| My 65 split bus | |
+24Russi666 renegade67 delboy leahcar52 Big Blue Betty Shamrockez eddie gordo purple73 slammervan nomates itsabuglife soapbox VWFRIZZ Cleverchap 1584cc lowriderbug vwbeetlebum Mr Scoops Impy Mcdub ANDYLHAM dubberatlast spennyp Dirty Dave thecrewkid 28 posters |
1584cc Blitzen Regular
Number of posts : 400 Age : 56 Location : In the Sticks My Ride(s) : 1971 1300 Beetle, 1970 1302 Beetle, 1971 Deluxe Bus, 1972 1200 Beetle Registration date : 2006-12-07
| Subject: Re: My 65 split bus Sun Dec 31, 2006 6:30 pm | |
| What spec. 1914 is that? Was thinking of going for the 94mm barrels as well. | |
spennyp DBS Old Timer
Number of posts : 3184 Registration date : 2006-08-19
| Subject: Re: My 65 split bus Sun Dec 31, 2006 6:43 pm | |
| Subject: Re: My 65 split bus Sun Dec 31, 2006 6:53 pm | |
| Well i'm not total suer on the spec of the motor cos it was in the van when i got it, here's what i know.. AS41 case 94mm pistons Heads have standard valves (better torque for a bus) Ports have been ported not polished Not sure whats in the case but it's got hydraulic tappets fitted C.B Maxi full flow pump Big external cooler, soon to have electric fan fitted Deep sump Stage one Kennedy clutch 009 40mm webbers IDF's Merged header with mondo floor dragger box Thats all i know about it | |
| Subject: Re: My 65 split bus Sun Dec 31, 2006 7:01 pm | |
| Unusual to have hydraulic tappets, an american build? Not seen your bus round town yet. My missus kept seeing (and hearing) your crewcab go past where she works in Bridgwater | |
| Subject: Re: My 65 split bus Mon Jan 01, 2007 10:11 pm | |
| Subject: Re: My 65 split bus Mon Jan 01, 2007 10:13 pm | |
| did you sort your carb dude | |
| Subject: Re: My 65 split bus Mon Jan 01, 2007 10:21 pm | |
| Yes mate thats sorted as well it was open far to far so it was closing itself back up the other way, if that makes sense | |
| Subject: Re: My 65 split bus Tue Jan 02, 2007 5:34 pm | |
| Subject: Re: My 65 split bus Tue Jan 02, 2007 8:07 pm | |
| looking good.....what else you got to do on the body work?? | |
| Subject: Re: My 65 split bus Tue Jan 02, 2007 8:26 pm | |
| - spennyp wrote:
- looking good.....what else you got to do on the body work??
Well it's not to bad really a little list for you, Lower front panel is rotton. REPLACE Half height windscreen apperture rotton and hanging due to front panel being removed and refitted VERY badly. REPLACE N/S 'B' pillar inner and outer rotton. REPLACE O/S outer sill dented badly. REPAIR/REPLACE Slight twist in one rear wheel arch. REPAIR Complete N/S upper quarter panel due to windows being cut in to it. REPLACE And a couple other little repairs I think that is about it i think.. The rear quarter prob wont get done till the winter in the workshop. But all the others should be done before Volksworld.. | |
| Subject: Re: My 65 split bus Tue Jan 02, 2007 8:32 pm | |
| The repair panels for the front will be from Autocraft so should be good | |
| Subject: Re: My 65 split bus Tue Jan 02, 2007 8:38 pm | |
| is the Autocraft stuff any good?? shame they dont do bug stuff......seems you splitty owners have a few good places to get panels from.....that list seems enourmous to me....but then again i dont have much of a clue when it comes to panels | |
| Subject: Re: My 65 split bus Tue Jan 02, 2007 8:50 pm | |
| Well it's ment to be the pretty much the best stuff on the market but then i've never used them... The list isn't that bad really it should take a couple of good weekends to do, not including the upper rear panel | |
| Subject: Re: My 65 split bus Tue Jan 02, 2007 8:52 pm | |
| They do do bug panels well 2 "rear 'H' panels" http://www.autocraft2004.co.uk/index.htm | |
| Subject: Re: My 65 split bus Sat Jan 13, 2007 3:04 pm | |
| Well as i got fu#ked about on the sale i'm gonna get the thing sorted and stop pi$$ing about.. Here we go................. So there is a brand new CB performace 4"narrowed adjustable beam on it's way to me which means the front will go a little lower. Roll her over on her side and paint the underside. Also gonna raise the steering box at the same time for serious ground clearance. Build a new wiring loom. Swap the engines and gearboxes over again. Rebuild the carbs Make a bug turbo trip exhaust fit. Fit the larger bay window fuel tank. Repair front panel top and bottom. Repair the cab floor. Xbox and dvd player for the kids (honest) Paint it grey with sign writing Fit my new interior when i get it. That'll do for now | |
| Subject: Re: My 65 split bus Sat Jan 13, 2007 3:37 pm | |
| No way, what happened bud? | |
Cleverchap DBS Pervert
Number of posts : 895 Age : 48 Location : ɹǝpun uʍop My Ride(s) : '65 split with a difference Registration date : 2007-01-08
| Subject: Re: My 65 split bus Sat Jan 13, 2007 4:18 pm | |
| Rich, sorry to here the sale fell through. On the plus side I have used Autocraft panels on my bus and they are proper high quality stuff that doesn't need alterations to make them fit unlike other panel suppliers. Hope it all works out in the end | |
| Subject: Re: My 65 split bus Sat Jan 13, 2007 5:04 pm | |
| Thats cool rich....you'll have the van looking sweet in no time......looked great when you popped over it will look awesome when its done | |
| Subject: Re: My 65 split bus Sat Jan 13, 2007 5:10 pm | |
| Cheers buddy.. The van doesn't do it for me BUT i'm gonna make it do it for me watch this space | |
| Subject: Re: My 65 split bus Sat Jan 13, 2007 5:26 pm | |
| We've just had a chat a i reakon i've got 12 full days of work to do on it to get it finished | |
| Subject: Re: My 65 split bus Sat Jan 13, 2007 9:47 pm | |
| Good luck dude. Get the cam-corder out, get Frizz to record you and sell it to discovery. Panel Van Crisis!! And then give me 10% of the fee for coming up with the concept!! | |
| Subject: Re: My 65 split bus Sat Jan 13, 2007 10:04 pm | |
| - thecrewkid wrote:
- Cheers buddy..
The van doesn't do it for me BUT i'm gonna make it do it for me watch this space But it definately does it for me, so keep me in mind next time you have a mad five minutes and want to sell it (after you have done all the cool stuff to it of course!) That is of course if I have any money, you know how it is |
| Subject: Re: My 65 split bus Sat Jan 13, 2007 10:18 pm | |
| Cheers Harv.. CARL i'm gonna need a hand one evening through the week to get this thing rolled over on to it's side if your available dude. | |
| Subject: Re: My 65 split bus | |
| My 65 split bus | |
