| Ella - The 1985 Mexican Bandit | |
+24Shorty ANDYLHAM griff vietnam Road Rage clockwork Shamrockez vwbeetlebum MrsWizBiz Cleverchap HRD Bmtt4 SimonABT uselescrapytwit thecrewkid dubberatlast joker 67 ProjectParsons tango_van big dave nomates Gungemyster Mr Scoops WizBizMartin 28 posters |
| Subject: Re: Ella - The 1985 Mexican Bandit Tue Aug 31, 2010 4:02 pm | |
| got some driveshafts today no car to fit them to lol
Last edited by WizBizMartin on Fri Sep 24, 2010 12:55 am; edited 1 time in total | |
Cleverchap DBS Pervert
Number of posts : 895 Age : 48 Location : ɹǝpun uʍop My Ride(s) : '65 split with a difference Registration date : 2007-01-08
| Subject: Re: Ella - The 1985 Mexican Bandit Wed Sep 01, 2010 6:33 am | |
| They look like race axels to me | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sun Sep 19, 2010 11:51 am | |
| Subject: Re: Ella - The 1985 Mexican Bandit Wed Sep 22, 2010 2:25 pm | |
| coming on then... | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sun Nov 14, 2010 8:11 pm | |
| best update this then , gearbox prepped up , gearbox painted in some high temp engine enamel engine has a tiny leak coming from oil pump area , turned out to be the seal between the pump and case . | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Nov 20, 2010 10:38 pm | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sun Nov 21, 2010 11:30 pm | |
| Nice to see it back! Get cracking on with it and it'll be ready for the new year | |
| Subject: Re: Ella - The 1985 Mexican Bandit Fri Nov 26, 2010 11:27 pm | |
| beam stripped and roller bearings taken out of the ends , was a pig of a job getting them out gunna replace with some poly ones , beam removed ready for clean up and paint , ball joints are ruined aswell only put new ones on in 2009 but must have been cus i had the coilovers wound all the way down , long travel i think for future, | |
| Subject: Re: Ella - The 1985 Mexican Bandit Thu Dec 30, 2010 3:38 am | |
| havent updated in while :/ , beam has been painted as well as torsion arms, new long travel balljoints fitted (cheers Big Dave) Caster Shims on beam, poly bushes on beam new brake lines from MC to callipers and braided hoses, new steering box, new tie rod ends as they were shot to ! pooped some CB dropped spindles which drop it 2.5 " and the coilovers on the highest setting lower it 2 " so currently sitting at 4.5 " dropped on the front , will proberly leave as this as the beam sits bout 9-10cms off the ground as theres no weight in the car yet and i wanna be able to use the car , could drop another 2" if i wind the coilovers down ;P cleaned up the koni steering damper too ! thats it for the front , oh and plenty of copper grease think thats it ! tomorrows plans are start to fit some interior bits back in or put the engine back together | |
| Subject: Re: Ella - The 1985 Mexican Bandit Thu Dec 30, 2010 9:42 am | |
| Nice one Martin, loving the progress.
Ps I might go for that Nurse job advertised in the paper!! lol | |
| Subject: Re: Ella - The 1985 Mexican Bandit Thu Dec 30, 2010 4:39 pm | |
| Looking really smart mate. Makes so much difference when things are cleaned and painted when re-assembled. | |
| Subject: Re: Ella - The 1985 Mexican Bandit Thu Dec 30, 2010 6:19 pm | |
| good to see you back on it ......but dude ,you need a camera with auto focus ...lol | |
MrsWizBiz Blitzen Regular
Number of posts : 191 Age : 31 Location : Weston super mare My Ride(s) : Bella bug - newbie beetle Registration date : 2011-01-18
| Subject: Re: Ella - The 1985 Mexican Bandit Thu Jan 20, 2011 11:02 pm | |
| Hurry up and get her finished please x shotgun first passenger xx | |
| Subject: Re: Ella - The 1985 Mexican Bandit Mon Jan 31, 2011 5:45 pm | |
| Subject: Re: Ella - The 1985 Mexican Bandit Tue Feb 01, 2011 12:27 pm | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Feb 12, 2011 7:36 pm | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Feb 12, 2011 7:49 pm | |
| ah, this brings back memories of those evil circlips! | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Feb 12, 2011 7:56 pm | |
| i spent an hour trying to take one out without damaging them then thought i have another 3 to remove ! and them i gotta refit them ! after that i ended up geting an old pare of pliers and notching them about 2-3 mm inn from the top of the plier , i then found they held the circlip much better and it did'nt snap out, will get a pic tommoz, , i can get em in and out 100% in about 2 mins a side , doddle now ! actaully scrap that im just gunna start my own tool range ! | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sat Feb 12, 2011 7:57 pm | |
| yep ....I do the same ......grind down some thin nosed pliers | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sun Feb 13, 2011 2:54 pm | |
| circlips are a pig of a job without the right tool.
looking good mate, nice and clean new bits! | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sun Feb 13, 2011 4:56 pm | |
| did you sort the tight axle problem? | |
| Subject: Re: Ella - The 1985 Mexican Bandit Sun Feb 13, 2011 6:36 pm | |
- did you sort the tight axle problem?
Correction!! he said stiff!! | |
| Subject: Re: Ella - The 1985 Mexican Bandit Thu Feb 17, 2011 7:22 pm | |
| ye sorry sorted the tight axle problem, the fooker i bought the driveshafts on VZI didnt mention he had been playing about with the end that go into the gearbox, it looked like ever so slightly he machined one side of the spade bit down after comparing to the old driveshafts, dont know why but it stop travel and made them stuck, so ended up buying some new HD ones, i want HD axles just so i know the rear end is sorted and stronger , fitted new HD axles and all fine , went out today to look for some gaskets , ended up not finding them but started to fit one sides axle tube up , just needs a bearing and axle boot, would do other side but ran out of the hexagon axle tub gaskets got this little toy too just need to source a t4 cooler then ill bosh this on | |
| Subject: Re: Ella - The 1985 Mexican Bandit Thu Feb 17, 2011 7:53 pm | |
| nice dtm housing, did you get from jake rabey in the states?
andy | |
| Subject: Re: Ella - The 1985 Mexican Bandit | |
