 The Notch.......
Go to page : 1, 2, 3, 4, 5, 6, 7  Next
The Notch....... Empty
PostSubject: The Notch.......   The Notch....... EmptyTue Aug 05, 2008 6:53 am
Well, I have got the Notch in with Classy Campers to get that bloody drivers side door resprayed. It was the one thing about the car that really bothered me, whilst it was in there I decided to have a good poke around and sort out anything else that may have needed doing. The sills were looking a bit crusty so they are going to get a looking at, as well as some bubbles on both doors.
Here she is......................getting naked, ready for a rub down!!
The Notch....... 024
The Notch....... 025
The Notch....... 026
The Notch....... 027
Passenger side sill.
The Notch....... Alansnotch001
Looks even rougher up close!!
The Notch....... Alansnotch002
Get the paint off and see what is going on...
The Notch....... Alansnotch004
Hmmmm, some of these previous repairs aren't to the best standard.
The Notch....... Alansnotch005
Nothing too much to worry about. A panel is en route from Type 3 Detectives for this side.
The Notch....... Alansnotch006
All the rot is to be cut out and replaced with fresh metal.
The Notch....... Alansnotch007
Ah bliss, this end of the sill didn't benefit from previous welding, simply plug the area with filler!! Rolling Eyes
The Notch....... Alansnotch008
The bubbles along the bottom of the door have turned into this.....
The Notch....... Alansnotch009
One previous repair on this corner of the door was ok, lead loaded, shame about the later work.
The Notch....... Alansnotch010
Now round to the drivers side.
The Notch....... Alansnotch011
I didn't think this side looked as bad........
The Notch....... Alansnotch012
Get the paint off for a proper look. affraid
The Notch....... Alansnotch013
It could have been worse, this just needs a sheet panel making up and welding in.
The Notch....... Alansnotch014
Quick, sweep it up before anyone comes!!! lol!
The Notch....... Alansnotch015
Looking better, should be good for a few more years.
The Notch....... Alansnotch016
The Notch....... Alansnotch020
Especially pumped full of Waxoil when it's done......
The Notch....... Alansnotch017
Up in the air it is solid. No rot at all in the floor etc.
The Notch....... Alansnotch019
The Notch....... Pbucket
PostSubject: Re: The Notch.......   The Notch....... EmptyTue Aug 05, 2008 7:00 am
The other area that needs doing is the front clip side of the spare wheel well. It has been raised now as it was lower and I think that area ground out a lot hence it has blown through at the bottom. Not got any pics of that yet but hope to have some for the next update.
When the paint is done the engine is coming out to sort the oil leak. First job will be to tighten the adjustable push rod tubes and then check the crankshaft oil seal.
I am going to stick with the 009 and go 6v pertronix in that, so that will sort the timing, and then put the 5x130 discs on the back to lose the adaptors.
135 tyres to replace the 145 on the front will give a tad more tuckage and I have had the arches rolled to maximise clearance.
Just on the hunt now for a 6v oil temp gauge.
PostSubject: Re: The Notch.......   The Notch....... EmptyTue Aug 05, 2008 7:35 am
Nice one Scoops Wink
The sills were the only thing letting the old girl down, so glad you're getting them done while she's in.
at least now it'll be piece of mind that she's getting sorted & waxoiled up to give protection!
PostSubject: Re: The Notch.......   The Notch....... EmptyTue Aug 05, 2008 7:38 am
For defo. I might even be happy enough with it then to get it in the show and shines!! Very Happy
PostSubject: Re: The Notch.......   The Notch....... EmptyTue Aug 05, 2008 8:55 am
Wow mate, I'm amazed they needed that much work, but well worth it, and you'll be so happy with their results, try and get a photo of dans bus for me (maybe in a blue or primered at the mo)... Smile This is going to be the nicest notch on the scene when its done
PostSubject: Re: The Notch.......   The Notch....... EmptyTue Aug 05, 2008 9:33 am
Cheers Dude.......I loved cruising around in the car before, but once I get it back, get the rack back on with a few little accessories I haev got stashed away I am am going to be grinning like a loon I think!! Ihave got some bits to go on there. A Sun 1960's 6v tacho (the one that Moon copied), a badge bar and some nice lights) as well as rear jail bars for the back shelf and a genuine and COMPLETE VDM wheel with red centre.
I would like to try and get it ready for the show and shine on the Sunday at Vanfest, see how it fairs......
PostSubject: Re: The Notch.......   The Notch....... EmptyTue Aug 05, 2008 9:40 am
Cant wait to see her once she is all finished. She will certainly have the WOW factor thats for sure!
xxxxxxxxxxxxxx
You grin like a loon already Scoops, so I doubt we'll notice buddy! lol!
PostSubject: Re: The Notch.......   The Notch....... EmptyTue Aug 05, 2008 11:11 am
shes gonna look sweet when shes done ....
xxxxxxxxxxxxxx
PostSubject: Re: The Notch.......   The Notch....... EmptyTue Aug 05, 2008 11:13 am
I hope so!!
PostSubject: Re: The Notch.......   The Notch....... EmptyTue Aug 05, 2008 11:37 am
at least the rust issues are getting sorted, how long before it comes back bud
PostSubject: Re: The Notch.......   The Notch....... EmptyTue Aug 05, 2008 11:40 am
The rust?? affraid
I think it will be a couple of weeks before I get the car back so looks like I will miss Dubs at the Beach in it, never mind, i can wang down the outside lane in the wifes Golf!!
PostSubject: Re: The Notch.......   The Notch....... EmptyTue Aug 05, 2008 11:58 am
i can wang down the outside lane in the wives Golf!!
How many do you have Scoops? affraid
..... And does Em know about the others? Suspect
PostSubject: Re: The Notch.......   The Notch....... EmptyTue Aug 05, 2008 12:05 pm
Edited, You are quite right. It should be wifes not wives........it's been a long morning..... Rolling Eyes
PostSubject: Re: The Notch.......   The Notch....... EmptyTue Aug 05, 2008 8:28 pm
Nice one Scoops looks good don't forget I need some good quality pic's of the notch to see if the guy I know can do a model like it or close to it for you and how much it will be.
punk The Notch....... Thumbs
PostSubject: Re: The Notch.......   The Notch....... EmptyWed Aug 20, 2008 10:25 pm
I am just uploading some more pics. Will update the thread tomorrow....
PostSubject: Re: The Notch.......   The Notch....... EmptyThu Aug 21, 2008 6:18 am
One sill sorted with fresh metal and a skim of filler. Looking much better I think.
The Notch....... Goldbus006
The Notch....... Goldbus007
The Notch....... Goldbus005
The Notch....... Westieunderside031
And some paint going on, this paint actually matches!!
The Notch....... Westieunderside028
The Notch....... Westieunderside029
The other dodgy area was the front valance. Previously I think the car had been lower and this point had regularly ground out. Hence it had blown through with a bit of local rust.
The Notch....... 18082008002
Out you come......
The Notch....... 18082008005
Shaun made a replacement panel up.....
The Notch....... 18082008007
....and slotted it into place.
The Notch....... 18082008009
And covered up with some paint.
The Notch....... 19082008005
The Notch....... 19082008007
The passenger side is next to get some paint on and then it's a few mechanical bits and bobs.
Ie rear discs, oil leak and a couple of other little things.
Should be back with me soon.
PostSubject: Re: The Notch.......   The Notch....... EmptyThu Aug 21, 2008 6:44 am
Bugger me i never knew there was a Notch thread..
Looking sweet dude, some great work going in there.. Twisted Evil Cool afro
PostSubject: Re: The Notch.......   The Notch....... EmptyThu Aug 21, 2008 6:48 am
Ady and Shaun at Classy Campers are doing it.
Can't fault them at all.
Really looking forward to getting it back. Very Happy
PostSubject: Re: The Notch.......   The Notch....... EmptyThu Aug 21, 2008 12:47 pm
Schweeeeeet!
PostSubject: Re: The Notch.......   The Notch....... EmptyThu Aug 21, 2008 4:31 pm
nice one scoops looks ace
PostSubject: Re: The Notch.......   The Notch....... EmptySat Aug 30, 2008 9:44 pm
Another update on this then.
Went to have a proper chat with Ady yesterday.....
The engine was dropping oil whenever it was warmed up, not a huge amout but it was annoying. So whilst the car is there it is getting sorted.
So, whip the 1776 out.......from here.......
The Notch....... Notch010
to here
The Notch....... Notch011
It would seem the suspicions were correct, crankshaft oil seal had gone.
The Notch....... Notch012
The Notch....... Notch013
Happily, despite there being plenty of oil in the bell-housing the clutch etc was okay.
The Notch....... Notch014
Unfortunately we have discovered a hairline crack in the gearbox casing. I am awaiting news to see if a local chap will go out to Ady's and Tig the casing for me.
It's booked into the booth for Thursday, then it is just a case of getting the 6v Pertronix in and sorted, quick tune up and then get the rear discs on.
Bit gutted it won't be back with me for Bibic but I am hoping to have it sorted for Vanfest. Might need a couple of late nights then to get the couple of accesories etc I have for it on there!!
PostSubject: Re: The Notch.......   The Notch....... EmptySat Aug 30, 2008 10:02 pm
ahh what a bugger mate, but worth the wait, then its 100% tickedy boo Smile
PostSubject: Re: The Notch.......   The Notch....... EmptySat Aug 30, 2008 10:04 pm
Awesome car ......glad its getting the 'love' it deserves .....was it the crankshaft oil seal AND a crack in the box .......or was the seal OK ?
PostSubject: Re: The Notch.......   The Notch....... EmptySat Aug 30, 2008 10:05 pm
I hope so Olly.
It was both Nomates.
The Notch.......
Page 1 of 7Go to page : 1, 2, 3, 4, 5, 6, 7  Next
» Top Notch Stars AAU summer team
» Top Notch Stars Summer AAU Team Second Tryout
» Top Notch Stars AAU Summer Team
» 5100s 285/70 17s
