 Need PushRod Seals Replacing 2Ltr A/C!
edweed
Need PushRod Seals Replacing 2Ltr A/C! Empty
PostSubject: Need PushRod Seals Replacing 2Ltr A/C!   Need PushRod Seals Replacing 2Ltr A/C! EmptyThu Jun 02, 2011 2:45 pm
Hey All,
Can anyone help me regarding getting the pushrod seal replaced on my 2ltr aircooled camper?
Its now dropping oil all over the place and needs doing asap! i would rather someone with some A/C experience had a look rather than a general mechanic.
Any pointers would be greatly appreciated!
cheers,
edweed.
PostSubject: Re: Need PushRod Seals Replacing 2Ltr A/C!   Need PushRod Seals Replacing 2Ltr A/C! EmptyThu Jun 02, 2011 3:12 pm
where abouts are you?
i can do this if you want
you will need the green seals for the hot side and black for the other and a pair of rocker cover gaskets
if you want to try and do it yourself you will need a feeler gauge to do the valve clearances after
be warned though, it still may not seal 100% but will be loads better. i would advise new push rod tubes if yours are rusty or dented
mobile number is below if you want to give me a call
Need PushRod Seals Replacing 2Ltr A/C! B9d2fd24
edweed
PostSubject: pushrod leaks!!   Need PushRod Seals Replacing 2Ltr A/C! EmptyThu Jun 02, 2011 3:26 pm
howdy Baja69!
im in WSM.
the pushrods on the nearside look fine - they are dry with no leakage - however it seems all four on the offside are letting vast amounts of oil out, which apart from making a mess on my drive also splatters on my tailgate.
any idea of cost to have it done, as money is well tight after having new carbs put on!!! Wink
cheers matey!
edweed
PostSubject: Re: Need PushRod Seals Replacing 2Ltr A/C!   Need PushRod Seals Replacing 2Ltr A/C! EmptyThu Jun 02, 2011 3:54 pm
£20 + parts for 1 side
£30 + parts for both
you can provide your own or i can supply the parts
if you are in wsm and have a 2.0 A/C with new carbs, then you need to join and post some pics of your ride
PostSubject: Re: Need PushRod Seals Replacing 2Ltr A/C!   Need PushRod Seals Replacing 2Ltr A/C! EmptyThu Jun 02, 2011 4:49 pm
Good call Amigo!!
Need PushRod Seals Replacing 2Ltr A/C! Pbucket
PostSubject: Re: Need PushRod Seals Replacing 2Ltr A/C!   Need PushRod Seals Replacing 2Ltr A/C! EmptyThu Jun 02, 2011 7:12 pm
hell! I might take you up on this at this price!!! Very Happy geek
edweed
PostSubject: push rods leaking...   Need PushRod Seals Replacing 2Ltr A/C! EmptyFri Jun 03, 2011 7:48 am
morning gents,
ok...how do i go about joining and getting some pics of my twin del' powered T25 on the site???
edweed.
PostSubject: Re: Need PushRod Seals Replacing 2Ltr A/C!   Need PushRod Seals Replacing 2Ltr A/C! EmptyFri Jun 03, 2011 11:56 am
click on the register bit and enter your details
its in the top middle of the home screen
PostSubject: Re: Need PushRod Seals Replacing 2Ltr A/C!   Need PushRod Seals Replacing 2Ltr A/C! EmptySat Jun 04, 2011 8:27 pm
Ed
You're up and running now Dude, sorrybfor the delay, got back from a trip away this afternoon......
» TBOFS-Dallas Stars/Minnesota North Stars/Cleveland Barons/California Seals/Golden Seals
» Seals around the little Orme
» Honda Foreman Front Diff
» Mutiny Kites....replacing the depower rope!
» We sell bearings and seals now!
 :: Non Members-
