 ALLY RESTORATION EPESODE 2
The G
The G
Male Number of posts : 613
My Ride(s) : 1983 T25
Registration date : 2009-02-06
ALLY RESTORATION EPESODE 2 Empty
PostSubject: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptySun Jun 26, 2011 10:40 pm
Hi Guys, been a bit busy...
Well the dreaded seam rust has hit my bus bad so its time to cut it out.
So Iv gone with panel replacment.
ALLY RESTORATION EPESODE 2 1-NSrearfirstcut
ALLY RESTORATION EPESODE 2 2-panelcutalongarch
ALLY RESTORATION EPESODE 2 3-panelgonejustlefttodrilloutspotweldsandrusttreat
ALLY RESTORATION EPESODE 2 4-anothershotofthepanelremoved
ALLY RESTORATION EPESODE 2 5-spotweldsdrilledoutandremovingwhatsleft
ALLY RESTORATION EPESODE 2 6-BADoldrepairsnotasbadasitlooks
ALLY RESTORATION EPESODE 2 7-badrepairsgonejustnewtraetedmetal
ALLY RESTORATION EPESODE 2 8-anothershotofbadareamadgood
ALLY RESTORATION EPESODE 2 9-insideedgeofrearpanelalltreated
ALLY RESTORATION EPESODE 2 10-wheelarchremoved
ALLY RESTORATION EPESODE 2 11-firstofer-upitsnotbad
ALLY RESTORATION EPESODE 2 12-allinprimerandwaitingforthenewpanel
ALLY RESTORATION EPESODE 2 13-newpaneltackedontillabitofworktodo
ALLY RESTORATION EPESODE 2 14-rearbotomlinselookgood
ALLY RESTORATION EPESODE 2 15-slidingdoorlinestonewpanellookgood
ALLY RESTORATION EPESODE 2 16-moreslidingdoorlines
ALLY RESTORATION EPESODE 2 17-overaltisnotbad
This is the first time I have ever attempted something like this so very big learning curve but so enjoyable.
I have so much to do on this van so I recon its going to be of the road for most of the summer pale
http://www.groove-a-licious.co.uk
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyMon Jun 27, 2011 6:50 am
It's looking good though Dude. Best to take your time and get it right, a bummer you'll miss it this summer but it'll be sorted then.
ALLY RESTORATION EPESODE 2 Pbucket
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyMon Jun 27, 2011 8:20 am
very good work mate, wish i can to that!!
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyMon Jun 27, 2011 11:10 am
Nice work sir!! Very soon your bus will have nearly as much metal in it as you do!!
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyMon Jun 27, 2011 1:30 pm
Good luck bud Wink
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyMon Jun 27, 2011 6:19 pm
Fair shout dude
The G
The G
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyTue Jun 28, 2011 8:15 pm
Had another run of it today, also hit a few snags (as you do) going to sort them out on Saturday with help from a friend.
ALLY RESTORATION EPESODE 2 IMG00149-20110628-1843
ALLY RESTORATION EPESODE 2 IMG00150-20110628-1843
ALLY RESTORATION EPESODE 2 IMG00148-20110628-1843
ALLY RESTORATION EPESODE 2 IMG00151-20110628-1843
ALLY RESTORATION EPESODE 2 IMG00152-20110628-1843
ALLY RESTORATION EPESODE 2 IMG00153-20110628-1844
The G
The G
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyTue Jun 28, 2011 8:17 pm
I going to put allot more seam sealant on when I have finished all the panel and before I start on the next.
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyTue Jun 28, 2011 8:46 pm
Nicely done
make sure the sealant is over-paintable fella....
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyTue Jun 28, 2011 10:07 pm
good on ya......no mean feat changing the whole panel ....it will give you lots of confidence to tackle future repairs .....and well done for taking the time to post the piccies too ALLY RESTORATION EPESODE 2 Thumbs
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyTue Jun 28, 2011 10:42 pm
nice work G man
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyWed Jun 29, 2011 7:52 am
make sure you etch prime beforee putting sealer in, then seal it up, and wipe away the excess with panel/spirit wipe, going across the panel gap and this will give you a good panel seal. ready to paint over.
as once its dry you cannot sand the sealer down, as it tears and flakes and makes the joint look horrible.
hope this will help you.
also around the inside of the arch use a panel adhesive and that will save welding the arches together.
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyWed Jun 29, 2011 8:53 am
good work mr G
who did you get your panels from, and are they a good fit?
The G
The G
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyThu Jun 30, 2011 7:03 pm
good work mr G
I got them from HERITAGE, there not bad but needs a bit of fetlin.
The G
The G
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyThu Jun 30, 2011 7:08 pm
Cheers bud, I may have got a bit ahead of my self with the sealant doh lesson learnt for the next.
I want to completely finish the one before I go on to the next as this is the trial and error one.
I'm thinking of using a brush on seam sealant to cover and protect after the etch prim, any recommendations ? Iv used tiger seal on a gun up to know.
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyThu Jun 30, 2011 7:20 pm
my very limited bodywork knowledge... you need to use seam sealer as its silicone free and wont react when paint is applied. (but it is highly flammable as i found once, lol, so make sure all welding is finished).
any panel shop type place will have it. i would brush it on and smooth it with a gloved finger. you could also mask off to give a clean line
ALLY RESTORATION EPESODE 2 B9d2fd24
alflars bus
alflars bus
Male Number of posts : 121
My Ride(s) : 1989 T25 panel van, (marge) & picasso family car
Registration date : 2011-03-08
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyThu Jun 30, 2011 7:37 pm
Nice work dude, Im not brave enough to cut panels out, but I guess its the best way to loose the rust.
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptyFri Jul 01, 2011 8:41 am
you need to get the panels almost prepped for paint, then seal them up using a gun and tiger seal is ok, run sealer into the joint, then get some mutton cloth, and soak it in spirit.panel wipe then wipe the sealer into the joint and clean the excess off with the mutton cloth as you go, this should then give you a nice it of sealer in the joint and keep it clean as well.
if the panel joint is vertical, you need to wipe away horizontal , and keep the cloth soaked and tight.
you will be better taking the sealer out you have put in and re-prep the area again.use a clean and strip wheel for this .
ALLY RESTORATION EPESODE 2 Csd1
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptySat Jul 02, 2011 4:33 pm
the problem with tiger seal ......is it will crack any paint ...if you want to 'over paint 'it .....seam sealer is best ,but buy it in tubes to go in a silicone gun ......I will only use iger seal to bond panels on now
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptySat Jul 02, 2011 7:25 pm
sika flex for me, best sealer i have used.
The G
The G
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptySat Jul 23, 2011 7:27 pm
Panel finished,
ALLY RESTORATION EPESODE 2 IMG00173-20110713-1924
ALLY RESTORATION EPESODE 2 IMG00178-20110713-1954
ALLY RESTORATION EPESODE 2 IMG00177-20110713-1925
ALLY RESTORATION EPESODE 2 IMG00176-20110713-1925
ALLY RESTORATION EPESODE 2 IMG00175-20110713-1925
ALLY RESTORATION EPESODE 2 IMG00174-20110713-1925
Sort the left side gutter today but forgot to take pics, Planning on starting on the other panel tomorrow.
The G
The G
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptySat Jul 23, 2011 7:31 pm
As you can see there are still ripples in the panel but I'm going to get the guy who dose the respray to go over the van and put right the odd bits.
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptySat Jul 23, 2011 8:29 pm
nice one ...good and solid
The G
The G
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptySun Aug 07, 2011 2:49 pm
I been getting on with the other side.
Seemed to go a bit better but still had it hitches.
ALLY RESTORATION EPESODE 2 58
ALLY RESTORATION EPESODE 2 57
ALLY RESTORATION EPESODE 2 56
ALLY RESTORATION EPESODE 2 55
ALLY RESTORATION EPESODE 2 54
ALLY RESTORATION EPESODE 2 53
ALLY RESTORATION EPESODE 2 52
ALLY RESTORATION EPESODE 2 51
ALLY RESTORATION EPESODE 2 50
ALLY RESTORATION EPESODE 2 49
ALLY RESTORATION EPESODE 2 48
ALLY RESTORATION EPESODE 2 47
ALLY RESTORATION EPESODE 2 46
ALLY RESTORATION EPESODE 2 45
PostSubject: Re: ALLY RESTORATION EPESODE 2   ALLY RESTORATION EPESODE 2 EmptySun Aug 07, 2011 3:41 pm
Looking good bud, keep them pics coming Wink
» Ally McCoist
» 1973 Roper Motomower restoration
» 1975 ish' bolels h14 1/2 way restored carb problem
» My restored push mower.
» 1969 Honda z50 Mini Trails
