 Matt's '82 T25 Devon
5 posters
Matt's '82 T25 Devon Empty
PostSubject: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptySat Jun 06, 2015 3:55 pm
So this one time, I went and bought a t25, it turned up on a Facebook group, having been painted then stored for two years. It's not the best but it's a solid base to work from.
It failed it's first mot on binding brakes, a bulb out and a wiper arm missing the previous (mechanic) owner was gutted. It then stayed at the old dub shop for a few odd jobs that I couldn't be arsed to do, a top end overhaul and new barrels/Pistons. All done in time for Volksworld.
Since then I've been building a list of stuff to do and putting it off til nearer Chimay. I'm not panicking yet, but I'm not far off.
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptySat Jun 06, 2015 3:56 pm
It had more noise to replace the 1.5 working speakers
Matt's '82 T25 Devon E827131A-8BD5-4563-8074-5F6FD1F3B18D
Matt's '82 T25 Devon 851E0435-FCAF-4583-975C-E87C954B6405
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptySat Jun 06, 2015 3:58 pm
Then it went to Devon and Cornwall for a break.
Matt's '82 T25 Devon D5FF14BA-DACC-435D-83ED-3DA563DF8134
Matt's '82 T25 Devon 0E78639A-991B-47A9-BBE6-B764452E47CC
Became a waiting room on the way home after two dozy holiday makers tried to fit more than one car in the same bit of road
Matt's '82 T25 Devon FDB0AB5F-E567-412C-8277-A730AEED52B9
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptySat Jun 06, 2015 4:00 pm
I then went on a spending spree. £5.50 for a pair of new seats
Matt's '82 T25 Devon 55E6B922-45E2-42E4-BB8D-BCF112705F7C
Uncle gonzo painted a good sliding door which is ready to fit one night this week
Matt's '82 T25 Devon 309F6B29-6BCE-47AC-8FD9-A8C188C002B9
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptySat Jun 06, 2015 4:01 pm
Treated the cab doors to new felts cos the old ones looked terrible
Matt's '82 T25 Devon B8E8ACC4-D587-46A1-A36E-F2FFC6171587
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptySat Jun 06, 2015 4:03 pm
Then started on the lesiure battery install. I found a new friend...
Matt's '82 T25 Devon A8DE60A6-FFCE-4D3E-A51B-B221A2203093
Matt's '82 T25 Devon 74CC3475-A65F-46BB-9A3F-A1B8E0B82162
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptySat Jun 06, 2015 6:06 pm
Looking good buddy!
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptySat Jun 06, 2015 6:37 pm
Sweet. We like pics.
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptySat Jun 06, 2015 8:46 pm
I felt a little guilty moaning about a quiet forum when I had actually done stuff!
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptySat Jun 06, 2015 9:23 pm
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptySun Jun 07, 2015 8:44 pm
Today I fitted a window and my door. Spent HOURS tweaking it, got bored, ate stuff then realised I hadn't really made it any better than when I started. However, door fitted! I drove home to celebrate with a beer.
Matt's '82 T25 Devon BFC5FBB2-7397-46EE-866D-FD5CEAD263BB
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptySun Jun 07, 2015 8:47 pm
Got home, went to get something out of the van.
Realised I had hold of the door, and it wasn't quite where I expected.
Matt's '82 T25 Devon D92017F9-86DE-4D13-9408-55E81691AFAB
COCK. Managed to hold it long enough for my mate to drive over, stop laughing and re hang it. Packed up the bottom roller this time and it seems to be sorted. I did find the cause was probably the rotten plate the bottom roller rests on.
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptySun Jun 07, 2015 9:10 pm
Good old Vee Dubs eh?
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptyMon Jun 08, 2015 7:09 pm
And Lo he said, let there be split charge.
Matt's '82 T25 Devon 56F5CDDA-138E-4DFD-BF13-2894C020724B
And so there was. It wasn't very neat, and I need to attend my supplier tomorrow for some m6 crimps. However, it's in, I'm happy and I've used two spare slots in the fuse board to install a pair of relays to switch the radio and 12v socket feed in the back between start and auxiliary batteries using a switched live.
Matt's '82 T25 Devon 7AE388D9-2079-44A4-AB37-185BF2E4E837
I have also started workin through the crappy wiring behind the fridge. Hopefully I'll end up with the water pump and interior lights running off the lesiure battery over the next few evenings too.
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptyMon Jun 08, 2015 7:27 pm
Good effort
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptyMon Jun 08, 2015 7:41 pm
switched live..
is that so when it's running your on the main batt, and then when your parked up it's on the leisure...?
got a diagram.. relay spec?
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptyMon Jun 08, 2015 8:50 pm
Yup, I used a 5 pin relay from halfords. The configuration is luckily standardised thanks to the Germans.
Pin 85 - switched live - (coil +ve)
Pin 86 - to ground - (coil -ve)
Pin 30 - to radio +ve - (output)
Pin 87 - to start battery - (normally open contact)
Pin 87a - to leisure battery - (normally closed contact)
I'm also thinking about putting a timer relay in instead so I have less load when cranking.
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptySun Jun 14, 2015 10:20 pm
Today has mostly been a slog to get all the wiring sorted, it's a lot of work for little apparent gain. First, I made an earth stud behind the fridge, then went about wiring up some E.A.O switches to work my water pump and to switch the 12V socket I use for my fridge. Eventually I want to swap the ugly black switch for a push in latching type, with a light to show when it's energised. The beauty of the EAO blocks is that the modular nature means I already have the bits wired in, I just have to clip them onto the new switch. I am also considering filling the old switch hole, and letting my new switches into the original fascia. Once I've done that there's a company near work who reckon they can wrap the units as a temporary way of tidying the interior before I get round to remaking the units.
Matt's '82 T25 Devon 000B2FE0-D377-4D9B-BE64-C10E298D2303
I also spent fucking hours trying to hunt down the interior lighting wiring looms, since no one on the Facebook T25 clubs could point me in the right direction. eventually new wiring was run in, and a pair of LED light bars from Ikea fitted (they are the kind of thing that you fit into cupboards, but they should do)
Matt's '82 T25 Devon 20B812FA-2259-40BE-9277-E2918096E70C
I also tried to tart up the outside of the van, and picked a few easy wins. The mirrors were taken off, stripped, cleaned, and tightened before refitting with stainless bolts (cheers for the tip off Griff). The old gas fridge cover got bolted back on, I'll hit it with the duraglit next time I was the van. The old chrome inserts on the window rubbers were picked out in satin black, and the rubbers will get a coat of back to black in the morning.
Matt's '82 T25 Devon B242EC4E-7838-4EB3-8915-58D1AAFAEE9D
Next on the list is some door cards for the tailgate and sliding door, maybe a quick coat of black on the door handles.
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptySun Jun 14, 2015 10:27 pm
Nice one buddy Wink
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptySun Jul 05, 2015 10:31 pm
good work dude !
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptyFri Jul 10, 2015 6:57 pm
you should post a pic of your sliding door falling off ……lol
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptyFri Jul 10, 2015 9:16 pm
Lol bloody woman.
PostSubject: Re: Matt's '82 T25 Devon   Matt's '82 T25 Devon EmptyFri Jul 10, 2015 10:23 pm
She looked properly worried when she came in and said 'Matt, can you help me a minute'!
I thought she'd got Bailand Dave a birthday cake!
» Matts comedy resto thread.
» The new addition (T25 devon camper)
