| Bertie the bug | |
+10Impy Mcdub 1584cc spennyp nomates Mr Scoops itsabuglife thecrewkid vwbeetlebum purple73 dubberatlast 14 posters |
| Subject: Re: Bertie the bug Mon Mar 19, 2007 10:59 pm | |
| http://www.volkszone.com/VZi/showthread.php?p=3397481#post3397481 there you go dude add to it if you think of anything its got you started | |
| Subject: Re: Bertie the bug Mon Mar 19, 2007 11:03 pm | |
| Subject: Re: Bertie the bug Mon Mar 19, 2007 11:06 pm | |
| cheers dude just added abit not loosing faith yet though dude | |
| Subject: Re: Bertie the bug Mon Mar 19, 2007 11:10 pm | |
| Subject: Re: Bertie the bug Mon Mar 19, 2007 11:27 pm | |
| If it was me I would double check the timing is spot on, make sure the carbs are jetted for a 1641 and not a 1776 or something, make sure the 009 distributor is advancing properly, Oh, and make sure the fuel is getting to carbs properly. I know it is not much help but you got to start from the beginning and work through it as logically as you can. |
| Subject: Re: Bertie the bug Mon Mar 19, 2007 11:29 pm | |
| - moup wrote:
- If it was me I would double check the timing is spot on, make sure the carbs are jetted for a 1641 and not a 1776 or something, make sure the 009 distributor is advancing properly, Oh, and make sure the fuel is getting to carbs properly.
I know it is not much help but you got to start from the beginning and work through it as logically as you can. the thing is with the jetting im not 100% sure what size the motor to know what jets it shud be running | |
| Subject: Re: Bertie the bug Mon Mar 19, 2007 11:31 pm | |
| Bugger! In that case you really need to pull the tops off On the bright side at least you would have another chance to fix the oil leak! |
| Subject: Re: Bertie the bug Mon Mar 19, 2007 11:43 pm | |
| i rekon im gona have to buy brand new heads to sort that out | |
| Subject: Re: Bertie the bug Mon Mar 19, 2007 11:47 pm | |
| Its got to be something simple as it ran fine with everything thats on it now before you took it out the only thing changed is plugs and leads so i say go back to the old ones to eliminate that as the prob, then blow all the fuel lines through and as harv said make sure the fuels getting to each carb, i would have done this but it was 9:30pm dude so getting on abit | |
| Subject: Re: Bertie the bug Mon Mar 19, 2007 11:48 pm | |
| Sam, I once fitted a brand new chrome rocker cover that just wouldn't seal! Ended up putting the old rusty one back on! | |
| Subject: Re: Bertie the bug Tue Mar 20, 2007 12:45 am | |
| Just because something is new doesn't mean it is any good, so as Carl says, elimate the leads and cap first, then look for other problems |
| Right dude ive been having a chat with someone and agrees go back to the old plugs as they where bosch and you have unknown make plugs now so gap could be wong and go back to old leads see if its better then let me no dude | |
| Subject: Re: Bertie the bug Tue Mar 20, 2007 12:50 am | |
| Oh and just in case this helps, the new leads I bought are NFG, I am back on the old ones |
| Subject: Re: Bertie the bug Tue Mar 20, 2007 7:38 am | |
| Give me a ring later bud and i'll pop round for a look and see what i think can't stay long but hope fully long enough | |
1584cc Blitzen Regular
Number of posts : 400 Age : 56 Location : In the Sticks My Ride(s) : 1971 1300 Beetle, 1970 1302 Beetle, 1971 Deluxe Bus, 1972 1200 Beetle Registration date : 2006-12-07
| Subject: Re: Bertie the bug Tue Mar 20, 2007 9:20 am | |
| From your description sounds like a fuel/carb problem.
Have you checked the valve clearances after you changed the pushrod tubes? Check them even if you think they are correct.
If you've not removed/disturbed the distributor when you took the engine out and the engine was running before it should run now at least as far as the ignition/timing goes. Put your original leads back on and check your plug gaps.
The oil leak you have from the rocker cover should be cured by putting the original covers and bales on. The bolt ups have a reputation for leaking.
Hope you get it sorted I'm sure it's only something minor... | |
| Subject: Re: Bertie the bug Tue Mar 20, 2007 11:30 am | |
| have you checked the fuel lines are not blocked? my engine wonldn't tick over correctly and would cut out if i didn't have my foot on the gas, turned out to be a blocked fuel filter hidden under the fuel tank, i changed and now runs perfect |
| Subject: Re: Bertie the bug Tue Mar 20, 2007 12:59 pm | |
| plugs are ngk but might check the gaps in a min as ive been sciving but DONT LET THE BOSS KNOW also gona check me metal fuel line | |
| Subject: Re: Bertie the bug Tue Mar 20, 2007 8:22 pm | |
| well im putting a 1.3 in some point this week im gona completely strip my motor find out wat it is and rebuild it with new crank case and heads it will be at the bloody next meet if it kills me | |
| Subject: Re: Bertie the bug Tue Mar 20, 2007 8:25 pm | |
| why strip ot as its only the valve clearances that are out | |
| Subject: Re: Bertie the bug Tue Mar 20, 2007 9:18 pm | |
| scrap it | |
| Subject: Re: Bertie the bug Tue Mar 20, 2007 9:21 pm | |
| dont temp me only joking fat chance of that | |
| Subject: Re: Bertie the bug Tue Mar 20, 2007 10:21 pm | |
| Standard NGK plugs are crap, fit the iridium ones as they are much better, don't strip it down completely, just find out what size pistons are in it and spend sometime making sure the gaskets are good for the rocker covers, if you want some special gasket sealant we sell Ducatibond, it is quite dear but it seals Ducati crankcases together with no gaskets so it must be pretty good |
| Subject: Re: Bertie the bug Wed Mar 21, 2007 9:11 am | |
| Are we gona see this at the end of month meet? | |
| Subject: Re: Bertie the bug Wed Mar 21, 2007 1:10 pm | |
| we should be dude rich and me are on the case so its not having the engine pulled its having the valve gaps done by rich and im fitting the stock rocker covers | |
| Subject: Re: Bertie the bug | |
| Bertie the bug | |
