| Ella - The 1985 Mexican Bandit | |
+24Shorty ANDYLHAM griff vietnam Road Rage clockwork Shamrockez vwbeetlebum MrsWizBiz Cleverchap HRD Bmtt4 SimonABT uselescrapytwit thecrewkid dubberatlast joker 67 ProjectParsons tango_van big dave nomates Gungemyster Mr Scoops WizBizMartin 28 posters |
MrsWizBiz Blitzen Regular
Number of posts : 191 Age : 31 Location : Weston super mare My Ride(s) : Bella bug - newbie beetle Registration date : 2011-01-18
| Subject: Re: Ella - The 1985 Mexican Bandit Sat May 14, 2011 5:53 pm | |
| Possibly? Im not sure.. He just keeps telling me that it doesn't fit.. On the other hand, finished the other half of the floor today all painted with special stuff so ready to be carpeted | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat May 14, 2011 6:49 pm | |
| I have no idea ,but i wonder if the new g box needs a modified or special cradle | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat May 14, 2011 6:51 pm | |
| it just needs a bigger hammer | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat May 14, 2011 7:13 pm | |
| currently it all fits in but the rocker covers seem really close to the inner wing bits , one side is ok like for clearence but the other side is closer, kinda hard to measure up but the engine is standard width 69mm crank so i know its standard size on the outside, one side you can fit a S/S scat rocker cover , the other side you cant as it hits the body :C, i have checked and the gearbox cradle at the rear the bigger on which bolts to the frame horns is exactly the same a stock size so its def o not that mount, the only thing i can think is i have this adapter plate on the front gearbox mount which consist of a 2 bolt rhino mount which is bloted to this adapter. originaly the car came with this mount as standard which bolts horizontal to the floorpan with me trying to up rate everything i want a rhino mount as you can see this is for early style floor pan i think IIRC ?? well any way found this adapter thing which i think is doing the job of allowing me to use the rhino mount this bolts to the floorpan then the rhino mount to the adapter, im not using the poly red mount in the pic as the rhino mount is in its place | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat May 14, 2011 7:19 pm | |
| the gearbox is a rhino case and from what i understand this is a standard type gearbox size just stonger
| Subject: Re: Ella - The 1985 Mexican Bandit Fri Jun 10, 2011 10:15 pm | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Jun 11, 2011 10:39 am | |
| looking good mate. just a few more hours to go then and it'll be ready | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Jun 11, 2011 10:43 am | |
| Good work Wizbiz, I shall have to pop round and have another nosey!!.
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Jun 11, 2011 5:46 pm | |
| Please can you get this thing finished so i can see it? Looks ace!! Gonna look ard' as fook on those rims. | |
| Subject: Re: Ella - The 1985 Mexican Bandit Fri Jun 17, 2011 8:36 pm | |
| Wizpop. You sort those surface rust bits out and get that paint on ready for re-fitting the engine and gearbox in the morning? Lets get this badboy back on the road soon! | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Jun 18, 2011 2:26 pm | |
| yeah .....get on with it skinny !! | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Jun 18, 2011 3:40 pm | |
| he was not going to be ready at 8am ..... and no paint on the rust treatment areas, instead he'd "watched a film" with mrs wizbang last night. so I rang him at 7:45am to wake him, and work commenced at 8:45am... lazy git! done today: rust areas done, zinced/red oxied...(apart from the airbox drain hole) Gloss black top coated them. Fuel tank, sender, filler and breather in and done. and wizpop got all wet Z-bar in, greased up bushes and fitted. gearbox mount front spacer painted and fitted. gearbox rear mount painted and fitted. gearbox fitted - needs adjustment when engine in. nearside new lowered spring plate fitted, with new poly bushes. thanks to iPhone level and angle meter in one driveshafts attached and rear end built up: shocks, z-bar, bump stops and discs attached both sides. wheels on both sides and axle nuts torqued up. bug then rolled out into the sun all done by 1pm. so all you gotta do now is: paint inner wings, paint front drain hole Fit engine, fit fuel filter and pressure regulator. bolt on carbs. sort out breather position center gearbox. fit exhaust. run wiring for engine. Fit rear valance and wings. fit front seats and seat belts build up callipers and get brake bias kit. fit these and bleed brake system fit battery. sort out front wiring and dash, wipers ready for glass fit lights all round. get tyres on those porka wheels: check clearance on front wings (or just sent it in on the ATS set) get it to the MOT!!! and tracking sorted. then get Matrim to sort inner door paint, fuel filer cap paint, then he can fit headliner and fit glass all round. then: interior: carpet, stereo system, gauges, door cards, sort out electrics to the seats. | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Jun 18, 2011 3:55 pm | |
| Then we can sort out a photoshoot for Ultra VW!!
So leave Mrs Wiz Pop alone and crack on!! | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Jun 18, 2011 4:30 pm | |
| yeah i'll look after mrs wizpop for ya dude .........now crack on
P.S tango van ...........after you finished with wizpop ....fancy building a frid? ......lol | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Jun 18, 2011 4:33 pm | |
| nomates... only if you put a big motor in it wizpop - same time tomoz then! so then engine in etc... and I'll bring the bus around to get you motivated. | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Jun 18, 2011 4:41 pm | |
| Mate I'm on the case ......only about another grand on engine bits .....plus I'm toyingwith red 9 designed front wishbone suspention .....I think dan (lowrider bug ) mentioned here was a rear set up now too | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Jun 18, 2011 4:43 pm | |
| One thing .......how / why does the gearbox need centering? are the new mounts adjustable? .......and would it be easier to do this before the motor goes in dude? | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Jun 18, 2011 4:50 pm | |
| he's had to adjust the mounts with some spacers. there's not much play to be fair, just wanna make sure it all sits square etc. will measure and check it before engine is in.
He's not far off really. just the change of wheels and pattern will mean new discs and xdrilling etc, as well as working out the tyre size. | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Jun 18, 2011 4:56 pm | |
| just the front wheel wing assue to | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Jun 18, 2011 4:57 pm | |
| thanks for help today rich notmates do you mean the kit which replaces the whole front beam or just the coilovers with rods that go through beam | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Jun 18, 2011 5:03 pm | |
| the whole kit ,full wish bone ..............any good? | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Jun 18, 2011 5:07 pm | |
| dunno im running the coilovers kit with the bars that go in the beam had it since red9desging started making them, no complaints at all, car used to drive like it was on rails ! , im guessing the whole front end will be evan better, !!
| the whole front end kit cost about 1 k though !!! | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Jun 18, 2011 5:08 pm | |
| 1300 actually ...................LOL | |
| Subject: Re: Ella - The 1985 Mexican Bandit | |
