 My 'bit on the side'
Go to page : Previous  1, 2, 3
My 'bit on the side' - Page 3 Empty
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptySun Feb 05, 2012 10:38 am
SimonABT wrote:
Really? That's handy to know as i need a few things. is he local?
bridgwater i will find him on face book and post a link
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptySun Feb 05, 2012 11:04 am
that looks cool , perhaps they use ali plate over the sunroof hole for less weight?
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptySun Feb 05, 2012 1:29 pm
Awesome Si, looking awesome
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptySun Feb 05, 2012 5:51 pm
Cheers Smile
I did about an hours work on the car today but got cold and hungry so went home. Rolling Eyes
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptySun Feb 05, 2012 7:46 pm
https://www.facebook.com/profile.php?id=100000938140741
i can work out how to link to the bit with his ad in for the corrado. i will pm his number to you.
edit
i will when i get it, as my old phone deleted my phone book.
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptyTue Mar 06, 2012 2:59 pm
Havent updated for a while so.....
Made up some brackets to hold the sunroof panel in place until we weld it properly.
My 'bit on the side' - Page 3 2012-02-05162825
Robbed a scrap Corrado of its Dash heater, cleaned it all out, fitted new Matrix and bolted it up
My 'bit on the side' - Page 3 406424_10150543271132723_552862722_9381967_1487691488_n
Also got hold of a Mk4 Golf V6 4 motion throttle pedal (flyby), made up a bracket and modified the Corrado pedal box to allow fitting of the mk4 pedal
My 'bit on the side' - Page 3 420504_10150543272422723_552862722_9381977_1380828163_n
My 'bit on the side' - Page 3 430163_10150543272942723_552862722_9381979_1827898159_n
Made up a custom subframe for the seats to bolt to.
My 'bit on the side' - Page 3 426491_10150553672757723_552862722_9420193_1145915315_n
Only problem with this is the seats wont go back any further due to the seat (ears) hitting cage, and the seat wont go any lower. The position of the seat is perfect for my driving position, but its a bloody mission getting in and out of the seat due to steering wheel and side impact bars being in the way. Im actually worried it could be an MOT failure if the tester cant get in the car. Rolling Eyes
Oh and also got the Electric spoiler working manually. Cool
My 'bit on the side' - Page 3 431659_10150544843077723_552862722_9389517_1619448232_n
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptyTue Mar 06, 2012 4:07 pm
Gone are the days when you could drive your own car on the ramps and sit in it while the test was done...it doesnt seem that long ago either...i must be getting older lol
looks great though Si, lots and lots of work gone into that! bloody good job!
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptyTue Mar 06, 2012 6:46 pm
I still do this for my motier Cool
Nice work si afro
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptyTue Mar 06, 2012 9:32 pm
Nice work si afro
There you go Si...if the fella fails it cos he can't get in it then get carl to take it to his guy, robert's ya mother's brother Wink
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptyWed Mar 21, 2012 7:34 pm
An update WITH PICS Very Happy
Cage is fully finished, and managed to get it in primer today. What a pig of a job that was. Not looking foward to putting topcoat on Mad
My 'bit on the side' - Page 3 2012-03-21180642
My 'bit on the side' - Page 3 2012-03-21180703
My 'bit on the side' - Page 3 2012-03-21180732
My 'bit on the side' - Page 3 2012-03-21180759
And i made up some brackets so that i can re-fit the original dashboard (needed cutting about) but will fit around cage
My 'bit on the side' - Page 3 2012-03-21181150
Made up some subframes for the seats, but they just sat too high and was a nightmare trying to get in / out of the car. So had a rethink and made these. I have checked my little blue MSA reg book and it seems legal as ive used correct thickness steel. So hopefully should be ok.
Seats now sit perfectly, are plenty low enough and sit further back for my long legs. (still need to drill holes in pic)
My 'bit on the side' - Page 3 2012-03-21180813
Modified the exhaust tunnel so i can use the Mk4 Golf cable shifter unit, but mount it inside the car ontop the tunnel, this allows selecting gear much easier when sat in the bucket seats as the shifter is so much higher.
My 'bit on the side' - Page 3 2012-03-21181255
And finally fitted the sunroof panel. Did this by making up some temp brackets to hold the steel panel in place, and get the gaps perfect. Then cut some solid bar to fit underneath. The bar is slightly bigger than the gaps. Then welded either side of the bar to prevent the roof warping.
So the roof is solid, but to fill the gap ontop we used seamsealer to fill the bulk of the gap, then when that dries will rub it down and put another thin layer ontop. Then once its all dry, sand it down and paint. I dont know how it will look, and i may end up changing my mind afterwards but will have to wait and see how it turns out.
My 'bit on the side' - Page 3 2012-03-21181006
More progress tommorow hopefully. Very Happy
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptyWed Mar 21, 2012 9:52 pm
Looking Cool there Si, it will be great when its finished Twisted Evil Twisted Evil
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptyThu Mar 22, 2012 8:44 pm
Paint Cool
My 'bit on the side' - Page 3 2012-03-22161609
My 'bit on the side' - Page 3 2012-03-22161759
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptyThu Mar 22, 2012 8:59 pm
Lovin' it
Wanna trailer it up to Sandown for the club stand? Very Happy
My 'bit on the side' - Page 3 Pbucket
Tigger
Tigger
Male Number of posts : 106
My Ride(s) : T4, Caddy Maxi, Golf, SV1000SZ, Polo
Registration date : 2012-03-14
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptyThu Mar 22, 2012 9:02 pm
Cracking build. Cool
Just wish I had the time to do a build like this.
Got the offer of a part finished kit car but know that I cant commit enough time to the build. Sad
Keep up the good work. sunny
http://centurion-electrical.co.uk
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptyFri Mar 23, 2012 8:02 am
Cheers.
to be honest i havent got the spare time either, i always have to sacrifice something else to go and work on the car, and i wont lie when i say it causes a fair few rows with the wife. Hopefully she will see the effort was worth it when i let her take it round the track a few times.
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptyMon Apr 30, 2012 7:57 pm
Havent really done much to this thing for a while due to starting a new job, but managed to do a few little things..
Fitted the seats and loosely fitted the harnesses
My 'bit on the side' - Page 3 2012-04-21135854
Modified the Mk4 Golf Shifter, made some straps to mount it (still yet to bolt it in) and re-routed the cables through the bulkhead to the gearbox
My 'bit on the side' - Page 3 2012-03-28155753
Hacked apart a Corrado Centre console.......
My 'bit on the side' - Page 3 2012-04-28103822
.....so that i could make this to mount my Oil pressure, Oil temp gauges and some switches for fans, fuel pump, etc. (work in progress)
My 'bit on the side' - Page 3 2012-04-28121111
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptySat May 19, 2012 9:41 pm
Rear axle out to be polybushed, new brakes and new anti-roll bar fitted
My 'bit on the side' - Page 3 540025_10150771205897723_552862722_9939938_1982091925_n
Drilled some holes
My 'bit on the side' - Page 3 524893_10150771203407723_552862722_9939930_782060288_n
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptySun May 20, 2012 10:46 pm
wow - now that is a proper project! amazing mate
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptySat Jun 09, 2012 8:32 pm
Bought myself a new Camera, (even though i havent got a clue how to use half the settings yet) i thought i'd take some snaps of the Corrado.
Havent done anymore to this car, although i have just bought an Engineless Corrado for spares for a good price.
My 'bit on the side' - Page 3 Picture023
My 'bit on the side' - Page 3 Picture018
My 'bit on the side' - Page 3 Picture017
My 'bit on the side' - Page 3 Picture010
My 'bit on the side' - Page 3 Picture027
More progress in the next few weeks hopefully!
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptySun Jun 10, 2012 8:21 pm
Love the new roof mod!
PostSubject: Re: My 'bit on the side'   My 'bit on the side' - Page 3 EmptySun Jul 01, 2012 8:08 pm
Bought an Engine/running gear-less 'spare' Corrado last weekend for basically beer tokens.
It has got all the small parts im missing from the Silver car, i.e. mirrors, door handles, door seals, clips, etc.
Shame to break it really as it is so tidy and its a non sunroof shell Crying or Very sad
My 'bit on the side' - Page 3 2012-06-24134530
My 'bit on the side' - Page 3 2012-06-24140533
Page 3 of 3Go to page : Previous  1, 2, 3
» PROSTAR 6 A SIDE LEAGUES
» UTV/SIDE X SIDE RIDE AT LORETTA LYNN'S
» 2012 Cat Side x Side
» Side Pressure
» Southern Side x Side Riders on the trail at Winrock ( Video )
