| ALLY RESTORATION EPESODE 2 | |
+9joker 67 nomates big dave itsabuglife dubberatlast Gungemyster HRD Mr Scoops The G 13 posters |
The G DBS Pervert
Number of posts : 613 Age : 48 Location : Bridgwater My Ride(s) : 1983 T25 Registration date : 2009-02-06
| Subject: ALLY RESTORATION EPESODE 2 Sun Jun 26, 2011 10:40 pm | |
| Subject: Re: ALLY RESTORATION EPESODE 2 Mon Jun 27, 2011 6:50 am | |
| It's looking good though Dude. Best to take your time and get it right, a bummer you'll miss it this summer but it'll be sorted then. | |
HRD DBS Old Timer
Number of posts : 1507 Age : 45 Location : Bridgwater!!!!!! My Ride(s) : Too many to list! Registration date : 2009-05-04
| Subject: Re: ALLY RESTORATION EPESODE 2 Mon Jun 27, 2011 8:20 am | |
| very good work mate, wish i can to that!! | |
| Subject: Re: ALLY RESTORATION EPESODE 2 Mon Jun 27, 2011 11:10 am | |
| Nice work sir!! Very soon your bus will have nearly as much metal in it as you do!! | |
| Subject: Re: ALLY RESTORATION EPESODE 2 Mon Jun 27, 2011 1:30 pm | |
| Subject: Re: ALLY RESTORATION EPESODE 2 Mon Jun 27, 2011 6:19 pm | |
The G DBS Pervert
| Subject: Re: ALLY RESTORATION EPESODE 2 Tue Jun 28, 2011 8:15 pm | |
The G DBS Pervert
| Subject: Re: ALLY RESTORATION EPESODE 2 Tue Jun 28, 2011 8:17 pm | |
| I going to put allot more seam sealant on when I have finished all the panel and before I start on the next. | |
big dave DBS Old Timer
Number of posts : 1744 Age : 46 Location : W-s-M My Ride(s) : 72 type 1 for sale, 67 Ragtop, Registration date : 2009-03-09
| Subject: Re: ALLY RESTORATION EPESODE 2 Tue Jun 28, 2011 8:46 pm | |
| Nicely done make sure the sealant is over-paintable fella.... | |
| Subject: Re: ALLY RESTORATION EPESODE 2 Tue Jun 28, 2011 10:07 pm | |
| good on ya......no mean feat changing the whole panel ....it will give you lots of confidence to tackle future repairs .....and well done for taking the time to post the piccies too | |
| Subject: Re: ALLY RESTORATION EPESODE 2 Tue Jun 28, 2011 10:42 pm | |
| Subject: Re: ALLY RESTORATION EPESODE 2 Wed Jun 29, 2011 7:52 am | |
| - The G wrote:
- I going to put allot more seam sealant on when I have finished all the panel and before I start on the next.
make sure you etch prime beforee putting sealer in, then seal it up, and wipe away the excess with panel/spirit wipe, going across the panel gap and this will give you a good panel seal. ready to paint over. as once its dry you cannot sand the sealer down, as it tears and flakes and makes the joint look horrible. hope this will help you. also around the inside of the arch use a panel adhesive and that will save welding the arches together. | |
| Subject: Re: ALLY RESTORATION EPESODE 2 Wed Jun 29, 2011 8:53 am | |
| good work mr G
who did you get your panels from, and are they a good fit? | |
The G DBS Pervert
| Subject: Re: ALLY RESTORATION EPESODE 2 Thu Jun 30, 2011 7:03 pm | |
| - griff wrote:
- good work mr G
who did you get your panels from, and are they a good fit? I got them from HERITAGE, there not bad but needs a bit of fetlin. | |
The G DBS Pervert
| Subject: Re: ALLY RESTORATION EPESODE 2 Thu Jun 30, 2011 7:08 pm | |
also around the inside of the arch use a panel adhesive and that will save welding the arches together. Cheers bud, I may have got a bit ahead of my self with the sealant doh lesson learnt for the next. I want to completely finish the one before I go on to the next as this is the trial and error one. I'm thinking of using a brush on seam sealant to cover and protect after the etch prim, any recommendations ? Iv used tiger seal on a gun up to know. | |
| Subject: Re: ALLY RESTORATION EPESODE 2 Thu Jun 30, 2011 7:20 pm | |
| my very limited bodywork knowledge... you need to use seam sealer as its silicone free and wont react when paint is applied. (but it is highly flammable as i found once, lol, so make sure all welding is finished). any panel shop type place will have it. i would brush it on and smooth it with a gloved finger. you could also mask off to give a clean line | |
alflars bus Blitzen Regular
Number of posts : 121 Age : 47 Location : Worle My Ride(s) : 1989 T25 panel van, (marge) & picasso family car Registration date : 2011-03-08
| Subject: Re: ALLY RESTORATION EPESODE 2 Thu Jun 30, 2011 7:37 pm | |
| Nice work dude, Im not brave enough to cut panels out, but I guess its the best way to loose the rust. | |
| Subject: Re: ALLY RESTORATION EPESODE 2 Fri Jul 01, 2011 8:41 am | |
I'm thinking of using a brush on seam sealant to cover and protect after the etch prim, any recommendations ? Iv used tiger seal on a gun up to know. you need to get the panels almost prepped for paint, then seal them up using a gun and tiger seal is ok, run sealer into the joint, then get some mutton cloth, and soak it in spirit.panel wipe then wipe the sealer into the joint and clean the excess off with the mutton cloth as you go, this should then give you a nice it of sealer in the joint and keep it clean as well. if the panel joint is vertical, you need to wipe away horizontal , and keep the cloth soaked and tight. you will be better taking the sealer out you have put in and re-prep the area again.use a clean and strip wheel for this . andy | |
| Subject: Re: ALLY RESTORATION EPESODE 2 Sat Jul 02, 2011 4:33 pm | |
| the problem with tiger seal ......is it will crack any paint ...if you want to 'over paint 'it .....seam sealer is best ,but buy it in tubes to go in a silicone gun ......I will only use iger seal to bond panels on now | |
| Subject: Re: ALLY RESTORATION EPESODE 2 Sat Jul 02, 2011 7:25 pm | |
- the problem with tiger seal ......is it will crack any paint ...if you want to 'over paint 'it .....seam sealer is best ,but buy it in tubes to go in a silicone gun ......I will only use iger seal to bond panels on now
sika flex for me, best sealer i have used. | |
The G DBS Pervert
| Subject: Re: ALLY RESTORATION EPESODE 2 Sat Jul 23, 2011 7:27 pm | |
The G DBS Pervert
| Subject: Re: ALLY RESTORATION EPESODE 2 Sat Jul 23, 2011 7:31 pm | |
| As you can see there are still ripples in the panel but I'm going to get the guy who dose the respray to go over the van and put right the odd bits. | |
| Subject: Re: ALLY RESTORATION EPESODE 2 Sat Jul 23, 2011 8:29 pm | |
| nice one ...good and solid | |
The G DBS Pervert
| Subject: Re: ALLY RESTORATION EPESODE 2 Sun Aug 07, 2011 2:49 pm | |
| Subject: Re: ALLY RESTORATION EPESODE 2 Sun Aug 07, 2011 3:41 pm | |
| Looking good bud, keep them pics coming | |
| Subject: Re: ALLY RESTORATION EPESODE 2 | |
