 rusty nail to sow's ear
Go to page : Previous  1 ... 11 ... 19, 20, 21, 22  Next
sparkywig
sparkywig
Male Number of posts : 538
My Ride(s) : 1969 rusty bay
Registration date : 2013-01-14
rusty nail to sow's ear - Page 20 Empty
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyTue Jan 21, 2014 10:46 pm
31st December 2013
Bit more fettling this morning.
rusty nail to sow's ear - Page 20 002_zpsd1f245d7
Starter re-fitted, CV joints tightened, heater tube re-attached, gearbox earth strap connected along with the gearbox coupling (thanks for the reminder Wink ), gearbox oil topped up, new sealant tape fitted to firewall and installed, and it's in.....
rusty nail to sow's ear - Page 20 005_zps27e9025c
Although 6' farther forward of it's final resting place. Laughing
Tapped the l/h carb and inserted a blanking bolt in the unused fuel inlet, letting that cure for a day or so. Then I need to assemble the oil lines at the engine end and fit the moustache bar.
sparkywig
sparkywig
2nd January 2014
Spent most of the day trying to stop the cooling fan rubbing the fanhousing and relieving part of the alternator to sit on the stand properly, even had to disconnect the thermostat and release the tinware.
I managed to fit the oil connections in 10 minutes..... Rolling Eyes
All ready for hose fitment and bolting on the moustache bar.
rusty nail to sow's ear - Page 20 001_zps4cd4175e
Gearbox clutch operating shaft and release bearing issues now.
I need to swap one out of a CA 'box and fit it to the 5 rib 'box. Job 30% completed, I'll finish it tomorrow now.
sparkywig
sparkywig
3rd January 2014
All done. Guide tube removed and CA 'box clutch release shaft and bearing installed.
rusty nail to sow's ear - Page 20 001_zps3ee69f51
All ready for tomorrow morning. Smile
sparkywig
sparkywig
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyTue Jan 21, 2014 10:47 pm
4th January 2014
Today's the day.
rusty nail to sow's ear - Page 20 001_zps8d3e9726
And it's actually connected to the gearbox......
rusty nail to sow's ear - Page 20 002_zps04d9b2ff
Self-supporting and oil lines connected at the engine.
rusty nail to sow's ear - Page 20 003_zps59f474d2
Remote filter location, I think I'm going to make a drop-off panel to protect the oil filter from road debris.
rusty nail to sow's ear - Page 20 004_zps9ef6585a
One stubborn nut and stud that cost me over an hour. Rolling Eyes
rusty nail to sow's ear - Page 20 005_zps39dcafa4
Nick doing a bit to the ute.
rusty nail to sow's ear - Page 20 006_zps56d5a1d0
That'll do for today, f*cking knackered now.
rusty nail to sow's ear - Page 20 009_zps14e9e821
Need to fill up with oil, fit the breather box, connect the fuel lines and the wiring, whack in the battery and fire it up.
sparkywig
sparkywig
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyTue Jan 21, 2014 10:48 pm
6th January 2014
The oil fittings and hose are from MOCAL, and the filter is a generic one from a local factors. Got some clips on order to support the hose.
Spent all morning re-connecting heat exchanger pipework, adjusting clutch, fitting fuel lines and Filter King regulator, and tidying wiring.
Doesn't look like I've accomplished much.....
rusty nail to sow's ear - Page 20 002_zps85aa52ab
Laughing
Unfortunately work gets in the way of play for the rest of the week.
sparkywig
sparkywig
11th January 2014
All ancillaries connected, breathers hooked up, filled with oil, turned over by hand, connected the battery and
rusty nail to sow's ear - Page 20 007_zpsb54eb82b
all the warning lights on with the key in my pocket.
Cock.
Wiring fault.
Cock.
Laughing
Permanent 12V feed to coil and alternator field connection.
So, after disconnecting everything Nick asked if there were two spade connectors on the starter solenoid.
rusty nail to sow's ear - Page 20 003_zpsbaea7454
Yes there are, and I'd connected to the wrong one. Should have been the one that's vertical....
I can get a phone in there and take pictures, but unfortunately either I'm too fat, or the bus is too low for me to get underneath enough to connect it.
Cock
Oh well, looks like Monday's the day then.
sparkywig
sparkywig
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyTue Jan 21, 2014 10:49 pm
13th January 2013
Back to where I was at 1100 on Saturday morning.
rusty nail to sow's ear - Page 20 001_zpscfe8e588
Engine turns over very slowly, I think the battery may be kippered so I've got a 60Ah on charge over night to try sometime tomorrow.
Perhaps having the engine stood for a year hasn't helped, although it does turn over with a spanner on the crank nut.
The good news is the fuel gauge works now. Very Happy
sparkywig
sparkywig
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyTue Jan 21, 2014 10:50 pm
14th January 2014
It runs, thank fuck for that.
rusty nail to sow's ear - Page 20 Th_002_zps138acd02
At midday today there was a possibility that it was being dropped out and stripped.
Almost 7 hours (over a couple of days) of hand turning and oiling the bores to try and get it to loosen up. Eventually it loosened enough for the starter to turn it, oil pressure achieved and then fired up.
Cam burn done, timing set, just need a fiddle with the mixture, and then change the oil and filter. Oh, and fit the oil line P clips when they turn up.
The moral is, don't leave a built engine on the bench for 14 months. Neutral
sparkywig
sparkywig
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyTue Jan 21, 2014 10:51 pm
18th January 2014
OK then, next job.
Off came the leaky and rotten folding sunroof and then various strengthener pieces to leave a nice clean gaping hole in the roof.
rusty nail to sow's ear - Page 20 003_zps736f57be
rusty nail to sow's ear - Page 20 C4778AF7-BF09-4215-B180-5F4FD4FE98A0_zps2f69000c
rusty nail to sow's ear - Page 20 005_zpsfd78897c
Perfect fit.
rusty nail to sow's ear - Page 20 006_zpsf74442f3
It's just tekscrewed down temporarily so it doesn't fly across the yard in any inclement weather we may have between now and my next visit.
Welding to follow next weekend all being well.
sparkywig
sparkywig
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyTue Jan 21, 2014 10:52 pm
Dropped into the yard for a couple of hours roof fettling.
Bit more work than anticipated due to previous owners. Always wondered why the bus had a bit of flex at roundabouts and across camping fields.
rusty nail to sow's ear - Page 20 001_zps1aba8325
rusty nail to sow's ear - Page 20 002_zpsaeb88a13
Laughing
Whoever butchered the oversize hole for the sunroof moved the roof brace but obviously only for the courtesy light. 4" short either end and 4 pop rivets to the roof skin.
Looks like a bit of extra work getting this one back in properly.
At least the rear one fits better.
rusty nail to sow's ear - Page 20 003_zps503b4f8b
Roof trimmed back and cap on ready for welding this weekend.
Bit of gaffa tape over the seams to stop the rain getting under.
rusty nail to sow's ear - Page 20 004_zpsc11bd2aa
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyWed Jan 22, 2014 7:23 pm
Looking really good - I've just caught up on the whole thread Smile
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyTue Feb 18, 2014 1:03 pm
Looks ace!
sparkywig
sparkywig
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyWed Feb 19, 2014 6:01 pm
Thanks, here's a bit more to catch up on.
Sat 25th January 2014
Half way round.
rusty nail to sow's ear - Page 20 004_zpsf2f4b04a
Looks much better already.
rusty nail to sow's ear - Page 20 005_zpsdd5e0bfb
Smile
sparkywig
sparkywig
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyWed Feb 19, 2014 6:02 pm
Sat 1st February 2014
Welding and grinding finished at last. Primer on ready for filling next week.
rusty nail to sow's ear - Page 20 005_zps922f9706
rusty nail to sow's ear - Page 20 004_zps3dea0930
rusty nail to sow's ear - Page 20 002_zps23da4557
rusty nail to sow's ear - Page 20 001_zps539a30d5
sparkywig
sparkywig
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyWed Feb 19, 2014 6:03 pm
Friday 7th February 2014
Right then, now that the roof's done.
OK you're right, it's not, still need to fill and paint.
But I've not been happy with the shut of the rear hatch and it leaks as well.
rusty nail to sow's ear - Page 20 001_zpsd7a4aed1
So I've cut the off-side of the opening out and will put it back perfectly aligned tomorrow. Very Happy
sparkywig
sparkywig
Saturday 8th February 2014
Rear hatch shuts perfectly now, and a bit of filler on the roof.
rusty nail to sow's ear - Page 20 003_zps665ef799
rusty nail to sow's ear - Page 20 005_zps4a14a532
rusty nail to sow's ear - Page 20 006_zpsb230adf1
I was planning to paint the roof tomorrow, but the gearbox on the DA decided to spray itself across the workshop.
Ended up having to buy a cheap (£38!!) one in B&Q on the way home so I can get the sanding finished in the morning.
sparkywig
sparkywig
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyWed Feb 19, 2014 6:05 pm
Sunday 9th February 2014
Got to crack on this week, I haven't driven it properly for a couple of months now and it needs shaking down and a "new" interior fitting before we go away at Easter.
After some more filling and sanding this morning, on went a coat of primer.
rusty nail to sow's ear - Page 20 001_zpseca4f9f5
rusty nail to sow's ear - Page 20 002_zps141f28f6
rusty nail to sow's ear - Page 20 003_zpsf58ff2e2
rusty nail to sow's ear - Page 20 004_zps37d9104e
rusty nail to sow's ear - Page 20 005_zps5b9cfd46
rusty nail to sow's ear - Page 20 006_zps783c028b
A bit more filling and sanding and then a satin black guide coat.
rusty nail to sow's ear - Page 20 009_zps3c072fab
rusty nail to sow's ear - Page 20 008_zps89d69729
rusty nail to sow's ear - Page 20 007_zpsd4db51b7
Needs a bit more filling and the roof sanding back, but I'm happy with it so far.
And the DA sander is OK as well.
sparkywig
sparkywig
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyWed Feb 19, 2014 6:06 pm
Monday 10th February 2014
I spent this morning finishing off the rear corner and getting the hatch seal channel done, and more roof sanding.
The place I usually get my paint mixed has recently been taken over, and the new paint is shite. Too thin, like water, there's next to no coverage and it runs like buggery.
I'll need to rub it back when the weather improves and do it again. Sad
sparkywig
sparkywig
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyWed Feb 19, 2014 6:08 pm
Tuesday 11th February 2014
Today I have been mostly sanding the roof.
rusty nail to sow's ear - Page 20 002_zps99ca91c5
rusty nail to sow's ear - Page 20 001_zps8ac28052
sparkywig
sparkywig
Friday 14th February 2014
Today I have been mostly sanding the roof again, in the rain.
rusty nail to sow's ear - Page 20 001_zpsaff902cf
rusty nail to sow's ear - Page 20 002_zpsb06f4d34
I did have to take refuge in the van at one point though....
rusty nail to sow's ear - Page 20 004_zpsed1b7e29
I think it was in a US hailstorm at some point as it has a bit more "character" than I first thought.
I'm not going to get too worried about dents and ripples, just want to get it painted.
rusty nail to sow's ear - Page 20 005_zps1f18a4e6
sparkywig
sparkywig
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyWed Feb 19, 2014 6:09 pm
Saturday 15th February 2014
Today I have been mostly waiting for the rain to stop, sanding the roof, and then waiting for the rain to stop, etc.
I also got the front roof brace extended and fitted.
Hopefully tomorrow will be better weather and I can actually get a coat of paint on the roof.
sparkywig
sparkywig
Sunday 16th February 2014
After much sanding and filling, and much more sanding and filling, I'm fed up with it so got a coat of primer on this morning.
I'm even more fed up with the roof now, the new paint as supplied is absolutely shite. No coverage and runs like fuck.
rusty nail to sow's ear - Page 20 001_zps8a20e18e
rusty nail to sow's ear - Page 20 002_zps282905e2
Looks like I shall be mostly wet sanding at some point tomorrow and then blasting satin black all over it. Rolling Eyes
At least it never rained today, which meant I could get home to sort the garage and make a bit of room.
sparkywig
sparkywig
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyWed Feb 19, 2014 6:11 pm
Tuesday 18th February 2014
Roof, day 8...
Finished work early as it was a fine day and dropped down the yard to get on with the bus.
I've had enough of the roof, and other than bare metalling it this was as good as it was going to get.
A final fill and sand.
rusty nail to sow's ear - Page 20 001_zps9ea7811c
Then paint.
rusty nail to sow's ear - Page 20 002_zpse734c3b8
sparkywig
sparkywig
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptyWed Feb 19, 2014 6:13 pm
Wednesday 19th February 2014
All this mucking about with the roof means that I'm behind with "other projects".
I think it's time to start the Westfakia interior.
One £20 full width Westy bed in need of tlc.
rusty nail to sow's ear - Page 20 001_zps99cd5142
One naked full width bed.
rusty nail to sow's ear - Page 20 002_zps22b8a3e3
There's a couple of suspicious stains on the ply, but these will sand off. At least it doesn't smell so much now.
Need to fit the seat base supports and then mock it all up in the bus when it gets home this weekend.
This is next to get the treatment.
rusty nail to sow's ear - Page 20 Westfaliacookerunit_zps9bbfb83a
Anybody got a Continental drop down cooker spare?
sparkywig
sparkywig
PostSubject: Re: rusty nail to sow's ear   rusty nail to sow's ear - Page 20 EmptySat Mar 15, 2014 8:46 pm
Right then, where were we?
Page 20 of 22Go to page : Previous  1 ... 11 ... 19, 20, 21, 22  Next
» The 16D Rapidfire Nail Gun
» Blister under toe nail (but not a blood blister/black toenail)
» How to get rims and hubs off stuck axles.
» PROSPECTING FOR PLACER GOLD AND GOLD VEINS.
» Another water pump seal gone bad
