 Help needed
4 posters
Blackfairykitten
Blackfairykitten
Female Number of posts : 540
My Ride(s) : 2001 VW T4 2.5TDI & 2005 Seat Altea 1.9TDI
Registration date : 2008-03-04
Help needed Empty
PostSubject: Help needed   Help needed EmptySun Apr 20, 2008 11:17 am
We have decided to sell the van but we're trying to get as many things done on it beforehand. Lowering it being one of them but after putting the rear on we are finding it impossible to put the front on, we decided to replace upper ball joints but cannot remove them have tried ball joint separators! Any tips we just wanna get it done and gone asap so I can get something I can drive!
Help needed Empty
PostSubject: Re: Help needed   Help needed EmptySun Apr 20, 2008 11:29 am
i take the top arm bolt out when doing the front springs. as the camber needs resetting really, are you using a fork type seperator that you beat in with a hammer or the bolt type that winds down on it and pushes it out Question
Blackfairykitten
Blackfairykitten
Help needed Empty
PostSubject: Re: Help needed   Help needed EmptySun Apr 20, 2008 11:35 am
tried both types but it's solid Sad
Help needed Empty
PostSubject: Re: Help needed   Help needed EmptySun Apr 20, 2008 3:30 pm
Hit it harder Twisted Evil
Help needed Empty
PostSubject: Re: Help needed   Help needed EmptySun Apr 20, 2008 7:13 pm
long bar to lever suspension apart and then hit the mount point that ball joint pin mounts through as this will shock apart.
Blackfairykitten
Blackfairykitten
Help needed Empty
PostSubject: Re: Help needed   Help needed EmptySun Apr 20, 2008 8:24 pm
thanks for all the suggestions, thanks to Rick for a better seperator, it is off and new all on Smile Just the other side to go 2 moro now Smile
Help needed Empty
Help needed
» HELP!!! T4 engine, AAB 2.4, 5 cylinder desperately needed
