| The 72 custom bay called hank | |
+16spennyp nomates Shamrockez VWFRIZZ Mr Scoops vwbeetlebum lowriderbug BugBren thecrewkid ANDYLHAM Impy Mcdub Dirty Dave griff itsabuglife Big Blue Betty dubberatlast 20 posters |
| Subject: Re: The 72 custom bay called hank Sat Sep 01, 2007 9:49 pm | |
| At a guess dude theres valve looking thing mounted to the chassis kinda like behind where the servo used to be.. Could be the one???????? | |
Impy Mcdub DBS Old Timer
| - dubberatlast wrote:
- Impy Mcdub wrote:
- Has it got a proportioning/balance valve in the circuit?
If there is give it a few taps with a hammer cos it sounds like its stuck! Any ideas where its to bud i dont Just follow around the brake lines mate (mid to rear sections probably & you'll find it....just looks like a big pipe joiner or a small slave cylinder with a pipe at each end. | |
blueridge DBS Old Timer
Number of posts : 1245 Age : 43 Location : highbridge My Ride(s) : 1973 Squareback,1999 golf gti,95 GMC Safari. Registration date : 2007-04-12
| the balance valve maybe working correctly but when your bay was lowered they may not have re-set the valve. | |
| Subject: Re: The 72 custom bay called hank Sat Sep 01, 2007 9:58 pm | |
| if you dont re-set the balance valve when lowering it thinks it got weight in the van so it makes the rear brakes work harder | |
| Subject: Re: The 72 custom bay called hank Sat Sep 01, 2007 10:05 pm | |
| Whats the bleed nipple for and how do i reset it | |
| Subject: Re: The 72 custom bay called hank Sat Sep 01, 2007 10:07 pm | |
- Whats the bleed nipple for and how do i reset it
dont know about resetting it but tap it with the hammer then bleed it & see what happens | |
| - Impy Mcdub wrote:
That looks like the kiddie, get someone to pump the brakes while you tap it with a hammer (gently!!) & it'l probably free off if its stuck How will i no if its freed of mate and thanks | |
| Subject: Re: The 72 custom bay called hank Sat Sep 01, 2007 10:08 pm | |
| Cos the front will lock up first dude.. | |
| Subject: Re: The 72 custom bay called hank Sat Sep 01, 2007 10:09 pm | |
| If not then back the rear brakes off a bit | |
| Subject: Re: The 72 custom bay called hank Sat Sep 01, 2007 10:10 pm | |
dont know about resetting it but tap it with the hammer then bleed it & see what happens One more question do i have to bleed all the breakes again or just that thingy lol | |
| Subject: Re: The 72 custom bay called hank Sat Sep 01, 2007 10:11 pm | |
One more question do i have to bleed all the breakes again or just that thingy lol try the tapping trick, then test drive & only bleed it if you have to (you shouldnt have to bleed the rest again i wouldnt think) | |
| Subject: Re: The 72 custom bay called hank Sat Sep 01, 2007 10:13 pm | |
| Cool i will give it ago Rich if i back the rears of they willfail on performance | |
| Subject: Re: The 72 custom bay called hank Sat Sep 01, 2007 10:15 pm | |
| Subject: Re: The 72 custom bay called hank Sat Sep 01, 2007 10:17 pm | |
| just take em back a couple of clicks mate to balance things up | |
| Subject: Re: The 72 custom bay called hank Sat Sep 01, 2007 10:19 pm | |
| i will give the thing me jig a couple af taps with the lump hammer and if that dosnt work i will try backing them of on the rear and hope it passes | |
BugBren Blitzen Regular
Number of posts : 295 Age : 42 Location : Bridgwater My Ride(s) : Lovely Peachy Polo that Carl loves!! Registration date : 2007-05-01
| Subject: Re: The 72 custom bay called hank Mon Sep 03, 2007 9:52 am | |
| can't wait til wed, fingers, legs and toes crossed he passes, as i would love to go to vanfest in hank and not have to pitch a tent up | |
| Subject: Re: The 72 custom bay called hank Mon Sep 03, 2007 6:11 pm | |
| All breaks sorted i hope just the lights to adjust tomorrow evening Also got to pick my free awning up at vanfest | |
| Subject: Re: The 72 custom bay called hank Mon Sep 03, 2007 6:21 pm | |
| well done fella! |
| Subject: Re: The 72 custom bay called hank Mon Sep 03, 2007 6:25 pm | |
| Good work dude, fingers crossed for the MOT... Leave a opened pack of wine gums on the passenger seat it always works | |
| Subject: Re: The 72 custom bay called hank Mon Sep 03, 2007 8:36 pm | |
| did tapping the thingamy jig work .....or did you back off the rear brakes dude??? | |
| Subject: Re: The 72 custom bay called hank Mon Sep 03, 2007 8:50 pm | |
| Ive backed of the breakes as tapping the thingy did nothing i even blead it again and it blead fine But it was the same when it went for its first mot and they didnt fail it on that just the servo and the rear breaked binding | |
| Subject: Re: The 72 custom bay called hank | |
