 gearbox loom question.
gearbox loom question. Empty
PostSubject: gearbox loom question.   gearbox loom question. EmptySun Jul 10, 2011 9:13 am
Chaps -
I appear to have fitted a later series gearbox than the car initially had, any ideas how to wire from the older 2 pin reverse light switch to the later four pin plug?
I THINK I can patch across if I can find a plug to fit, if not am I best to rewire?
caddyshack
caddyshack
Male Number of posts : 641
My Ride(s) : Caddy pick up with Tischer demountable camper
Registration date : 2009-10-12
PostSubject: Re: gearbox loom question.   gearbox loom question. EmptySun Jul 10, 2011 11:57 am
Can't you swop the switch? Question
PostSubject: Re: gearbox loom question.   gearbox loom question. EmptySun Jul 10, 2011 12:29 pm
I'm not sure, I thought I would ask first.
Also, since I've got it started and running...
What should hold the choke butterfly horizontal at idle on a pierburg 2e carb? I cant drive around with my fingers in the engine?
Is there any damping material between the rad and body?
Where is best to look for clutch/throttle cable fixings?
Cheers- Matt.
» Pulley Question
» grip strength advice..ask david horne any question on grip training....
» Level Adjust Question
» Boston Qualifying Question
» Gearbox oil
