 The 64 crew cab.. EVA..
7 posters
The 64 crew cab.. EVA.. Empty
PostSubject: The 64 crew cab.. EVA..   The 64 crew cab.. EVA.. EmptySun Feb 01, 2009 11:11 am
Heres my old 1964 Splitscreen crewcab these first pics are al i saw of her before i paid £4000 for here over the phone.. She was ment to turn up all welded, running MOTed and on the road but i got screwed over big time.. She turned up like this with a engine on the bed and a load of panels inside so i was p1ssed to say the least.. I went made on them and they agreed to give my money back and collect it from me.. BUT she was the only crewcab for at the time so i kept her and dealt with it..
The 64 crew cab.. EVA.. P11904140015
The 64 crew cab.. EVA.. 65crewcabtexas3
The 64 crew cab.. EVA.. 61kombiand65crewcab2
The 64 crew cab.. EVA.. P11904130014
The 64 crew cab.. EVA.. P11904120013
The 64 crew cab.. EVA.. P11904090012
I sat about just getting her solid and on the road..
But the first thing was a lowered front beam which was just cut and turned and wasn't low enough... see...
The 64 crew cab.. EVA.. DCP_2006
So i got hold of a adjustable beam and chuckked that in.. A bit better..
She also came with NO dropsides or rear gate... As you may know split crewca drop sides AREN'T cheap so i found a good complete set of bay single cab gates then set about cutting them up shortening them to suit the crew cab..
The 64 crew cab.. EVA.. DCP_2038
The complete cab floor was kackered so i got a OG floor cut from another van and i replaced that.. So was both outer sills..
The rear inner floor was rotten so that was cut out and i had so sheet metal cut and folded to suit and welded that in..
The lower front panel was also replaced at the same time..
Bit of body prep and some primer to the front half. And a set of white BRM's 4.5's on 145/65's and 5.5's on 195/65's were added.
[The 64 crew cab.. EVA.. DCP_2160
The 64 crew cab.. EVA.. DCP_2159
The O/S rear corner/quarter had taken a big impact and was to far gone for repair, crewcab rear corners are a totally different shape and profile to split buses so i searched and searched for one but couldn't find one GOOD one... I could only find 3 shagged ones so i got them and cut them about welded them in place to make one good one, i also had to jack the chassis leg out straight to get the engine lid in to shut..
The rear quarter was really badly warped so that got heated up and body jacked from the inside and a nuts load of panel beating to the quarter and corner.
The 64 crew cab.. EVA.. DCP_2163
The 64 crew cab.. EVA.. DCP_2221
The 64 crew cab.. EVA.. DCP_2220
The 64 crew cab.. EVA.. DCP_2218
The 64 crew cab.. EVA.. DCP_2215
The 64 crew cab.. EVA.. DCP_2232
The 64 crew cab.. EVA.. DCP_2231
The 64 crew cab.. EVA.. DCP_2242
The seats were a bit worse for wear so i got them retrimmed in Cream with brown piping..
The 64 crew cab.. EVA.. DCP_2179
The 64 crew cab.. EVA.. DCP_2175
The 64 crew cab.. EVA.. DCP_2201
The 64 crew cab.. EVA.. DCP_2200
The 64 crew cab.. EVA.. DCP_2197
The 64 crew cab.. EVA.. DCP_2199
I had to drive her to Exeter to get her inspected once she passed the MOT so i put her in primer..
The 64 crew cab.. EVA.. DCP_2203
The 64 crew cab.. EVA.. DCP_2202
I didn't like the stock rear running gear so i straight axled her using a GT box ect also rebuilt all the brakes, lines, master cylinder and cables.
The 64 crew cab.. EVA.. DCP_2238
The 64 crew cab.. EVA.. DCP_2237
Frizz got me a set of Chrome Radars with 175/50's ad 195/65's, and a set of rebuilt flipped dropped spindle's with new K+L pins..
The 64 crew cab.. EVA.. Radars1
The 64 crew cab.. EVA.. Spi2
Insides all painted then carpeted
The 64 crew cab.. EVA.. Insidefront
The 64 crew cab.. EVA.. Insiderear
The 64 crew cab.. EVA.. Insidecarpet2
The 64 crew cab.. EVA.. Insidecarpet1
I then had to flip her on her side to raise the steering box, and a couple little repairs to the inner sills and paint the whole underneath in chassis black..
The 64 crew cab.. EVA.. Thefloor2
The 64 crew cab.. EVA.. Steerpaint
The 64 crew cab.. EVA.. Steerupdate2
The 64 crew cab.. EVA.. Steering1
The 64 crew cab.. EVA.. Ouit3
The 64 crew cab.. EVA.. Veiw
The 64 crew cab.. EVA.. 15
The 64 crew cab.. EVA.. 12
And a 4" narrowed adjustable beam was called for aswell..
The 64 crew cab.. EVA.. Narrowed
Then time came to get her in paint Brown and Beige..
Primed
The 64 crew cab.. EVA.. Comeon8
Then guild coated and then flatted back nice and smooth..
The 64 crew cab.. EVA.. Comeon15
The top painted Beige.
The 64 crew cab.. EVA.. Ssdsdsdds13
Then started the bottom in Brown.
The 64 crew cab.. EVA.. Ssdsdsdds17
The 64 crew cab.. EVA.. Ssdsdsdds20
All painted.
The 64 crew cab.. EVA.. Sdsdsddddddddddd2
The 64 crew cab.. EVA.. Sdsdsddddddddddd1
Going back together
The 64 crew cab.. EVA.. Lightbadge1
All finished and a nice trip to Newquay was called for..
The 64 crew cab.. EVA.. STA60015
The 64 crew cab.. EVA.. STA60014
The 64 crew cab.. EVA.. Dfdfdfdfd
A few more pics as she is now...
The 64 crew cab.. EVA.. Dfdfdfdfd2
The 64 crew cab.. EVA.. Dfdfdfdfd3
The 64 crew cab.. EVA.. Dfdfdfdfd4
The 64 crew cab.. EVA.. Dfdfdfdfd5
The 64 crew cab.. EVA.. Dfdfdfdfd6
The 64 crew cab.. EVA.. Dfdfdfdfd7
Full spec list...
Full respray in Rattan beige and Russet brown.
Re-upholstered seats and re-trimmed interior panels and floor.
New 3 bow roof rack.
Chevvy roof light.
New window and door rubbers all round.
New polished alloy rear pop outs.
Near mint pair of door tops with new seals.
Set of chrome radars and tyres.
VDO oil pressure, oil temperature, cylinder head temperature guages with senders and rev counter fitted.
72 row external oil cooler with electric fan, filter head, thermostatic switch, CB performance high pressure oil pump with inlets and outlets for the cooler and filter and all the hardware needed.
Turbo trip exhaust wrapped in exhaust wrap.
Chassis painted black.
Raised the steering box.
Lowered front and rear. Straight axled. Drop spindles with new king and link pins.
Rebuilt 4" narrowed front beam.
Tubbed aches.
Front and rear brakes have been rebuilt. New drums, wheel cylinders, shoes, adjusters, flexi and solid pipes and all hardware. New master cylinder and bottle.
New wiring loom.
New 1600 heads, pistons and barrels, new clutch, new alternator, new carb, fuel pump, 009 dizzy and has had a full service and tappets and tune done.
Suspension and steering has been rebuilt.
Beetle GT gearbox.
Variable speed wipers.
EMPI trigger shifter.
6 red seatbelts with wolfsberg crest on them.
US spec lights.
PostSubject: Re: The 64 crew cab.. EVA..   The 64 crew cab.. EVA.. EmptySun Feb 01, 2009 11:27 am
Amazing dude, how much did it all set you back in the end?? Or does it still hurt to think about it!!
PostSubject: Re: The 64 crew cab.. EVA..   The 64 crew cab.. EVA.. EmptySun Feb 01, 2009 11:38 am
Cheers dude we did love the old girl.. We still don't really talk about the finally cost but gotta be close to 10k...
Just so glad i done it all myself and didn't need to pay someone else to do it Cool Cool
PostSubject: Re: The 64 crew cab.. EVA..   The 64 crew cab.. EVA.. EmptySun Feb 01, 2009 1:15 pm
Its amazing the amount of work that goes into a project like this ....the pics tell a story of the basic build ......but its difficult to appreciate all the different problems you need to overcome .....fairplay to you its looks fantastic
PostSubject: Re: The 64 crew cab.. EVA..   The 64 crew cab.. EVA.. EmptySun Feb 01, 2009 4:27 pm
Cheers Steve.. The pics/words just don't show the amount of grief you go through.. lol! lol!
The only true way to understand is to get in and do it yourself.. Twisted Evil Twisted Evil
PostSubject: Re: The 64 crew cab.. EVA..   The 64 crew cab.. EVA.. EmptySun Feb 01, 2009 5:30 pm
Adge just called me down to see this post. We are just both gobsmacked how much work and time has gone into the truck. Amazing work.
PostSubject: Re: The 64 crew cab.. EVA..   The 64 crew cab.. EVA.. EmptySun Feb 01, 2009 5:37 pm
I miss Eva the cake Crying or Very sad
PostSubject: Re: The 64 crew cab.. EVA..   The 64 crew cab.. EVA.. EmptySun Feb 01, 2009 5:45 pm
Cheers chaps..
I knew you were gonna say that Lucy... lol! lol!
PostSubject: Re: The 64 crew cab.. EVA..   The 64 crew cab.. EVA.. EmptySun Feb 01, 2009 5:58 pm
but it's true! She looked so... delicious! Very Happy
PostSubject: Re: The 64 crew cab.. EVA..   The 64 crew cab.. EVA.. EmptySun Feb 01, 2009 7:09 pm
When i get my crewy fancy another go Very Happy
PostSubject: Re: The 64 crew cab.. EVA..   The 64 crew cab.. EVA.. EmptySun Feb 01, 2009 9:47 pm
I know I said this on another thread, but I loved this crewie dude..........fair play.
PostSubject: Re: The 64 crew cab.. EVA..   The 64 crew cab.. EVA.. EmptySun Feb 01, 2009 10:21 pm
Tis a very cool lookin bus dude... What's even more impressive is that you built it on your drive! As always, top job. afro Twisted Evil afro
