 Tigger Reborn
Tigger
Tigger
Male Number of posts : 106
My Ride(s) : T4, Caddy Maxi, Golf, SV1000SZ, Polo
Registration date : 2012-03-14
Tigger Reborn Empty
PostSubject: Tigger Reborn   Tigger Reborn EmptyWed Jan 28, 2015 8:08 pm
Just thought I would start a build thread to keep track of what I'm doing.
Not your stunning air-cooled stuff I'm afraid but its part of the family to us.
Had it 7 years now and this will be its third reincarnation.
Started as an AA Combi T4 Van
I fitted it out in Caravelle interior panels and rear seats. Orange paint job.
Next was a Styleline interior with a T5 Caravelle rear triple seat on rails that we used as our bedroom when camping and had it set up with an awning.
Now its out with the Caravelle triple and in with a Variotech 3/4 RnR seat and camper units.
This will be quite random as I will post up pics as and when bits get done.
http://centurion-electrical.co.uk
Tigger
Tigger
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptyWed Jan 28, 2015 8:39 pm
Headlight Mods and bonnet.
As we know, T4 headlights are krapp...
Couldn't bring myself to buy a set of tacky DRL "Audi style" lights so set about creating my own.
Sourced some independent light units that are designed for the truck market and fitted them out with 12v lamps.
Tigger Reborn Dsc_0210
I used the original headlight surround so it will still hold the indicators and fitted a steel plate to hold the lights
Found that I needed more movement so had to profile the plate to suit.
Tigger Reborn Dsc_0310
Tigger Reborn Dsc_0311
Modified a bonnet to get a more modern looking style so blended out the steps around the headlights.
Tigger Reborn Dsc_0312
Fitted and adjusted on an MOT station to get the positions right and had the bonnet sprayed when I had the van arches replaced and re-sprayed.
Tigger Reborn Dsc_0410
Tigger Reborn Dsc_0411
Next to do is the surrounds/in-fills and an upgraded wiring loom. But that has to wait.  Very Happy
Tigger
Tigger
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptyWed Jan 28, 2015 8:52 pm
Next was the seats.
Bought a set of cream leather seats from a guy on eBay and the turned up GREY!!! Mad Mad Mad Mad
After a battle for a refund, I decided to put the money it would have costed to pallet them back towards a re-colouring kit.
Never attempted re-colouring leather before but thought I'll give it a go.
The results were a lot better than I could have imagined and I am sooo chuffed... Very Happy
Sorry no pics of them grey but here they are part done.
Tigger Reborn Dsc_0313
Tigger Reborn Dsc_0314
Tigger Reborn Dsc_0315
Re-assembled ready to be fitted on the cut down and swivelled bases.
Tigger Reborn Dsc_0316
Tigger Reborn Dsc_0317
And here fitted in the van
Tigger Reborn Dsc_0318
Tigger Reborn Dsc_0319
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptyWed Jan 28, 2015 8:55 pm
Looking good Amigo
Tigger Reborn Pbucket
Tigger
Tigger
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptyWed Jan 28, 2015 9:08 pm
Had a pair of half size Reimo seat rails that were never machined so took them to a friends workshop and milled out the slots to drop the seats into the rails and 3 holes to locate the seat in 3 positions. First hole right back so the seat is as far back as possible giving maximum room when camping during the day. Second hole located so seat is in correct position for seat belt (travelling mode) and third forward in correct position for making into bed.
These were marked out and remarked and re checked about 10 times until I was happy and then fixed down to the strengthening struts under the van as Reimo instructions.
I then fitted 15mm batten across the van to fix the flooring to.
Tigger Reborn Dsc_0412
I then fitted 15mm insulation between the battens.
Tigger Reborn Dsc_0413
Tigger Reborn Dsc_0414
9mm Ply board was then cut and profiled so the rails slotted through.
Tigger Reborn Dsc_0415
After fitting the other side, I then fitted a piece of black Altro flooring to finish it off. Its not all fixed down at the moment as I am making sure all cabling is in first befor the glue goes down.
Tigger Reborn Dsc_0416
Tigger
Tigger
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptyWed Jan 28, 2015 9:10 pm
Looking good Amigo
Thanks. Long way to go yet!!! Smile
Tigger
Tigger
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptyWed Jan 28, 2015 9:19 pm
Took the van out for a spin and got the side windows re-tinted as the old stuff was starting to bubble and also got a sunroof fitted.
Decided to fit it in the second bay so it will be over the hob in the camper units.
Tigger Reborn Dsc_0417
Tigger Reborn Dsc_0418
Tigger Reborn Dsc_0419
Couldn't decide where, if any, position for the rear speakers so decided to fit them in the tailgate. Will have to upgrade the struts now as its a bit heavy!! Laughing
Tigger Reborn Dsc_0320
Also re-fitted the head lining with a bit of fabric.
Tigger Reborn Dsc_0420
Tigger Reborn Dsc_0421
Tigger
Tigger
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptySun Feb 22, 2015 1:30 am
Before I could start insulating the sides out, I had to remove the side door rail and get it powder coated, not that it needed doing but to change it from stainless colour to black as it was the only shiny thing left on the van.
Here it is fitted back on.
Tigger Reborn Dsc_0422
So next came the insulating.
Tigger Reborn Dsc_0423
And now back in with the Styleline panelling and a strip of LED lights around the top.
Tigger Reborn Dsc_0424
Tigger Reborn Dsc_0425
Tigger
Tigger
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptySun May 08, 2016 11:59 pm
Wow, just looked back through this and its changed quite a bit since then. I'm nearly there with it so I better get a few more pics up.
Firstly, lets look at how the lights are coming on.
As the bonnet is modified and the new round headlights are in I went about making the cowlings to go around them.
First I made some moulds from the original lenses to get the correct contour for the front.
Tigger Reborn DSC_0912
Tigger Reborn DSC_0914
Tigger Reborn DSC_0915
Tigger Reborn DSC_0917
Tigger Reborn DSC_0918
Next I had to remake the top edge of the mould to suit the new bonnet profile.
Tigger Reborn 1
I then needed a way of offering this mould up to the lights to get the positioning of the lamps correct. I decided to get the moulds vacuum formed in clear plastic so I could offer the forming up to the lights and transfer the light positions back to the mould.
Tigger Reborn 3
Tigger Reborn 4
I then decided that a tapered tube around the light units would project too close to the edges of the cowling so I went for a parallel tube and proceeded to attach them to the forming with a hot glue gun to get the positions correct.
Tigger Reborn 5
Tigger Reborn 7
Tigger Reborn 6
Once happy with both sides I transferred the tubes to the original moulds.
I then proceeded to fill the tubes with pattern resin to built up the bosses on the mould.
When it had set, I gave it a proof spray of undercoat to identify areas that needed sanding and filling.
Tigger Reborn 8
Tigger Reborn 9
Tigger Reborn 99
I then spent time over 3 days waxing and polishing the mould ready for fibreglassing. I currently have one mould fibreglassed out curing and will be de-moulding sometime this week.
The rest of the van is also near completion and I will get those pics up shortly.
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptyTue May 10, 2016 8:43 pm
That's a lot of patience gone into building those light covers, can't wait to see them finished, along with the rest of the vans latest updated photo's.
Excellent work 'Tigger', a man with loads of talent.
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptyWed May 11, 2016 9:41 pm
Looking good Dude
Tigger
Tigger
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptyTue May 17, 2016 4:23 pm
Thanks guys.
Well the first fibreglass form came out of the mould in good shape although the mould had to be partially broken up to get it out. This I had expected.
So on with the second one and again not too bad a result.
Then a proof spray of undercoat and a good work over with 180 paper and filler. Next 240 then some Hi-build paint and on with the 400 and 600 grit paper.
A few coats of top coat satin black and they are ready for fitting.
Tigger Reborn DSC_1174
Tigger Reborn DSC_1177
Brackets made and all fitted on.
Well happy with the results. Something a little different from the norm. Very Happy
Tigger Reborn DSC_1182
Tigger Reborn DSC_1185
Tigger Reborn DSC_1186
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptyTue May 17, 2016 8:36 pm
Looking good fella.
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptyWed May 18, 2016 3:42 pm
Very nice - always good to see someone doing something unusual.
Tigger
Tigger
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptySun May 22, 2016 12:07 pm
Thanks all.
Just sorting out my pics of the rest of the van.
Having a nightmare with photobucket so looking at other options. Any suggestions?
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptySun Jun 05, 2016 9:23 pm
looks good matey, nice to see something different !
Tigger
Tigger
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptyThu Jul 28, 2016 6:16 pm
Just back from having the roof wrapped. Fantastic job by South West Tinting in Wellington.
Tigger Reborn 13669810
Tigger Reborn 13654410
Tigger Reborn 13680810
Tigger Reborn Dsc_0010
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptyThu Jul 28, 2016 9:48 pm
Looking Good man!
Tigger Reborn Empty
PostSubject: Re: Tigger Reborn   Tigger Reborn EmptyThu Jul 28, 2016 10:51 pm
Looking really good, just looked at the rest of the tread
Tigger Reborn Empty
Tigger Reborn
» Reborn Matt Sydal
