| My 65 split bus | |
+24Russi666 renegade67 delboy leahcar52 Big Blue Betty Shamrockez eddie gordo purple73 slammervan nomates itsabuglife soapbox VWFRIZZ Cleverchap 1584cc lowriderbug vwbeetlebum Mr Scoops Impy Mcdub ANDYLHAM dubberatlast spennyp Dirty Dave thecrewkid 28 posters |
Number of posts : 8406 Age : 43 Location : Bridgwater My Ride(s) : '04 LWB T5.. Restored escort RS turbo estate. Registration date : 2006-08-30
| Subject: Re: My 65 split bus Mon Jan 07, 2008 9:46 pm | |
ProjectParsons DBS Old Timer
Number of posts : 1431 Age : 42 Location : Burnham on Sea My Ride(s) : MK2 Jetta Turbo Diesel Registration date : 2007-03-22
| Subject: Re: My 65 split bus Mon Jan 07, 2008 9:59 pm | |
| Perhaps he needs to be introduced to Spence and Java!!! | |
| Subject: Re: My 65 split bus Mon Jan 07, 2008 10:14 pm | |
| That would suprise the crap out of him! As long as the speed humps didn't bugger up Java's gearbox as well |
blueridge DBS Old Timer
Number of posts : 1245 Age : 43 Location : highbridge My Ride(s) : 1973 Squareback,1999 golf gti,95 GMC Safari. Registration date : 2007-04-12
ANDYLHAM DBS Pervert
Number of posts : 952 Registration date : 2006-08-20
| Subject: Re: My 65 split bus Mon Jan 07, 2008 10:36 pm | |
| my old short shaft went down the scrappy last week dude | |
type25 dan DBS Old Timer
Number of posts : 1245 Age : 41 Location : highbridge My Ride(s) : passat 2.0 sport, mrs t25 dan and a TRANSIT work van Registration date : 2007-09-01
Number of posts : 1435 Age : 45 Location : Sitting in a room, in Exeter! My Ride(s) : 2005 T5 Transporter, 67 very original ozzy bug running a 1914 lump.. Registration date : 2007-05-07
| Subject: Re: My 65 split bus Tue Jan 08, 2008 6:53 pm | |
| You got a spare one? may know a man who has... Give me a bell if you need one mate.... | |
VWFRIZZ DBS Pervert
Number of posts : 704 Age : 42 Location : Bridgwater Registration date : 2006-09-27
| Subject: Re: My 65 split bus Tue Jan 08, 2008 7:11 pm | |
| Thanks mate for the offer... Think he has one sorted but if things go twits up i am sure he will buzz you.. | |
| Subject: Re: My 65 split bus Tue Jan 08, 2008 9:23 pm | |
| Cheers for the offer Mart.. But i have a couple spare kicking around.. Tis all pulled apart now and also found that when the shaft went it fooked a wheel bearing | |
| Subject: Re: My 65 split bus Wed Jan 09, 2008 8:44 pm | |
| I've changed both shafts, a new wheel bearing and new gaskets (again ) Lets hope it does leak again.. Gearbox is back in so is the engine, just need to connect the motor up, change the throttle cable and refit the rear brakes then all should be good............. Fingers crossed.... | |
| Subject: Re: My 65 split bus Wed Jan 09, 2008 9:29 pm | |
| Well done Rich, quick work fella Gave the readies to Carl tonite for ya. |
| Subject: Re: My 65 split bus Wed Jan 09, 2008 9:35 pm | |
| Cheers rick tis in the back pocket.. | |
| Subject: Re: My 65 split bus Fri Jan 11, 2008 10:25 pm | |
| All back together.. New throttle cable, modded the s/s exhaust so i can get the bumper on, finished straightening the engine lid after the silly fu(ker drove in to it.. Gearbox has new gaskets again.. Just need to throw so fuel in it so i can try the gearbox fingers crossed i done no damage to it... | |
| Subject: Re: My 65 split bus Fri Jan 11, 2008 10:41 pm | |
| Nice one dude!... That really didn't take you too long at all! | |
| Subject: Re: My 65 split bus Sat Jan 12, 2008 2:44 pm | |
| Cheers dude.. took me longer then i wanted but work is a bit busy at the mo and is just about to get alot worse... Fingers crossed i'll get down there a chuck some fuel in it and hopefully it'll be all good.. .. | |
| Subject: Re: My 65 split bus Sat Jan 12, 2008 2:48 pm | |
| Subject: Re: My 65 split bus Sat Jan 12, 2008 7:54 pm | |
| Subject: Re: My 65 split bus Sat Jan 12, 2008 8:11 pm | |
| That was a bit of a bummer then Rich. Glad you got it sorted though. You'll have to be careful now. Tho I doubt you will By the way do you have any mufflers hanging about to fit on a 1776 engined bay? |
| Subject: Re: My 65 split bus Fri Jan 18, 2008 9:05 pm | |
| Subject: Re: My 65 split bus Sat Jan 26, 2008 12:56 pm | |
| As you know i snapped another axle... But she's back on the road for a while.. The home brewed straight axle kits all BALLSED so that'll be going in the bin cos it's litter.. So is the 1500 box... The GT box is now in capable hands get rebuilt. I've gotta sort new axle straight axle kit, rear spring plates, new brakes and bearings and shot blast some long axles and paint them the gearbox may get a coat of paint as well.. Then put it all back together and see if it lasts | |
| Subject: Re: My 65 split bus Tue Jan 29, 2008 7:03 am | |
| The finish deadline for her is just under 11 weeks away now.. Swap gearboxes Rebuild rear suspension Rebuild rebrakes Restore wheels Fit front air shock Sort and fit compressor for shocks Tub front arches Build custom front seats to clear front tubs Restore the steering wheel Prep the body Paint the fooker inside and out Finish building the interior The dealine is CTTP... But would like her done for Volksworld which is about 9 weeks.. Time to get to work on her... But it's not easy when she's your daily | |
| Subject: Re: My 65 split bus Tue Jan 29, 2008 7:07 am | |
| Your confused......... You wanna be in my shoes dude...
I've had a good hard think and I'm gonna try and sort the cash elsewhere rather then selling the bus but if needs must | |
| Subject: Re: My 65 split bus | |
| My 65 split bus | |
