 Shorty's 1969 Kombi
Go to page : Previous  1, 2, 3 ... 10, 11, 12, 13  Next
Shorty's 1969 Kombi - Page 11 Empty
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptyThu Nov 07, 2013 7:03 pm
Yeah, very common to break at that point.
Sometimes the cables too long and you end up with the screw tightened on the cable and not on the metal end.
Always handy to carry those white electrical plastic blocks (Europa terminal blocks with the metal connectors - http://www.ebay.co.uk/itm/like/190926377724?hlpht=true&ops=true&viphx=1&lpid=95&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=95&ff19=0 ) that they use for wiring. It has saved me in the past, allowing me to rejoin both halves until home.
You can also use them on the heater cables that attach to the heat exchangers when they break, repair seems to last longer than new ones.
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptyThu Nov 07, 2013 7:11 pm
Good shout that is..
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptyThu Nov 07, 2013 10:50 pm
Looking good matey. Always carry a spare clutch and accelerator cable Wink
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptyWed Nov 13, 2013 9:22 pm
Loving this Bus Carl, it's gonna be a stunner!
Shorty's 1969 Kombi - Page 11 Pbucket
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptyThu Nov 14, 2013 12:05 pm
i do like this
what you going to be doing with the interior
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptyThu Nov 14, 2013 12:39 pm
i do like this
You'll find out! All in good time dear boy!
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptyFri Nov 15, 2013 6:23 pm
New 'universal' accelerator cable fitted this afternoon.. Quite pleased with it if I'm honest, seems much better than the other one I had that turned out the be too short...
Anyway, I'm a bit pissed off with the bus this afternoon... The engine has been running fine for weeks now, but it ran dry last weekend and now I can't get the bugger to start after putting in more fuel....
I am going to check for dirt in the filter and jets, although surely, all 4 jets cannot be blocked simultaneously? Also go to whip out the plugs and give them a clean just incase they're soothed up as a result of running it at idle only since it first started up.. Will also check for a spark...
Watch this space! The battle continues!
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptyFri Nov 15, 2013 9:12 pm
Have you had the petrol tank out of the bus?
Done any restoration on it, etc.
Beetle tanks have a filter fitted to the exit pipe inside, is it the same for the bus?
Like this:
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-111-209-147-A
Other fuel parts in the search may help:
http://www2.cip1.com/SearchResults.asp?Search=fuel+tank&sort=7&Search1=Search
Sorry about the search not being UK it was the first quick link I had.
Here's a complete set from UK:
http://www.vwheritage.com/vw_spares_Fuel-tank-tube-kit-w-filter-T1-T2-74-Carb-m-10-113298221AF_act_shop.product_pID_209716.htm?crumbStartPage=2&crumbStartRow=16
Just wondered if by running it dry you may have debris around the exit/feed pipe inside the tank that could possibly be affecting fuel flow and you may be looking for the problem too far down the line instead of at source.
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptySat Nov 16, 2013 6:37 am
It's a fair shout.... But I do hope you're wrong! This would be a proper set back at this stage of the game......
Thanks for the input, it's appreciated...
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptyThu Nov 21, 2013 11:27 pm
Have you had any luck sorting out your starting/running problems?
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptyFri Nov 22, 2013 5:46 am
I think so.. The fuel pump was found to be missing the spindle about which the level that operates it rotates... I'll get you a picture... It was there in previous photographs but is missing now... Must have worked itself out and onto the floor of my garage...
Anyway, I've got a new pump ready to go on do should be fine again now...
Took some tracking down though - had to be pretty methodical!!
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptyFri Nov 22, 2013 4:22 pm
I think the word you are looking for is 'anal'!
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptySat Nov 23, 2013 4:43 pm
Who would have thought to suggest you looking for a solution with the part missing from your fuel pump.
How random is that for that part to disassemble. (and you say, well I never touch that bit)
Glad you had success in finding your problem, nothing worse than head scratching and fixing/switching parts and then nothing solves a problem.
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptySat Nov 23, 2013 4:57 pm
Here's the offending item!
Shorty's 1969 Kombi - Page 11 5A018D3B-6201-4A8B-A385-92F8EAEB6052
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptySat Nov 23, 2013 4:59 pm
Once I replaced the fuel pump, I drove it out of the garage for the first time!
Shorty's 1969 Kombi - Page 11 3DD78A59-EDDB-4700-8DE4-14FCF6C12336
Shorty's 1969 Kombi - Page 11 CBA6B18A-BFBF-4E97-B3F8-27DF5679C735
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptySun Nov 24, 2013 8:57 am
looking good
Shorty's 1969 Kombi - Page 11 B9d2fd24
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptySun Nov 24, 2013 9:33 am
Nice work Carl, you must be stoked!
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptySun Nov 24, 2013 2:06 pm
Honestly, I'm like a little kid! every spare second I get I go out to the garage for a quick look at it... I know I shouldn't, but I love just giving the key a turn and letting her run for 5 minutes...
I'm also building confidence with it now, I want identify anything wrong before I out the kids in it!
She runs lovely btw.. and haven't had the timing or mix fully sorted yet and its already better than my westy ever was!
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptySun Nov 24, 2013 6:07 pm
looks spot on, must have been great getting it out under its own steam Very Happy
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptySun Jan 19, 2014 4:11 pm
I've been going through the list this weekend getting as ready as I can for it's MOT next saturday....
Jobs completed:
1) Install front shock absorbers
2) Install oil breather kit
3) Install jail bars on rear window (not MOT essential I know, but you gotta have some fun right!?!)
4) Install roundel
Here's some photo's
Shorty's 1969 Kombi - Page 11 845F9779-D4D5-40BD-9140-D9DC79328C70_1
Shorty's 1969 Kombi - Page 11 B3C37C06-6D99-4203-80EC-E5A7CEAE83CA
Shorty's 1969 Kombi - Page 11 DADCC371-A6B2-42BA-B7A3-B95DCF6910CE
64 Split
Male Number of posts : 469
My Ride(s) : 64 split, eriba familia 1964,73 412 square,a class 220amg sport, fiat 500 sport
Registration date : 2011-03-23
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptySun Jan 19, 2014 4:56 pm
Good luck with the mot dude.....it wil make you smile for weeks, I am sure here will be little probs.....
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptyMon Jan 20, 2014 1:29 pm
Best of luck on the MOT !
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptyMon Jan 20, 2014 1:41 pm
Mots are over rated.
Good luck dude!
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptyWed Apr 16, 2014 7:59 pm
forgot to mention (on here anyway!), passed the MOT first time with no advisories..  very happy about that!!
Since then I have registered it the the DLVA and got the V5C, updated MOT and tax disc (it's free but you still have to display one for the time being)
I can now get plates made up and get on the road...  I've got a few problems that stop me doing that at the moment, but I did fabricate some up on the printer at work - the fuzz didn't seem too fussed when they were following me earlier this evening...
ah yes, this evening..  took it out for it's maiden voyage!  Smile
I got a case of the fuck-its and headed out on a little evening jolly..
Shorty's 1969 Kombi - Page 11 F941CF21-CE1E-4208-8C58-F1A8F2333CBB
Shorty's 1969 Kombi - Page 11 0FA317D2-B829-4ADD-A66E-4166435B03EF
PostSubject: Re: Shorty's 1969 Kombi   Shorty's 1969 Kombi - Page 11 EmptyWed Apr 16, 2014 8:08 pm
nice one mate
Shorty's 1969 Kombi
Page 11 of 13Go to page : Previous  1, 2, 3 ... 10, 11, 12, 13  Next
» 1969 Honda z50 Mini Trails
» I seem to be new here. 1969? Sears Suburban
» 1969 FJ40 for sale
» Mystic Wetsuits, Board Bags, Harness's
» Project Big Cat
