 Project Back to '91!
Project Back to '91! - Page 5 Empty
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptyMon Nov 12, 2012 12:14 am
Nice to see some reengineering rather than just replacing it all Smile
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptyMon Nov 12, 2012 5:25 am
Good work Al..coming along nicely Very Happy
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptySat Mar 16, 2013 10:27 pm
Bit more done..
Combustion chamber reshaped and cc'd
Project Back to '91! - Page 5 92EEFE3A-DD1C-40EA-9A5E-DB2F9997AE35-2465-000005F3781087D3
Spark plug hole drilled
Project Back to '91! - Page 5 08DCC393-E296-4FAC-8C85-9F958785DEF6-2465-000005F36962281B
Valves all fitted
Project Back to '91! - Page 5 C7A206C2-B8E3-459C-9BDF-B6D38A2A3E11-2465-000005F359787B09
Now using a 37 mm inlet and 33 mm exhaust, I kept the valves on the small size to increase velocity at lower rpms, should help keep the power band towards the middle,
Also, because I'm using 36mm venturis in the carbs, it keeps the flow smooth!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptySat Mar 16, 2013 11:48 pm
great work sir, I would be lost when it comes to the finer detail like this!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptySun Mar 17, 2013 8:49 am
In all honesty, I would have been better off buying new heads, for the cost of new valves, springs, retainers, seats, all the machining work and the time to reshape it all,
But that's not the point!!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptySun Mar 17, 2013 10:07 am
Must be a lot more satisfying to have been able to do work like this than just swap bits though?
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptySun Mar 17, 2013 11:17 am
It is I suppose, if they were stock heads to start off with I would have binned them, but they have been extensively worked, so it made a bit more sense to save them.
Can't wait to get driving again!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptyMon May 13, 2013 6:19 am
Right, while I'm waiting for a few bits, I thought I would repair the dent in the front wing where the half inch air gun fell off the shelf!
Project Back to '91! - Page 5 Null-2
The dent knocked out pretty well with my new panel beating kit!
Left a bit of an indentation though
Project Back to '91! - Page 5 Null-4
Bit of rubbing down
Project Back to '91! - Page 5 Null-6
Light smothering with filler
Project Back to '91! - Page 5 Null-7
Rubbed down
Project Back to '91! - Page 5 Null-8
Primed
Project Back to '91! - Page 5 Null-9
Top coat is done, but I'll take more pics later when I flat and polish.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptyWed May 15, 2013 7:24 pm
Replaced the engine mounts with the polyurethane ones I bought at Big Bang,
Project Back to '91! - Page 5 Null-10
After speaking to Nomates, I think I'll replace the bolts the front mount came with because I don't think they are long enough.
Rear ones fit lush though!
Project Back to '91! - Page 5 Null-11
Time to start getting the engine together now!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptyThu May 16, 2013 8:07 pm
Woo Hoo! I now have a complete longblock!
Project Back to '91! - Page 5 Null-12
Just got to start bolting all the bits and pieces back on, hopefully I'll have it in the car by the end if Sunday!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptyThu May 16, 2013 9:02 pm
Good work Al, looking forward to seeing your Bug back on the road.
Project Back to '91! - Page 5 Pbucket
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptyThu May 16, 2013 9:33 pm
Sweet! It's been a long time coming Wink
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptySun May 19, 2013 6:38 pm
Moved the engine to the rear of the car using Charlie's skateboard to move it, started assembly of ancillary parts.
Project Back to '91! - Page 5 Null-14
Got more tinware and the exhaust fitted too, I cleaned the j-tubes up and sprayed them with high temp paint.
Project Back to '91! - Page 5 Null-13
Just the fanshroud and clutch assembly to fit to the motor and it can get bolted back in, I'm going to grind down the engine mount studs a bit first though to avoid fouling the flywheel, then I'm going to have to rethink my oil filter location, I'm not happy with the length of pipe to it.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptySun May 19, 2013 8:03 pm
Looking good Al!
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptySun May 19, 2013 9:33 pm
good work mate.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptySun May 19, 2013 10:51 pm
Well done mate
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptyWed May 29, 2013 4:44 pm
Half day today, so I cracked on with some jobs, got the bolts in the nosecone mount replaced, replaced the release bearing and ground the studs of the rear mounts like I was hoping.
Fitted the rest of the tinware too, with the help of a rubber mallet.
Project Back to '91! - Page 5 Null-15
Engine, say hello to gearbox, long time no see!
Project Back to '91! - Page 5 Null-16
10 minutes later!!
Project Back to '91! - Page 5 Null-17
Like a glove!
I re-plumbed the oil cooler/stat pipes so they run correctly, I need to fab a bracket for the oil filter to mount on the exhaust studs I made a template out of cardboard and I'll have a go at making it at work tomorrow.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptyWed May 29, 2013 6:30 pm
nice one dude ......good job
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptyWed May 29, 2013 9:07 pm
Back on the road soon then? You bringing it up to Bristol?
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptyWed May 29, 2013 9:24 pm
I was hoping to have it ready for Bristol, but it's not going to be, I still have to get the bloody thing running right, replace a couple of ball joint boots, get it MOT'd and taxed.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptyWed May 29, 2013 9:33 pm
Bummer
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptyThu May 30, 2013 1:06 pm
Bracket fabbed,
From this
Project Back to '91! - Page 5 Null-18
To this
Project Back to '91! - Page 5 Null-19
I'll offer it up to the car and get the filter bracket mounted correctly before I take it off and spray it up.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptyThu May 30, 2013 3:56 pm
what filter ? ........looks too thin for a bracket to me ......got some 2mm steel here dude if you want a cut off
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptyThu May 30, 2013 4:37 pm
It's 2mm galv steel, photo is a bit shit, it doesn't show the mounting holes and bend.
PostSubject: Re: Project Back to '91!   Project Back to '91! - Page 5 EmptyThu May 30, 2013 6:24 pm
cool
Page 5 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
» Project UTV
» Looking to start a rock crawler project.
» IM BACK! Craftsman II racer project
» Left Back Needed
» Project Peenemünde!
