 Tango Van - 1972 westy..
Go to page : Previous  1, 2, 3, 4, 5 ... 10 ... 17  Next
Tango Van - 1972 westy.. - Page 4 Empty
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptyMon Jun 22, 2009 9:11 pm
had some "electrical issues' so not quite done... so close..
all plumbed in and running though..
nearly done!
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptyTue Jun 23, 2009 5:55 pm
hi rich got that engine running? looking good in the pics, carbs look good, looking forward to hearing them suckin some air
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptyWed Jun 24, 2009 9:14 pm
hey mate.. they sound loverly! (when you block out the exhaust!)
SCAT SHIFTER = no gears... all of a sudden..?!
weird, can't get any gears at the mo. popped original sloppy shifter back on for a bit till I have so patience!
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptyWed Jun 24, 2009 9:15 pm
Got the Van back tonight.
shifter sh*t
but not a single drop of oil under that engine!!!!!!
at last!!
just got to run it in now and then get a tune up. afro
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptyWed Jun 24, 2009 9:18 pm
I had a SCAT in my Bay and it sucked.........
Tango Van - 1972 westy.. - Page 4 Pbucket
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptyWed Jun 24, 2009 9:21 pm
PICS Wink
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptyWed Jun 24, 2009 9:34 pm
Not sure I have got any pics of the inside of my Bus.......
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptyWed Jun 24, 2009 9:41 pm
lol i meant tango pics, hes a bit lame with pics so me and steve will have to get gunge to punish him Wink
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptyWed Jun 24, 2009 9:54 pm
so ... was so pissed with the shifter I ended up just bolting it down in 1st and driving it back into the garage... No No No
will get some pics up tomoz nite after a play about.
gear shift pics... isn't that some form of vw porn? lol! lol!
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptyWed Jun 24, 2009 9:55 pm
Ask gunge Wink
tango_van wrote:
so ... gear shift pics... isn't that some form of vw porn? lol! lol!
Exactly!!! geek
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptyWed Jun 24, 2009 10:00 pm
Will it next be....
so let's have a pic of your muffler... Suspect Suspect Suspect
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptyWed Jun 24, 2009 10:01 pm
*Snigger Snigger*
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptyThu Jun 25, 2009 8:50 pm
no shifter piccies yet... was out side van more than in it tonight
(pushing or staring at exhaust backfire igniting.......)
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptyTue Jun 30, 2009 10:32 pm
Van all sorted at last... i hope!
first problem, was the distributer cap not on right, and timing out/mixture etc.
booked into Interpro at Thornbury to get rolling roaded on Friday.
2nd problem: battery got drained in under 6hrs when engine off (and no lights left on before you ask!)
2 batteries later and all the wiring checked etc..
Turns out to be a wire plugged into the regulator that shouldn't of been, causing a permanent drain on the batt. This screwed up the charge circuit big time!
So now happy and back on the road!
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptyWed Jul 01, 2009 11:05 am
you forgot about the seatbelt that you put in !!!!!!!
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptyThu Jul 02, 2009 10:09 pm
Dropped off van at Interpro after work tonight.
They seem sound and know there stuff.
Will await the results tomoz and prepare myself for the blow to the wallet!
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptySat Jul 04, 2009 4:28 pm
how did they dyno go mate Very Happy
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptySat Jul 04, 2009 4:43 pm
what he said ^^^^ pics and figures Very Happy ......and prices for that matter
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptySat Jul 04, 2009 4:53 pm
No Pics........=......Didn't happen.
Nuff said.
Razz
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptySat Jul 04, 2009 6:56 pm
Serious bad luck really............
never got as far as the dyno. Crying or Very sad
bloody pain in the arse empi carb (number 4 cylinder)- mixture screw fits inside a brass thread thingy into the side of the carb is turning on it's self.
This means no adjustment at all to the air/fuel mixture.
There is a tab missing that holds it in place/not been drilled correctly. Evil or Very Mad
so, VW Heritage/SSP are collecting the faulty carb on Monday, and should have new replacement sent back by Wednesday.
This faulty carb was running very lean, and was over heating number 4; as a result the valves had closed up loads and compression was down to 50psi.
David at Interpro has checked out head etc and adjusted valves and now it is back up to 140psi. All others are at 150psi at the mo.
Lucky I got it there really and hadn't really driven her much. (or pushed the revs etc)
So it will hopefully be sorted and on the dyno/rolling road sometime at the end of the week.
sorry no pics, was at work all Friday, but Interpro took some of the carb fault. will see if I can get them this week.
So that's the 3 problems with the van sorted: engine leek, battery dead and now carb crap! lol! lol! lol!
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptySat Jul 04, 2009 7:40 pm
thts a bit of a bummer, wht carbs u running then i forgot ,
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptySat Jul 04, 2009 7:59 pm
He said Empi, is that the HPMX dude???
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptySat Jul 04, 2009 8:15 pm
Yep.
EMPI HPMX twin 40's
under guarantee though. (apart from the manifolds which I had to drill for brake servo...)
we shall see what happens next week.
kinda wished I had bought the webbers, but funds don't stretch that far..
PostSubject: Re: Tango Van - 1972 westy..   Tango Van - 1972 westy.. - Page 4 EmptySat Jul 04, 2009 9:01 pm
hmmmmmm
EMPI but some reason i still want them lol, so has it caused any perminant damage to the engine, and did this just happen while you were driving the bus or has it been like that all along without you knowing with regard to the misxture screw,
Page 4 of 17Go to page : Previous  1, 2, 3, 4, 5 ... 10 ... 17  Next
» 1972 Ruger .44 mag deer rifle (Deer Stalker Edition) ****Sold****
» Debbie Heald - HS Mile Record 1972 Video
» Manager Alan Brown - November 1972 (no money has been available to buy players.)
» 25 years ago - Scotsman wins the Wangaratta Gift!
» Muscle car commercials!!
