| scooby powered bay. | |
+18tango_van griff delboy Gungemyster lowriderbug Cleverchap soapbox ProjectParsons nomates Impy Mcdub itsabuglife SimonABT Wurz vwbeetlebum Mr Scoops thecrewkid dubberatlast slammervan 22 posters |
Number of posts : 8406 Age : 43 Location : Bridgwater My Ride(s) : '04 LWB T5.. Restored escort RS turbo estate. Registration date : 2006-08-30
| Subject: Re: scooby powered bay. Thu Aug 28, 2008 6:01 pm | |
slammervan a.k.a High Top Kid
Number of posts : 696 Age : 36 Location : The Hood Of Yatton My Ride(s) : subaru powered baywindow Registration date : 2006-09-30
| Subject: Re: scooby powered bay. Sun Aug 31, 2008 4:57 pm | |
soapbox DBS Old Timer
Number of posts : 1033 Age : 39 Location : Clevedon My Ride(s) : '73 subaru powered Type 2 and a '75 beetle hot rod Registration date : 2006-12-19
| Subject: Re: scooby powered bay. Sun Aug 31, 2008 5:07 pm | |
| Dude looking good....very jealous!! | |
| Subject: Re: scooby powered bay. Sun Aug 31, 2008 8:28 pm | |
| jamo like i said at the meet mate, big respect.... awesome. | |
| Subject: Re: scooby powered bay. Sun Aug 31, 2008 9:14 pm | |
| Looking good, BUT, I don't think that air scoop for the rad would last the first day of you being on the road......it's too low. You need to relocate it higher up Buddy. | |
| Subject: Re: scooby powered bay. Sun Aug 31, 2008 9:20 pm | |
| Sh1t dude i don't reckon it'll even make it to the road once the engine ect are all fitted and the suspension settles back down... Are you sure it can be spun round and mounted between the chassis rails?? | |
| Subject: Re: scooby powered bay. Sun Aug 31, 2008 9:43 pm | |
| - thecrewkid wrote:
- Sh1t dude i don't reckon it'll even make it to the road once the engine ect are all fitted and the suspension settles back down... Are you sure it can be spun round and mounted between the chassis rails??
Love your work....but agree with the kid ^^^^ WHS | |
| Subject: Re: scooby powered bay. Sun Aug 31, 2008 10:11 pm | |
| sorry mate, but i also think the same as them 3 but didnt wana say anything in my earlier post as I know your adamant you want it there.... hmm... | |
| Subject: Re: scooby powered bay. Mon Sep 01, 2008 7:31 am | |
| It wont fit in between the chassis rails because its not the size of the rad thats the prob, its the fans behind it that sit it that low. Jammo, the other options would be use slim line fans, or try and mount two smaller radiators somewhere?! Gonna be tricky to get over the problem but things are never easy! | |
| Subject: Re: scooby powered bay. Mon Sep 01, 2008 8:24 am | |
| strap them to the front with zip ties.... they're the way forward y'know | |
| Subject: Re: scooby powered bay. Mon Sep 01, 2008 6:39 pm | |
| Subject: Re: scooby powered bay. Mon Sep 01, 2008 8:25 pm | |
| Good job nerd! Where did you get the air filter and silicones from in the end? | |
| Subject: Re: scooby powered bay. Mon Sep 01, 2008 9:08 pm | |
| chav parts weston, i mean motor parts weston. cost me a arm and a leg. | |
| Subject: Re: scooby powered bay. Tue Sep 02, 2008 5:57 am | |
| Nice work mate, you are really cracking on with this transplant. Looking forward to seeing it running fella. | |
| Subject: Re: scooby powered bay. Tue Sep 02, 2008 7:05 am | |
| Just tried ringing you dude, me and dad have got to out to look at a job in clevedon later so when we get back (8ish?!) we will pop over and see your mounts. Dad says he will jus use your Arc Welder if thats ok cuz his MIG is buried. Give me a call later if your not gonna be around at 8ish. | |
| Subject: Re: scooby powered bay. Tue Sep 02, 2008 6:40 pm | |
| Subject: Re: scooby powered bay. Tue Sep 02, 2008 8:40 pm | |
| Subject: Re: scooby powered bay. Wed Sep 03, 2008 11:56 pm | |
| cam belt done. need to get si dad to weld mount in place(dont trust myself) buy some more rad hose and breather hose fit engine, wire engine get engine running then rase van a spline | |
| Subject: Re: scooby powered bay. Thu Sep 04, 2008 6:40 pm | |
| Subject: Re: scooby powered bay. Fri Sep 05, 2008 4:24 pm | |
| nasty bit of wiring ther jamo, good luck | |
| Subject: Re: scooby powered bay. Sat Sep 06, 2008 7:56 pm | |
| what i had to do the wiring in the other day.... thanks to si's dad, my mount ant going anywhere!!! next thing to do is fit engine connect wire's finish lambda sensor plumb engine then tickdy boom vom voom. tuesday should be the day 4 days behind estimate. | |
| Subject: Re: scooby powered bay. Sat Sep 06, 2008 8:39 pm | |
| excellent work dude you'll have take me out for a spin when finished dude |
| Subject: Re: scooby powered bay. Sat Sep 06, 2008 9:12 pm | |
| the mount itself looks strong , and the weld is perfect ...........but what its welded to looks a bit suss .....what is it welded too ?...looks like an inner wing ? | |
Cleverchap DBS Pervert
Number of posts : 895 Age : 48 Location : ɹǝpun uʍop My Ride(s) : '65 split with a difference Registration date : 2007-01-08
| Subject: Re: scooby powered bay. Sat Sep 06, 2008 9:32 pm | |
| Dude that is looking sweet. I wish my van was finished so quickly | |
| Subject: Re: scooby powered bay. Sat Sep 06, 2008 9:37 pm | |
- the mount itself looks strong , and the weld is perfect ...........but what its welded to looks a bit suss .....what is it welded too ?...looks like an inner wing ?
Rear chassis legs by the looks Nice work bud you dont hang about | |
| Subject: Re: scooby powered bay. | |
