 The Nomates engine build thread!
The Nomates engine build thread! Empty
PostSubject: The Nomates engine build thread!   The Nomates engine build thread! EmptySat Mar 12, 2011 10:03 pm
I'll Try and get 9 pages, and the only thing done so far is cleaned the case!
When i picked it up from Steve
The Nomates engine build thread! Ae7aa33d
Bit manky but fairly tidy
The Nomates engine build thread! 36f85417
After the first wash in the tank. high pressure chemical sprayed at 85 degrees!
The Nomates engine build thread! F4839910
After being vapour blasted, back to the tank again for a rinse, that vapour blasting fucking hurts your arms!
The Nomates engine build thread! 99f6a370
Finally back in the van for delivery to the chubby birthday boy!
And yes, I know i missed a bit!
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptySat Mar 12, 2011 10:09 pm
lol ....this thread could take a while ....cheers dude
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptySun Mar 13, 2011 8:27 am
Hmm, when you ready to do another Al???
The Nomates engine build thread! Pbucket
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptySun Mar 13, 2011 8:40 am
Nice however I am confused!!
Whos is building the engine? Al pics but title nomates??
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptySun Mar 13, 2011 9:47 am
al should be club engine builder
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptySun Mar 13, 2011 4:55 pm
Steve building, I am asissting!
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptyTue Dec 20, 2011 3:37 pm
Right ,some progress has now been made , all the studs have been removed from the case ,and replaced with helicoils ,this will make removing the fan for instance a 2 minuet job rather than a few hours (well with twin carbs it will ,which is what i'm gonna be running) ....the oil galleries have all been drilled and tapped ntp and plugged off ,so a good cleaning of the oil ways can now begin , and the crank ,clutch ,flywheel and bottom pulley have been sent off for balancing ,and the rods weighed end to end .....
One major draw back with the crank is that the face where the flywheel bolts to unfortunately runs out by 2-3 thou .....this means all 8 dowels will need removing the face machiened true again and new dowels fitted ......about 4hrs work ,which is about £200 extra OUCH ....but if its gonna get built ,it gonna be done well .....I can't buy a new crank as the bearings have been bought for this one and they were over £200 so I'm going to stick with what I have ,to be honest I'm so glad they spotted it as it shows they are doing a great job !!
because of this it won't be ready for a christmas build Sad gutted
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptyTue Dec 20, 2011 5:28 pm
P.S ......the rear towbar components have been shot blasted ,and powder coated gloss black ,and the front and rear bumpers are now in a high gloss finish ,looks loads better Smile
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptyTue Dec 20, 2011 6:00 pm
PICS!! you mofo!!
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptyTue Dec 20, 2011 6:15 pm
when i got time dude ......sometime in jan .....lol
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptyMon Jan 23, 2012 9:13 pm
crank finally came back from balancing ....rods weighed end to end ....and new small end bushes fitted and honed ....
tonight I fitted the no 3 bearing ,cam timing gear...race spacer ,distributor drive and the cir clip
...first I heated them up in oil ,then fitted them ......so it has BEGUN .....LOL
The Nomates engine build thread! IMG_1980
The Nomates engine build thread! IMG_1981
The Nomates engine build thread! IMG_1982
The Nomates engine build thread! IMG_1983
The Nomates engine build thread! IMG_1984
at first I was worried that the bid end bearing on no3 ....didn't fit properly ....as the hole to allow the oil to go through wasn't in line .....I phoned big al ,and he didn't know either ......however I think I work it out by myself .....as the oil ways in the crank are drilled at an angle ,the hole is better off being slightly out ....if that makes sense
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptyMon Jan 23, 2012 9:41 pm
looking good, can wait to see this in the frid
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptyMon Jan 23, 2012 9:59 pm
Don't think 'her indoors' would like me doing that in the kitchen.
Although I did the crank/bearing and gears job in the kitchen to a flat I had in the 1980's, up in Manchester. We weren't together then.
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptyMon Jan 23, 2012 10:22 pm
did you add some paprika to the oil first?
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptyMon Jan 23, 2012 10:29 pm
it was garlic olive oil ....lol
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptyMon Jan 23, 2012 10:30 pm
i've got a lambretta in the lounge dude ......after that .....anythings good to go ...lol
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptyMon Jan 23, 2012 10:32 pm
I'm gonna rip it to bits dude ......lol ,can't wait either
PostSubject: Re: The Nomates engine build thread!   The Nomates engine build thread! EmptySat Jan 28, 2012 3:44 pm
well you did say that if it didn't sell you were gonna stick a big motor up it's arse!!
looking forward to it Very Happy
» Custom Chassis Build Thread
» Briggs & Stratton Opposed Twin Engine Questions
» WOT4 XL Build
» Can you Guess what it is yet?
» GLOBALRC
