| Bella - 1958 Australian Beetle | |
+27ARCANE Cleverchap Wurz joker 67 Impy Mcdub Dirty Dave 1584cc nomates delboy eddie gordo type25 dan Russi666 Big Blue Betty Azrael lowriderbug ANDYLHAM purple73 VWFRIZZ thecrewkid itsabuglife Mr Scoops spennyp renegade67 vwbeetlebum soapbox dubberatlast Shamrockez 31 posters |
| Subject: Re: Bella - 1958 Australian Beetle Thu Feb 26, 2009 10:15 pm | |
| - Cleverchap wrote:
- NICE SPOTTY SOCKS!!!!!!!!!
I noticed that too ....very cheerful socks ...you can tell a lot by a person's socks (I however ...smell ,and as I'm a rev ...i'm also very holey ) | |
| Subject: Re: Bella - 1958 Australian Beetle Fri Feb 27, 2009 6:13 am | |
| why thank you! | |
| Subject: Re: Bella - 1958 Australian Beetle Fri Feb 27, 2009 9:09 am | |
| just had a look at cutting the current rod - tried with a junior hacksaw and after about 20 mins of sawing, I only had a small cut... got the jigsaw out but the blade wasn't long enough, so went to get our new angle grinder which we got for Christmas (we lost our old ones in the flood) and it doesn't work! So my day of fixing Bella came to a halt before 8am | |
| Subject: Re: Bella - 1958 Australian Beetle Fri Feb 27, 2009 3:43 pm | |
| Its a bummer when a plan turns to poop | |
| Subject: Re: Bella - 1958 Australian Beetle Fri Feb 27, 2009 4:41 pm | |
| Indeed gotta go into town tomorrow to buy a new angle grinder now. | |
| Subject: Re: Bella - 1958 Australian Beetle Fri Feb 27, 2009 4:45 pm | |
| spotted some cheapuns in aldi b/w if any help? |
| Subject: Re: Bella - 1958 Australian Beetle Fri Feb 27, 2009 4:46 pm | |
| I think B&Q do them for about £10. How much were they in Aldi? | |
| Subject: Re: Bella - 1958 Australian Beetle Fri Feb 27, 2009 4:52 pm | |
| sorry didnt see! but hey at a tenner, b&q sounds good worth a look in aldi as they had loads of discs etc, but again didnt notice price |
| Subject: Re: Bella - 1958 Australian Beetle Fri Feb 27, 2009 4:53 pm | |
| yeah can't grumble with a tenner really | |
| Subject: Re: Bella - 1958 Australian Beetle Sat Feb 28, 2009 6:20 pm | |
| It does! After trying to use a junior hacksaw for what seemed like hours on Friday, I managed to get a small indent into the rod... I couldn't really get the saw in to cut it properly, so Jim suggested I used a different type of saw, which I got today and set it to work: After ages of sawing, I finally cut through it: Yep it wasn't going to bend or rust away, was it?! Looks like she's smoking a pipe lol: That's as far as I got as I need to take the bumper off and move the Split out the way to get it out, and the Split's up on axel stands so hopefully he'll be moving tomorrow | |
| Subject: Re: Bella - 1958 Australian Beetle Sat Feb 28, 2009 6:47 pm | |
| did you have to make a hole in the front clip to remove the gear rod? | |
| Subject: Re: Bella - 1958 Australian Beetle Sat Feb 28, 2009 6:48 pm | |
| no there's a hole already there | |
| Subject: Re: Bella - 1958 Australian Beetle Sat Feb 28, 2009 6:50 pm | |
| cool ......I thought you may have extra work ......good news | |
| Subject: Re: Bella - 1958 Australian Beetle Sat Feb 28, 2009 6:51 pm | |
| nope, cunningly VW had thought of this! Otherwise it would have been a body off job! | |
| Subject: Re: Bella - 1958 Australian Beetle Mon Mar 02, 2009 2:06 pm | |
| Finally got the refund on the other beam so it's all systems go! Ordered a pair of 12v semaphores, a dual circuit master cylinder and a new gearstick boot from Heritage and a Volvo 240 reservoir to go on the master cylinder. Think I confused the chap on the phone at the Volvo place when I explained it was for a Beetle | |
| Subject: Re: Bella - 1958 Australian Beetle Wed Mar 04, 2009 8:21 pm | |
| Joey Bus went for his MOT retest today so I had the chance to remove the old shift rod (he was in the way before) and get the new one fitted. Steve helped me fit the new one as it's tricky to do it on your own without 'go go gadget' arms. Anyway, got that fitted and started looking for the new selector plate that I bought at Dubfreeze...... hmmm looks a little different to the old one.... Yep, that's right - there's a chunk missing where it's worn through and there's a massive crack in it, so I could pull it apart with my fingers! What on earth has happened to this Beetle?! First of all the gearbox was lose and moving around because the threads for the front mount had been snapped off, then the coupling was welded to the rod and now this plate! | |
| Subject: Re: Bella - 1958 Australian Beetle Wed Mar 04, 2009 8:43 pm | |
| I have no idea ....but I would say its unusual for this part to wear as bad as it has ....keep up the pics .....awesome thread | |
| Subject: Re: Bella - 1958 Australian Beetle Wed Mar 04, 2009 8:45 pm | |
| yeah I can't say I've ever read about one wearing like this. Good job I decided to change it, otherwise I'd have plodded on without knowing and it would have eventually broken up completely and I'd be stuck somewhere with no/few gears! | |
| Subject: Re: Bella - 1958 Australian Beetle Wed Mar 04, 2009 9:09 pm | |
| one more step closer to the mot | |
| Subject: Re: Bella - 1958 Australian Beetle Wed Mar 04, 2009 9:10 pm | |
| yep all there is to do is put the beam back on and wire up the semaphores. | |
| Subject: Re: Bella - 1958 Australian Beetle Mon Mar 09, 2009 9:12 pm | |
| Right, well we fitted the new shift rod, did the coupling up, fitted new shifter plate and..... only managed to get 2 gears after asking on the tech forum, I came to the conclusion that it was the wrong year, so pulled it out to check.... you can see the obvious differences! The original one is the one which is in 2 bits lol. My other parts arrived on Friday - 12v semaphores and new dual circuit master cylinder. I also got a Volvo 240 reservoir. On my way home from uni today I stopped off at Jim's (Tofufi) house to collect some grub screws for the adjusters (thanks Jim!) and then onto Dirty Dave's house to collect her original beam... those of you who've followed this thread for longer know Tom took 3.5in out of it and removed the shock towers - Dave has narrowed it another 1.5in and fitted shock towers - thanks Dave! And with a bit of POR-15: We mocked it up and it appears to fit like a glove! | |
| Subject: Re: Bella - 1958 Australian Beetle Mon Mar 09, 2009 10:44 pm | |
| that beam looks ...'one off' and superb ......i'm not jealous ...nope not me ....no ......no ...............no | |
| Subject: Re: Bella - 1958 Australian Beetle Mon Mar 09, 2009 10:49 pm | |
| Let's see some pics of it mocked up............ | |
| Subject: Re: Bella - 1958 Australian Beetle Mon Mar 09, 2009 10:57 pm | |
| we didn't take any - and it's now covered in wet POR-15 lol. I'll take some when we fit it - prob weds or thurs. | |
Number of posts : 1435 Age : 46 Location : Sitting in a room, in Exeter! My Ride(s) : 2005 T5 Transporter, 67 very original ozzy bug running a 1914 lump.. Registration date : 2007-05-07
| Subject: Re: Bella - 1958 Australian Beetle | |
