| My 'bit on the side' | |
+12griff Cleverchap HRD vwbeetlebum vietnam WizBizMartin joker 67 clockwork Mr Scoops Gungemyster tango_van SimonABT 16 posters |
| Subject: Re: My 'bit on the side' Mon Oct 31, 2011 8:33 pm | |
| niiiice, cant wait to see the cage in | |
| Subject: Re: My 'bit on the side' Tue Nov 01, 2011 8:06 am | |
| Ive cut the cage into 3 sections now. I researched where im allowed to cut to keep it in compliance. So fitting it should be fairly straight foward now..... i hope! | |
| Subject: Re: My 'bit on the side' Tue Nov 08, 2011 6:24 pm | |
| So..... fitted new Clutch, flywheel, bearing, and an O2J 5 speed gearbox from a Golf V5. (aparantly the ratio's are better?!) Lifted the engine into the engine bay The oil filter housing and cooler needed to be removed as it fouled the front engine mount, so i need to work out how im going to fit it back on with enough clearance, or maybe modify the engine mount? | |
| Subject: Re: My 'bit on the side' Mon Nov 14, 2011 8:23 am | |
| So not sure if anybody is that interested in this build as its not very fitting with the forum, but as its the only build thread ive got going i may aswell keep it going if thats ok with people?! Had a busy weekend. After a lot of measuring, swearing, cut knuckles, and a smashed windscreen, we got the 3 cut sections of cage into the car. Spend ages getting it all to sit right by using loads of rachet straps and blocks of wood to hold it together. Marked where the mountings attach to the body and welded in some re-inforced pates, tacked the cage in place, re-measured and adjusted where necessary. Once we were 100% happy i got dad to work his magic and weld the cage in. I have a pic of the cage tacked in place but not fully welded. It was dark when we finished last night so didnt get any finished pics. I need to clean a few welds up, the rub down the cage and inside of the car which will then be painted Metallic Grey to match engine bay. | |
| Subject: Re: My 'bit on the side' Mon Nov 14, 2011 8:55 am | |
| We're definately interested Si, keep up with the updates. | |
Number of posts : 7198 Age : 51 Location : Wouldn't I like to know My Ride(s) : Rollercoaster Registration date : 2009-08-09
| Subject: Re: My 'bit on the side' Mon Nov 14, 2011 10:07 am | |
| Yeh keep it up fella, watching this, proper interested to see how it turns out.
You got any pics of the engine bay before you started to rearrange it after your mates attempts? | |
| Subject: Re: My 'bit on the side' Mon Nov 14, 2011 10:15 am | |
| Great work Si, but can I ask how you are going to put the sunroof in?? | |
| Subject: Re: My 'bit on the side' Mon Nov 14, 2011 3:55 pm | |
| - clockwork wrote:
- Yeh keep it up fella, watching this, proper interested to see how it turns out.
You got any pics of the engine bay before you started to rearrange it after your mates attempts? Yeah i think i do. I will try and find it - Gungemyster wrote:
- Great work Si, but can I ask how you are going to put the sunroof in??
The Corrado uses a Steel panel sunroof (instead of glass panel) so ive removed all the sliders and mech and will weld the panel in, then seal around the edge. I was going to use a fibreglass panel but the regs state it needs to be metal. A lot of people just rivet a sheet of Aluminium over the roof hole, but i personally think it looks messy -In the previous picture its hard to tell how the sunroof will fit. A section of the sunroof underside will need removing in order to clear the top cross bar of the cage. | |
| Subject: Re: My 'bit on the side' Mon Nov 14, 2011 4:42 pm | |
| The alloy plate may look messy, but a lot less chance of warping the roof from the mig!
Saying that, this is SiABT, so I know it will be a good job either way. | |
| Subject: Re: My 'bit on the side' Tue Nov 15, 2011 8:38 am | |
- The alloy plate may look messy, but a lot less chance of warping the roof from the mig!
Saying that, this is SiABT, so I know it will be a good job either way. Haha cheers fella, although ive employed dad to do the welding on the cage and sunroof as he really is top man. If it warps badly then the alloy plate could be an option. | |
| Subject: Re: My 'bit on the side' Mon Nov 28, 2011 5:26 pm | |
| I thought i'd try my luck and see if the Mk4 Golf V6 4 motion downpipe would fit without any modifications..... it didnt. Its not that far off, but it doesnt clear the steering joint that comes through the bulkhead. So i will be making up a complete new downpipe soon. I was also having issues with the driveshafts, the previous owner had beaten the sh!t out of the out CV's and had buggered up the thread, i tried cutting a new thread and bought some new hub nuts but it wasnt looking good. So my cousin Matt (Maltloaf on here) came to the rescue with some Mk4 Golf 1.8t driveshafts left over from his mk2 Golf 1.8T conversion. In theory they should'v fitted straight on as ive used the Mk4 Golf V5 gearbox which has 106mm gearbox flanges (instead of VR6 100mm). The shorter shaft fitted straight on with no drama, but the longer shaft is about 1" too long. So i will use the Corrado shaft but swap the CV's over. Hopefully that will work? Ive also made up a list of things i need to buy..... kinda wish i hadnt now with xmas looming closer its expense i could do without. - Mk4 Golf Flyby wire Throttle Pedal and Loom - Corrado VR6 front engine mount - Corrado VR6 Speedo / Clocks and loom - x2 Corrado seats (i need the subframes from them as they sit lower than other VW's) - 288mm Front brake Discs - Corrado VR6 Front Brake Calipers and Pads - New Windscreen (smashed old one whilst fitting cage) - Complete Exhaust - Mirrors - Door handles - Front indicators - VR6 oil cooler sandwich plate - External Oil cooler - Radiator and fans - Headlight Looms - Battery and length of cables to relocate in boot - Interior Heater and ducting ..... And thats what i can think of at the moment. Sure there will be plenty more. | |
| Subject: Re: My 'bit on the side' Sat Jan 21, 2012 5:40 pm | |
| Another shameful picture-less update Had a bit of a result today, took a trip to my mates VW Breaker (Volksmania in Avonmouth) and blagged a passenger side driveshaft, 288mm Brake Discs and Calipers for free! ....Useful friends! I also fitted some new front wheel bearings, track rod ends, and ball joints and then fitted up the Brakes on one side. I am on the look out for a set of braided lines, i did bid on some on Ebay last week but got out bid in the last minute by 50p without realising. Oh well, its getting there slowely..... its 1st race day Saturday 28th April so i need to get cracking!!! | |
| Subject: Re: My 'bit on the side' Sat Jan 21, 2012 5:47 pm | |
| Pics Si!! come on!! lol
cant wait to see this | |
| Subject: Re: My 'bit on the side' Sun Jan 22, 2012 6:30 pm | |
| Haha yeah i know i know. will take pics soon. :-) | |
| Subject: Re: My 'bit on the side' Thu Feb 02, 2012 12:18 am | |
| Subject: Re: My 'bit on the side' Fri Feb 03, 2012 2:46 pm | |
| Hopefully my new driveshaft and Caliper Carrier bolts will arrive at Heritage VW stealers tomorrow so i can finally get the car on its wheels. Not looking foward to working in the ice cold conditions tomorrow though. | |
| Subject: Re: My 'bit on the side' Fri Feb 03, 2012 7:56 pm | |
| ...this thread is still WORTHLESS!
Seriously though I can't wait to see more of your build! | |
| Subject: Re: My 'bit on the side' Fri Feb 03, 2012 8:02 pm | |
| ok...lets spell it out.......
PEE.EYE.SEA.TEA.YOU. ARE. E.ESS
HRD DBS Old Timer
Number of posts : 1507 Age : 45 Location : Bridgwater!!!!!! My Ride(s) : Too many to list! Registration date : 2009-05-04
| Subject: Re: My 'bit on the side' Fri Feb 03, 2012 8:44 pm | |
Cleverchap DBS Pervert
Number of posts : 895 Age : 48 Location : ɹǝpun uʍop My Ride(s) : '65 split with a difference Registration date : 2007-01-08
| Subject: Re: My 'bit on the side' Sat Feb 04, 2012 12:19 am | |
| Wow this thing is going to kick ass.
Keep going and don't loose the faith. | |
| Subject: Re: My 'bit on the side' Sat Feb 04, 2012 8:40 pm | |
| ....back on her wheels! Hopefully whilst the wife is off riding her horse tomorrow i can prep the sunroof panel for welding, and maybe even get it welded in place. | |
| Subject: Re: My 'bit on the side' Sat Feb 04, 2012 8:52 pm | |
| This has come along! Looking ace | |
| Subject: Re: My 'bit on the side' Sat Feb 04, 2012 9:29 pm | |
| trevor from dirty pirates is breag my old 1.8 8v rado at the moment if you need anything. | |
| Subject: Re: My 'bit on the side' Sun Feb 05, 2012 10:03 am | |
| Really? That's handy to know as i need a few things. is he local? | |
| Subject: Re: My 'bit on the side' | |
