 Whitebrow's 65 Bug Full Restoration
whitebrow83
Male Number of posts : 126
Registration date : 2013-05-22
Whitebrow's 65 Bug Full Restoration - Page 5 Empty
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyFri Nov 29, 2013 1:21 pm
Right 4 cutting discs later and the body is free from the pans!
Hopefully get the engine out this weekend. Smile
whitebrow83
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyMon Dec 02, 2013 1:26 pm
Felt like I made some good progress on Saturday as Rich helped me with removing then engine.
Seemed to go smooth until it slipped off the jack and we found out it only had 3 bolts holding it in. Typical.
Had a good chat with Joker (Andy) who gave some good advice on panel choice and fitting.
Here's some pics (obviously engine needs some work).
Whitebrow's 65 Bug Full Restoration - Page 5 Photo_32
Whitebrow's 65 Bug Full Restoration - Page 5 Photo_33
Whitebrow's 65 Bug Full Restoration - Page 5 Photo_34
I was very surprised with the firewall as I thought it would be rotten as the previous owner had covered it up with shitty tinware.
Although the engine trays and rear sections need replacing due to be rotten and covered up with a dodgy patch.
Whitebrow's 65 Bug Full Restoration - Page 5 Photo_35
whitebrow83
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyMon Dec 02, 2013 1:30 pm
Looking at those trays, looks like the previous owner welded them incorrectly as they dont line up with the rear valance seal runner.
Looks odd to me!
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyMon Dec 02, 2013 9:03 pm
Has the rear valance been replaced?
I found with a replacement I bought, the channel didn't line up with the original side trays, it sat lower like yours does at the rear.
whitebrow83
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyMon Dec 02, 2013 9:08 pm
Thats what I was thinking mate. I has holes between the notched for the exhausts so im 99% sure its a replacement.
What did you do to sort it?
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyMon Dec 02, 2013 11:21 pm
Just a guess but going from the profile picture and user name I'd say he sacked the whole lot off and replaced it with fiberglass Laughing
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyTue Dec 03, 2013 6:51 pm
Didn't do it on the Wizard (I didn't build it and it's a steel rear valance).
The options could be to sit a replacement in position (if replacing) and work out if it does need modifying. (As below)
Or if keeping the original see if you can slice (horizontally on the inside, approx. 25mm or the difference) a section out and move the inner piece up to match the channel on the side trays. Quite a bit of work but should see a better seal of your engine compartment keeping the hot exhaust heat separate from the intake.
whitebrow83
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyFri Dec 06, 2013 7:13 pm
Got a delivery of the Wolksburg 18 gauge passenger side pan this week.
I have to say, thanks to Joker for recommending this one as it fits perfect, looks an exact replica of the original i removed.
Heres some photos of a test fit.
Whitebrow's 65 Bug Full Restoration - Page 5 Photo_36
Whitebrow's 65 Bug Full Restoration - Page 5 Photo_37
Whitebrow's 65 Bug Full Restoration - Page 5 Photo_38
Whitebrow's 65 Bug Full Restoration - Page 5 Photo_39
It didnt need any alterations and just fitted like a glove.
I put some of the bolts back in even though the heater channel is shot and they fitted bang on.
So chuffed with it. Just need to make sure I get good heater channels as well. Very Happy
Whitebrow's 65 Bug Full Restoration - Page 5 Photo_40
I need to drill spot weld holes in the pan. Ive seen a few videos where people say 2 inches apart. Is that correct and how far from the edge do each hole need to be?
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyFri Dec 06, 2013 10:46 pm
Every inch for a spot weld, 8mm hole. Make sure all is clean, good ally weld through primer, not zinc primer. As zinc is no good for mig.
Get x-member in first.
whitebrow83
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptySat Dec 07, 2013 9:57 am
Cool, will get the pan sorted this weekend.
I have another question. Do I try and save as much of the floor plate as possible as half of it and 90% of the lip that the pan sits on is rusted?
Whitebrow's 65 Bug Full Restoration - Page 5 Photo13
Or just replace it with the one that came with the pan.
whitebrow83
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptySat Dec 07, 2013 4:56 pm
Ok today i removed the floor plate on the n/s making sure i made measurements and a few notches to show where points are.
I tried to save some of it but realised it was too rusty to save.
Whitebrow's 65 Bug Full Restoration - Page 5 Photo_41
I then started to drill the floor pan. I broke my 8mm drill bit so used 7mm every inch andjust over 1/4 inch away from the edge.
Whitebrow's 65 Bug Full Restoration - Page 5 Photo_42
I then checked the positioning of it before I removed the last part of the floor plate.
Whitebrow's 65 Bug Full Restoration - Page 5 Photo_43
I then cleaned everything up.
Whitebrow's 65 Bug Full Restoration - Page 5 Photo_44
Whitebrow's 65 Bug Full Restoration - Page 5 Photo_45
I tried test fitting the new floor plate, X member and floor pan. Had a little issue with the pan not fittng eactly due to the floor plate.
whitebrow83
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptySat Dec 07, 2013 6:32 pm
Reading through jokers thread and his last comment I think ive done this slightly in the wrong order.
I should havewelded the x member to the boot floor first, drilled the holes into the floor plate and the removed the floor plate.
Although with the x member there it would have made it difficult to remove the plate.
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptySun Dec 08, 2013 9:30 am
It is so you can line it all up properly.
I told you don't cut too much out in one go.
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptySun Dec 08, 2013 9:32 am
The little tab on the rear torsion bar for floor weld, just make sure you clean all the old panel off correctly, and don't hit it too hard as it's cast so will break off.
Male Number of posts : 3614
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptySun Dec 08, 2013 11:25 am
QFT.
whitebrow83
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptySun Dec 08, 2013 4:09 pm
Its all good now, ive taken 4 measurements and compare them all to the original o/s plate and it all lines up perfectly.
False alarm! Very Happy
Ive also cleaned up the little tab which appears to be oval in shape.
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyMon Dec 16, 2013 10:20 pm
Craig... You still alive or have you welded yourself into the pan?
whitebrow83
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyTue Dec 17, 2013 4:35 pm
Help!!! I've been stuck here for weeks  Shocked
Nah just kicking my ex out the house so I can fit more Beetle parts lol
On a serious note. I havent done anything and have a pan drilled and ready to weld along with a x member and the o/s pan to prep.
Got a few weeks off over Christmas so will aim to weld then.
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyWed Dec 18, 2013 9:12 am
 lol! lol! lol! lol!
whitebrow83
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyWed Dec 18, 2013 9:24 am
My last day is today and im not back until the 6th! FUCK YEAH!
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyMon Jan 20, 2014 1:58 pm
craig has been too busy playing with his small willy rather than his welder
whitebrow83
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyMon Jan 20, 2014 3:24 pm
I've been on too many dates and now I have a frayed stump! lol
No more dates after this weekend and back on the bug.
I've also decided to admit defeat and just send the body off to get it all done professionally as theres just too much to do. My wallets going to look like my last dates wizards sleeve but at least there's a good chance it'll be done this year. Smile
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyMon Jan 20, 2014 8:39 pm
QFT.
this rings a bell...
looking forward to seeing it sorted..
you sending it to TODS?
whitebrow83
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyMon Jan 20, 2014 8:47 pm
Shut it house bender!
It just needs to be sorted and ive got alot of freelance work on recently that will fund it.
yeah should be going in to TODS if they have room for it when its ready. Im going to weld the x members and pans in first though and provide them the whole car.
The idea is that they then work on the heater channels and anything else they need to have the chassis for and then i'll have the chassis back to break down furnther, and sand blast.
Will need your help Rich with brakes and rear swing arm. Smile
PostSubject: Re: Whitebrow's 65 Bug Full Restoration   Whitebrow's 65 Bug Full Restoration - Page 5 EmptyMon Jan 20, 2014 9:11 pm
Enjoy the wait, spence has got my fasty to sort out next week!
Page 5 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
» HCR Racing Introduces Full Protection for the Polaris RZR 170
» full face helmet for sale NEW
» Trinity Racing full exhaust system plus more parts for sale
» A new nighttime quarter/half/full marathon in Indy
» NHL 12 Full Contact Physics Engine
