 Project Back to '91!
Project Back to '91! - Page 6 Empty
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyFri May 31, 2013 6:55 pm
Offered up, fits perfick,
Project Back to '91! - Page 6 Null-20
Sprayed, filter mounted
Project Back to '91! - Page 6 Null-21
Fitted in position
Project Back to '91! - Page 6 Null-22
Plumbed in, hoses are a close to the exhaust, but the wrap should help keep them protected partly from heat.
Project Back to '91! - Page 6 Null-23
Induction and extraction to be fitted tomorrow!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptySat Jun 01, 2013 10:53 am
Hi Al
This may sound like a daft question but will you get any noticeable heat transfer from the connecting points through onto the metal plate (head stud fixing)? Just a thought.
Once running you could always check to see if you get any transfer.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptySat Jun 01, 2013 4:52 pm
I thought about that, that's why the plate is sooooo much bigger than it needs to be, partly so it shields the filter and lines from the exhaust, and hopefully it should act like a heat sink and radiate any of the transferred heat away.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyWed Jun 05, 2013 5:14 pm
Carbs and Zorst on now, it's filled with oil, batteries are on charge, just need to put some fuel in it and I'll start and time it up properly!
Project Back to '91! - Page 6 Null-24
Smile
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyWed Jun 05, 2013 5:21 pm
No flooring it yet
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyWed Jun 05, 2013 6:38 pm
Are you going to try not to do so many McDonalds car park wheel spins this time?
Project Back to '91! - Page 6 Pbucket
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyWed Jun 05, 2013 8:57 pm
just not on a cold engine dude!!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyWed Jun 05, 2013 9:21 pm
I learnt the expensive way about how much abuse this engine can take!!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyWed Jun 05, 2013 9:42 pm
That doesn't mean you won't do it again! lol!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyThu Jun 06, 2013 9:12 am
Sounds like a challenge to me! lol!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptySat Jun 08, 2013 7:01 pm
It's alive! Again!
Changed the gearbox oil this morning and fired it up this afternoon, smoked like a bitch to start off with, but that was all the oil in the exhaust left over from the incident!
Ran it in the garage for about an hour and a half to warm it up properly, but i think it may be a bit warm at 220 degrees Fahrenheit.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyTue Jun 11, 2013 12:35 pm
Dude, dont say you have cooked it again!! dont forget its aircooled! lol
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyTue Jun 11, 2013 12:49 pm
According to tinternet, normal is at 180-210 f, it was running in my garage, on a warm day, with no bodywork or tin on the back end, so I'm happy with it a bit warm
In that circumstance, I forgot how noisy bloody chromoly pushrods are as well, runs ducking lush now, the revs pick up quick with the balanced crank, I just need to make sure the carbs are balanced properly, check the clutch adjustment, check the ball joint boots, then mot it.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyTue Jun 11, 2013 1:01 pm
Sweet! Get cracking al...there's still summer left!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyTue Jun 11, 2013 7:34 pm
Shame you can't get it done for the drive out tomorrow night....
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptySun Jun 23, 2013 3:51 pm
Right, fitted the rear valance back on, makes a huge difference to how the car looks
Project Back to '91! - Page 6 Null-26
Rear tin on as well
Project Back to '91! - Page 6 Null-27
Checked the ball joint boots as well, this is the average state of them!
Project Back to '91! - Page 6 Null-28
All replaced now, pics to follow when I've replaced the track rod end boots too!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptySun Jun 30, 2013 10:09 am
Boots done, so far this weekend I've inserted some Riv-nuts in the inner front wings to secure the cables for the front indicators, and one for the speedo cable, I've fitted a new E clip on the end of the speedo cable instead of the tie wrap that was there before, I've put some more Riv-nuts under the rear seat to secure the battery straps a bit better than self tappers.
Just got to enlist the help of the Mrs later to bleed the brakes, then I'm going to book it in for its MOT!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptySun Jun 30, 2013 11:05 am
nice one Al
Project Back to '91! - Page 6 B9d2fd24
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptySun Jun 30, 2013 4:11 pm
Brakes bled now, few per MOT checks, and a blown fuse for the sidelights, and a loose indicator lamp, and everythings hunky dory.
Got quite a bit of travel in the brake pedal though, I'll have a look at adjusting the pushrod later.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyMon Jul 01, 2013 11:46 pm
do you need a hand with the electrical bits?
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyTue Jul 02, 2013 6:47 pm
It's alright mate, I sorted them!
MOT today, and after taking it for a bit of a run, I know I need a new pulley seal, and I have a worn rear o/s wheel bearing.
But apart from that, I've had a double thumbs up from my friendly mot man!!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyTue Jul 02, 2013 7:11 pm
i have got some heat shield from above a catalytic converter if you want it for your oil pipes?
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyTue Jul 02, 2013 7:37 pm
well done mate Very Happy
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyTue Jul 02, 2013 8:09 pm
Good work.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 6 EmptyTue Jul 02, 2013 9:08 pm
That would be ace Ta!
Page 6 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
» Project UTV
» Looking to start a rock crawler project.
» IM BACK! Craftsman II racer project
» Left Back Needed
» Project Peenemünde!
