20, 2014 9:08 am | |
| Keep your suggestions coming.... | |
vwroadster Blitzen Regular
Number of posts : 337 Age : 66 Location : Portishead My Ride(s) : Wizard Roadster Registration date : 2007-03-15
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Dec 20, 2014 8:29 pm | |
| I like the idea of pasting your magazine featured Van on it, or maybe past it over ALL your fan housing and tinware (not straight and over lapping, random).
You could see what it would look like if you could photoshop it on. You could also try this theme or idea with vinyl wrap, if you could get the idea printed up.
As anyone see it done before?
Similar what people do to their vehicle interiors or ceilings.
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Dec 21, 2014 11:34 pm | |
| could get it hydrodipped , then you can have what ever you want on it | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Jan 03, 2015 5:15 pm | |
| Just ordered new valves and guides, some replacement tinware pieces, heat exchangers, new tinware screws, heater piping, new pulley, crankshaft oil seal and installation tool, sump plate with drain hole, tank filter, breather joints, battery tray and some full flow kit. That should get me back on the go! | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Jan 03, 2015 5:44 pm | |
| What heat exchangers have you bought? | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Jan 03, 2015 5:55 pm | |
| Machine 7 repops. One of mine had a slight hole in and the other was battered | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Jan 03, 2015 6:20 pm | |
| Good luck, the fit on the fasty ones was shit and they are split somewhere near no3 cylinder inside the jacket :/ | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Jan 03, 2015 7:30 pm | |
| Meh, if they're shit I'll just send them back as Ive got an Eberspacher coming | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Jan 04, 2015 7:45 am | |
| Just asking as I have been looking and C&C (might be vwh thinking about it) do a ' superior ' one which I have been contemplating over taking a risk on old origins parts...
I'll be interested to hear your views when you get them.. | |
