 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!
11 posters
Go to page : Previous  1, 2
1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 Empty
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptyTue Sep 02, 2008 6:18 pm
Mini Update...
Today I replaced the fuel lines in the engine bay, the carb/fuel pump one was perished to buggery but of the cloth braided type so wasn't instantly noticable, was a little damp anyhows...
Couldn't get any 5.5mm line locally so squeezed some 5mm on with proper clips, the one from the hard line through the chassis had no clip at all!!!
I will replace the one under the fuel tank when I have a bit more time, and bung a filter underneath while im there as they are better there than in the engine, less electrical things to leak on!!!
I connected the air filter up correctly with some vacuum hose, as there was none attached.
I reconnected and set up the auto-choke, which had been previously disconnected, as I don't think my neighbours have appreciated my 5 minutes of throttle blipping early in the mornings so far, works a treat, comes off quickly enough and runs a lot smoother, if a little fast, but that will be adjusted after I've done the plugs/valves and that.
Greased the front beam, not sure if it had been done recently, but it has now.
No pictures, but if I don't write things down as I do them I'll forget I have, and I want to keep a record of everything I've done so I keep on track!!! Very Happy
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptyWed Sep 03, 2008 5:54 pm
Mini update, nothing exciting im afraid...
Today I changed the Plugs, Leads, Oil, Oil Strainer, Fanbelt, Airfilter. Very Happy
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptyWed Sep 03, 2008 6:04 pm
cracking on with this little fella quite quickly aren't you dude!
pics pics pics...
you know the score!
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptyWed Sep 03, 2008 6:30 pm
Thought it best to nail the important stuff before I go spunk my budget on shiney bits, its not gonna be a daily driver, but it will be used a fair bit, I usually kill cars within a month of buying them, so these are preventative measures!!!
It could do with some new studs putting in the oil strain cover, a couple have been over tightened in the past and wouldn't do up really, and one was replaced with a small bolt, but there are no leaks as yet, only spanked it round the block though. Old fanbelt was really loose too, so happier now i know its done.
Got a few more little bits and bobs to do this week before the fun stuff can begin.
I'll take the digi cam to work tomorrow, I meant to take some of the underside the other night, its REALLY bloody clean by my standards! Makes up for the topside haha!
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptyThu Sep 04, 2008 4:36 pm
Mmmm fresh gearbox oil today, smells good too. No pics!!!
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptyMon Sep 08, 2008 7:46 pm
Some gimps decided it might be cool to rip the aerial off the n/s/f quarter leaving two holes where it was attached and remove my wingmirror and lob it on Friday night just gone, then commando slide across the bonnet from the looks of it Mad
Mirror was salvaged, but i now have 3 ugly holes and no frikkin aerial. I know its not exactly a showcar, but its not the point, Ive been drunk and I've never trashed someones ride Rolling Eyes
Did recieve the other key in the post, joy! Cheers Rich if you read this...
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptyMon Sep 08, 2008 8:25 pm
Dude that sucks big time
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptyMon Sep 08, 2008 8:29 pm
it DOES suck... Is the bonnet salvagable?
Think Rich had one for sale?
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptyMon Sep 08, 2008 8:38 pm
Yeah its just scratched/twisted on the hinges a little, doesnt look straight, I'll give it a good polish, luckily its just rattlecanned anyway so could always make it white I guess!!!
Burnham is yob central at the moment, no one gives a crap.
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptyMon Sep 08, 2008 8:46 pm
Scumbags.
I would get a replacement of Rich but in the mean time give yours a good thick coat of that vandle-proof paint that doesn't dry and will screw their best market Burberry gear up!!!
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptyMon Sep 08, 2008 9:51 pm
because he'd wake up to a ton of scrap where he'd parked his beetle. I've had a few recent nights out in 'nham and its a bit rough nowadays...
Rent a garage buddy, there's bound to be one fairly locally?
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptyTue Sep 09, 2008 2:44 pm
Rich here, I've been watching DBS from afar! >Very Happy
Sucks to hear about the aerial & bonnet, those bastards D: If the hinges are bent too then I can post the ones I have knocking about if needs be :3
Good to hear you got the key, sorry it took a little while <3
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptySat Sep 20, 2008 12:06 pm
Had a quiet morning at work, so managed to fit new aerial, back to standard one now, also now got a lockable decklid catch, done valve clearances/new gaskets, fitted new points, condensor, rotor arm and dissy cap.
Turned the idle down a bit, didn't mess with the mixture/timing, Im gonna let Parse Snr do a proper tune as he has all the gas analysers/timing lights and shit, and as its a 77, I don't think its exempt from emissions testing.
Took all wheels off and gave inner wings a good blast, found one small bit of grot the size of a 50p on the N/S/R, so quite happy with that.
Thats about it as far as getting things up together servicable items wise that I can think of, Im going to adjust the brakes as its snatching a bit after being stood for a couple days, thinking maybe a small leak onto the shoes on one side at the front, after a couple breaks its ok after they've cleaned up a bit.
So now its onto tidying up the cosmetic sides of things and getting it looking more how I'd like it too, the fun stuff, so should be more pictures!
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptyWed Sep 24, 2008 4:50 pm
The Fan Blower in my Air Box under the Bonnet fresh air grill is now fully functioning with 2 speeds!!!
Bring on the heater cables, Im gonna be toasty!!!
Should be coming from heritage tomorrow along with the correct winder mech for driver's door, cheers BigAl for the one you gave me but its pretty different to mine and I could see no way to make it fit!
Male Number of posts : 3616
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptyWed Sep 24, 2008 7:31 pm
No worries man, anyways, with a bit of butchery, anthing can fit! What a Face
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptyWed Sep 24, 2008 10:23 pm
Sounds like your coming on nicely there Gary next time Rick and I are in the area if your about we will have pop round and have a butchers dude.
purple73
purple73
Female Number of posts : 731
Registration date : 2007-01-05
PostSubject: Re: 1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!!   1977 1200 BEETLE - STIG2 - THE RUST STRIKES BACK!!! - Page 2 EmptyThu Sep 25, 2008 9:57 am
That is soo annoying!! sorry to hear what the vandals have done!
Page 2 of 2Go to page : Previous  1, 2
» 71 1200 Beetle
» My first Beetle
» My 1959 Beetle
» My first beetle Stella...
» Bella - 1958 Australian Beetle
