 Project Back to '91!
Project Back to '91! - Page 4 Empty
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySun May 20, 2012 1:04 pm
tango_van wrote:
Take the piston out, polish it up and That's the best in show cttp 2013 trophy sorted then!
Just need some other failed parts to make the rest Wink
Hope the rest of it is ok..
best rat trophy
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySun May 20, 2012 1:17 pm
By the looks of things, this car may be going to lennys!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySun May 20, 2012 2:30 pm
Fuck me Al, that's proper broken!
I'm still looking out for an engine for you.
There was a bug at one of the scrap yards on the congresbury road a while back.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySun May 20, 2012 2:52 pm
I have a plan, and it's fucking awesome!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySun May 20, 2012 2:57 pm
paris convertible Shocked
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySun May 20, 2012 3:52 pm
Awesome, not awful.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySun May 20, 2012 4:51 pm
Scooby time?
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySun May 20, 2012 7:33 pm
blimey ......gotta like the pic of the piston with the valve stuck in it ....lol
whats the new plan stan?
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySun May 20, 2012 8:38 pm
It was the cylinder that fell in half that shocked me!
I suppose that's what happens when a valve drops at 6500 rpm!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySun May 20, 2012 9:13 pm
piston must have expanded ......bummer dude , as the others have said ,is the case ok?
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptyWed Jun 20, 2012 7:04 pm
Ok awesome plan turned into a fail, due to lack of fundage!
So engine rebuild and a bit of wielding is on the cards, I've bought a newish counterweighted crank, which is currently down at hamlins getting balanced, I was looking at getting a set of 044 heads to replace the damaged ones, but after getting them looked at, they can be repaired, by tig welding up the dents, and then getting the combustion chamber reshaped to match the existing one.
It's going to stay as an 1835, but I may install larger valves while the heads are in bits, and the guides and seats are being done anyway.
With the money I'm saving by rebuilding the heads, i may treat myself to a new carpet set, and maybe get the headliner done as well, just to try and make the inside a nice place to be
(if it ever gets driven)
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptyWed Jun 20, 2012 8:15 pm
Glad to see it will live again mate!
Project Back to '91! - Page 4 Pbucket
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptyThu Jun 21, 2012 7:42 am
MOT in November!
And I want to get it run in before EBI!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptyTue Jul 24, 2012 4:29 pm
Ok,
Thanks to scoop and Nomates for giving me a push on Saturday, the car is now outside the house, minus the nearside floor pan, I had to cut it out to get an idea of how bad the rot was
Project Back to '91! - Page 4 F79fbe84
Not too bad, the last 12 inches of the heater channel bottom was rotten, as was the front 18 inches or so, I cut it all out, and I also used this as an opportunity to replace the flitch panel as well, as it has been subject to a few 'temporary' repairs.
New panel welded in.
Project Back to '91! - Page 4 B8cdb9ec
After a skim of filler, and under coated with galvanising paint
Project Back to '91! - Page 4 2a413252
While the panel was off I coated the inside of the bulkhead and in the heater channel with galv paint and waxoyl underseal.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptyFri Aug 03, 2012 7:12 am
Heater channel all repaired now,
Rear,
Project Back to '91! - Page 4 57e2706e
Front,
Project Back to '91! - Page 4 5a29bcee
Did a trail fit of the floor last night, I'll try and get it in and welded later, then it's underseal all that, and start re- fitting the interior.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptyFri Aug 03, 2012 7:23 am
Good work Al!!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySat Aug 11, 2012 11:15 am
New pan half in and sealed,
Project Back to '91! - Page 4 E9c58ef5
Coated the bottom and anything else in galv paint!
Just need to paint everything now, underseal on the bottom, and Smoothrite inside.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySat Aug 11, 2012 3:07 pm
Looking sweet al!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySun Aug 12, 2012 11:22 am
New fuel line in this morning, 8 mm OD, 0.6 mm wall thickness, and I flared the ends to give a bit more of a secure fitting to the flexible hose
Project Back to '91! - Page 4 6607c966
Fitted to my newly painted floor!
Project Back to '91! - Page 4 Bde5b83b
Just got to try and refit everything now, takes twice as long to fit it as it does to remove it!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySun Aug 12, 2012 4:09 pm
Well done mate.
I see you did this then to celebrate, went and bought some fish for the pond!!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySun Aug 12, 2012 5:17 pm
I'm sure you were there buying goldfish to fit in your platform shoes!
Project Back to '91! - Page 4 Goldfish_shoe_by_kingadam14
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySun Aug 12, 2012 5:27 pm
It just finishes off the get up!!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptyThu Aug 16, 2012 9:10 pm
Last little welding job before the car is back tucked away again, was to make a steering stop, apparently it's a mot fail to use the inner wing to control the range of the steering.
I welded a m16 nut to the side of the shock tower and threaded a bolt in there so the control arm hits that instead, easy!
Project Back to '91! - Page 4 A018FCB6-1E79-4D84-B0A6-F6AA8AE2AD8B-1424-0000028721C4FCF9
Just got to refit the fuel tank and amps etc, then I'm waiting for the engine.
PostSubject: We can rebuild it!   Project Back to '91! - Page 4 EmptySun Nov 11, 2012 11:23 pm
Well, here we go with saving the engine!
Crank gears on
Project Back to '91! - Page 4 364FBE11-36D4-4CFA-A035-B077DE711131-628-000001BD6A554E02
Rods on
Project Back to '91! - Page 4 6F10B458-B852-421F-B7D7-A34E59470AB3-628-000001BD701CBEA5
Crank in the case, with new bearings, followers etc.
Project Back to '91! - Page 4 0440FE67-924A-4010-B252-1B701611D1D9-628-000001BD7704F592
Missed a few photos, but here's setting the end float.
Project Back to '91! - Page 4 EEF81475-3768-4995-B1AA-5712C5672B96-628-000001BD7D39A6E3
That's as far as I am with the build, but the heads are getting there
Welded with new bigger seats fitted
Project Back to '91! - Page 4 6E15D8EC-6263-4F73-91F9-2B18FD28E7D7-628-000001BD5A97B63D
You can see where the head needs to be ported to blend in with seats
Project Back to '91! - Page 4 9B81B258-73F2-4E06-B91D-89959BE224EE-628-000001BD61BEAA5A
That's it so far!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 4 EmptySun Nov 11, 2012 11:59 pm
Nice work Al
Page 4 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
» Project UTV
» Looking to start a rock crawler project.
» IM BACK! Craftsman II racer project
» Left Back Needed
» Project Peenemünde!
