| rusty nail to sow's ear | |
+6Jam Man dubberatlast tango_van Road Rage Mr Scoops sparkywig 10 posters |
sparkywig DBS Pervert
Number of posts : 538 Location : mostly here, sometimes there My Ride(s) : 1969 rusty bay Registration date : 2013-01-14
| Subject: rusty nail to sow's ear Tue Jan 15, 2013 7:48 pm | |
| I've been asked to post the resto of my shitter bus by your administrators, so blame them. It all started back in February 2008 when I bought a heap of rust from a man in from Torquay and had it delivered just North of Bristol. I had forgotten to tell the wife a new addition was due, so when she came home from work this is what was waiting. It doesn't look too bad on the drive, does it? However, upon closer inspection Stripped out scabby diy interior and binned that, then polystyrene insulation and tinfoil stuck to every panel and the floor. Quick tip, if you've got insulation behind your panels, check it once a year or the condensation will rot your van from the inside. That was the better of the front arches Rear corner and gutter above cargo hatch from inside. Rear corner and roof. Fresh air grille just filled over as well! If you look carefully you can see van crying with relief For a few days the only signs of progress was this as the roof leaked like a sieve. It kept the neighbours happy, but little did they realise what was to come..... Got brake lights, horn, side lights, dip & main beam working and MOT booked, and then started collecting parts.
Last edited by sparkywig on Tue Jan 15, 2013 11:03 pm; edited 2 times in total | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 8:57 pm | |
| Keep posting mate, we want the whole thread!! | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 9:03 pm | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 9:08 pm | |
| OSF chassis leg finished. Better see what's lurking behind here. Not as bad as I thought. Right then, time to do something about the lack of rear suspension travel. The po had dropped the rear by three splines and the front to match. This was the reason why the tyres were rubbing on the arches and it was a pain to drive on anything with a surface worse than a snooker table. From this to this Hmmm, better make a start on those arches I think..... | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 9:10 pm | |
| were the 4 holes on the front panel for a badge? | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 9:12 pm | |
Yes, give me chance, I'll get there in about a year..... | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 9:15 pm | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 9:43 pm | |
| Work in progress. Please note the pile of scrap on the ramp. I mean under the sliding door | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 10:15 pm | |
| I do apologise for the quality of some of the pics. OK, into October 2008 now. Bit a bit bored recently. What with working late and at weekends, I haven't been able to get down to my van. So I've started on the less urgent bits. Before About an hour later Rustproofed Primed Having some topcoat mixed, L345 Lichtgrau, so finishing grille on Sunday. | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 10:17 pm | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 10:20 pm | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 10:23 pm | |
| Making start on the os front arch now, and get rid of the gash repair in the back. No wonder they rot, this has collected since the bodged sills were fitted. Got some topcoat on today to protect the new arch. What do you think of the colour, going back to the original L345 light grey. Bloody weather | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 10:26 pm | |
| Nick was busy in the workshop today, so I couldn't get on with what I wanted to. Started cleaning ns sill to see what it was like. The 7 layers of paint just flaked off the rust that had got through the crappy primer that was on the replacement sill. Bit of rust preventer painted on, and then started following the loose blue high build primer and matt black underneath with a filling knife Bit of an improvement don't you think? | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 10:29 pm | |
| Next installment, remember this? Need to repair OS cab floor before I can fit the arch. Took another two gash repair plates off. After a bit more cutting, can you spot where I cut the brake pipe from the fluid reservoir with the grinder? The bus is a touch lighter now, arch cut ready for a bit of fettling and then fitting next weekend. | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 10:33 pm | |
| 13th December 2008 I'm only on here to report the sh*t day I've had on the bus, mainly due to my stupidity. Up to the last couple of weekends, I've been using my mate's workshop with his four poster ramp. All OK so far. Been working on fitting the os front arch cut, but because the A pillar and gutter section is so ripe, I've been careful in how much metal I've been removing. Today I got to the workshop ready to fit the arch after the last couple of weekends preparing the bus. Got the arch tacked in two places, after trial fitting the door 6 or 7 times, door fits well, even gaps all the way round. Took the door off, raised the bus on the jack, and welded the arch on. Lowered the bus, fitted the door, and, bollocks, the door doesn't shut too well, have to lift the rear end to get it to shut. Awful fit. Tried packing hinges, levering the door by lowering the ramp onto an engine stand. All to no avail. Getting really pissed off by now. Nearly 1 o'clock, and my mate locks up at 1.30. I only get 4-5 hours a week to work on the bus and it's starting to wear thin now. Not complaining about my mate, as he lets me use the workshop, and leave the bus there, scot free. Anyway, my mate's old man turns up and says "Looks like the roof's dropped at the front" I'm thinking "Maybe I should have bought a bus with some more metal and structural rigidity in it" He says "Drop the bus down to the ground" So we drop the bus down to the ground, and the door still doesn't fit. I have a fit of pique and get the grinder out and cut the arch off along the welds that I'm rather proud of. "F*cking rusty heap of shit" As I cut the welds, BANG, the bus moves, and the door shuts absolutely fab. Moral of the story, don't weld on a two poster ramp that lifts by supporting the bus on the chassis rails. The front of the bus had dropped by 30mm as soon as it was lifted off the ground. My mate's old man then says " We sometimes get this problem with some modern cars. As soon as we lift them we can't open the doors" "We only use the four poster for body repairs" | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 10:36 pm | |
| I'll post some pics this weekend, but from the top of the O/S A pillar backwards, there is no metal. Had a poke about to see why the front dropped so much and the entire section above the cab door fell out. There's just the gutter left. My mate's are starting to call it "Trigger's Brush" 'cos of all the cuts I'm fitting. I'm only doing this to save another 40 year old classic...... Well, it was cheap to buy. | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 10:39 pm | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 10:44 pm | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 10:47 pm | |
| Right, where did I get too, a couple of weeks off from grinding and welding. Not too much to report, bit of tidying around the arches, filling, sanding, etc. Thought I'd start bare metalling the front panel to see what needed doing. OK then, new lower inner and outer front valance, and headlamp bowls. Bugger, oh well. At least the airbox and surround is OK. I think I'll get a front panel and cut repair panels out of that. Camera has stopped working, so new pics will be posted at some point. Ordered new front panel, inner and outer lower front panels, windscreen inner repair sections, r/h section of cargo floor, gearbox linkages, windscreen wiper spindles, and accelerator pedal linkage kit. Stop Press: Good News, found a pair of cargo area heater outlets and some genuine window rubbers in my garage stash when I got the door skin out I'd sold, and paid a tenner for a Scat bus shifter | |
| Subject: Re: rusty nail to sow's ear Tue Jan 15, 2013 10:48 pm | |
| ....and £23 for a pair of Porsche tombstones. Can't wait to get back to the workshop. | |
| Subject: Re: rusty nail to sow's ear | |
