| 72 bug had a little tickle from the stick | |
+24ProjectParsons ARCANE Wurz sid_the_geek itsabuglife griff Azrael nomates eddie gordo dubberatlast Shamrockez delboy vwbeetlebum 1584cc stuart72 Dirty Dave ANDYLHAM VWFRIZZ blueridge Impy Mcdub Big Blue Betty Mr Scoops type25 dan thecrewkid 28 posters |
| Subject: Re: 72 bug had a little tickle from the stick Sat Feb 16, 2008 8:34 am | |
| Subject: Re: 72 bug had a little tickle from the stick Sun Feb 24, 2008 9:03 pm | |
| Not got much done on this but the rear height is now set.. I've pulled the loom out of my bug and i'm half way through putting it in Frizz's... Wing beading has been coiled up for years and slightly miss shaped so i've got that in place to straighten it out a bit before final fit up.. Got to sort some dynamat before the insides can be started.. Probably gonna get it from the states i think.. | |
| Subject: Re: 72 bug had a little tickle from the stick Sun Feb 24, 2008 9:04 pm | |
| Subject: Re: 72 bug had a little tickle from the stick Sun Feb 24, 2008 9:09 pm | |
| - thecrewkid wrote:
- Not got much done on this but the rear height is now set..
Got to sort some dynamat before the insides can be started.. Probably gonna get it from the states i think.. One word dude ................... PICS | |
| Subject: Re: 72 bug had a little tickle from the stick Sun Feb 24, 2008 9:11 pm | |
| Dude you new puter must be playing up cos theres a pic there | |
1584cc Blitzen Regular
Number of posts : 400 Age : 56 Location : In the Sticks My Ride(s) : 1971 1300 Beetle, 1970 1302 Beetle, 1971 Deluxe Bus, 1972 1200 Beetle Registration date : 2006-12-07
| Subject: Re: 72 bug had a little tickle from the stick Mon Feb 25, 2008 5:40 pm | |
| How much did you narrow the front beam by Rich? Only wondering if you had to take off steering stops or how you got round the problem Got an MOT due on mine and it's got no steering stops so will be technically a fail | |
| Subject: Re: 72 bug had a little tickle from the stick Mon Feb 25, 2008 5:53 pm | |
| Hey Mark hows the family??? As for the beam i didn't do it i bought it as is... I think it was a 3" it def isn't any more then that.. And i'm still running the steering stops but did have to modify the arm that bolts to the box and track rod arms.. | |
| Subject: Re: 72 bug had a little tickle from the stick Mon Feb 25, 2008 6:36 pm | |
| Family's good thanks Rich. I think the arm on mine got cut back for clearance, hence no stops. I'll have to check and see if I can come up with a solution. Either that or distract the MOT tester | |
| Subject: Re: 72 bug had a little tickle from the stick Mon Feb 25, 2008 6:59 pm | |
| Subject: Re: 72 bug had a little tickle from the stick Tue Feb 26, 2008 7:33 am | |
| No stops should be to much of a problem as long as the wheels don't hit anything.... Should it..... My oval had no stops and that didn't fail.... | |
| Subject: Re: 72 bug had a little tickle from the stick Tue Feb 26, 2008 4:47 pm | |
| - thecrewkid wrote:
- No stops should be to much of a problem as long as the wheels don't hit anything.... Should it..... My oval had no stops and that didn't fail....
Did the wheels hit anything with the oval? I think the K & L beams are a bit different from the ball joint beams. The tyres on mine rub the inner arches on full lock. It's passed before at an MOT station up in Cheshire. I guess it depends on where you take it... | |
Big Blue Betty DBS Old Timer
Number of posts : 2686 Age : 43 Location : Bridgwater, Somerset My Ride(s) : 71 Bay Camper Betty, 69 Bug Minty, 57 Ragtop Oval Bery. 67 Split Hugo! 83 MK1 Golf Cabriolet Star! Registration date : 2007-05-06
| Subject: Re: 72 bug had a little tickle from the stick Tue Feb 26, 2008 5:03 pm | |
| Minty hasn't got her stops but I havent put her thru an MOT yet so who knows. Nothing rubs on her but she has got skinny tyres on the front.
xxxx | |
eddie gordo DBS Old Timer
Number of posts : 1650 Age : 36 Location : Leeds My Ride(s) : The Gordo Wagen Registration date : 2006-08-20
| Subject: Re: 72 bug had a little tickle from the stick Tue Feb 26, 2008 5:46 pm | |
| mine are hacked and 3 mots later, nothing said | |
| Subject: Re: 72 bug had a little tickle from the stick Tue Feb 26, 2008 6:29 pm | |
| - 1584cc wrote:
- Did the wheels hit anything with the oval?
I'm pretty sure they didn't hit anything buddy.. | |
| Subject: Re: 72 bug had a little tickle from the stick Thu Feb 28, 2008 8:22 pm | |
| Got abit more of the wiring done... And realised that the hole for the N/S rear light wiring on the inner wing is ummmmm not there Fitted the bonnet seal.. And fooked about with the bonnet catch.. Slow progress at the mo.. | |
| Subject: Re: 72 bug had a little tickle from the stick Sun Mar 16, 2008 9:51 am | |
| Very very slow going Ummm the headliner is goning up slowly, the wiring has had a little tickle.. And I pickED up a stock style Stainless exhaust for it as well cheers Tan 4 weeks.......CTTP......... She's never gonna be finished in time... | |
blueridge DBS Old Timer
Number of posts : 1245 Age : 43 Location : highbridge My Ride(s) : 1973 Squareback,1999 golf gti,95 GMC Safari. Registration date : 2007-04-12
| Subject: Re: 72 bug had a little tickle from the stick Sun Mar 16, 2008 10:34 am | |
| 4 weeks is plenty of time at the speed you work.Don't forget if you need a hand i'm just down the road. | |
| Subject: Re: 72 bug had a little tickle from the stick Fri Apr 18, 2008 7:06 am | |
| Subject: Re: 72 bug had a little tickle from the stick Fri Apr 18, 2008 9:39 pm | |
| wow that looks amazing! in regards to the bump stops, you chopped mine off! haha, but the tester called up the hq and they said thats fine as long as the suspension is working, 2 mot's later no probs. | |
| Subject: Re: 72 bug had a little tickle from the stick Thu May 01, 2008 8:34 pm | |
| Subject: Re: 72 bug had a little tickle from the stick Fri May 02, 2008 7:06 am | |
| And finally started to get to work on the front beam to get it finished and back in.. Should be back rolling next week..
Then it's just.. Finish the headliner. Sort and fit new sound deadening. Fit interior. Welding some new seat runners. Make door cards. Finish the wiring loom. Rebuild rear brakes. Bleed all brakes. Set tracking. Prep and paint the tinware. Refit tin. Fit engine. Fit chrome trim. Fit running boards. Sort some door rubbers. Fit all windows and chrome trim. Fit new rear shocks. Fit bumpers. Fit wings and wing beading. Fit new lights and indicators.
I think thats about it really.. Then MOT time.. | |
| Subject: Re: 72 bug had a little tickle from the stick Fri May 02, 2008 12:00 pm | |
| Looking Fab... Just a few little bits then mate be worth it in the end tho beone nice bug when done i recon |
| Subject: Re: 72 bug had a little tickle from the stick Fri May 02, 2008 12:03 pm | |
| Those seats are gert lush... | |
| Subject: Re: 72 bug had a little tickle from the stick Fri May 02, 2008 12:26 pm | |
| Cheers peeps If i pull my finger out she'll be on the road in 2 weeks... BUT can i be fooked to do it?????????? No not really.. | |
| Subject: Re: 72 bug had a little tickle from the stick Fri May 02, 2008 7:27 pm | |
| Subject: Re: 72 bug had a little tickle from the stick | |
