 71 Early Bay (formerly known as Superdry)
Go to page : Previous  1 ... 13 ... 23, 24, 25  Next
71 Early Bay (formerly known as Superdry) - Page 24 Empty
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptyThu Oct 05, 2017 8:37 pm
How's it going Scoops?
Engine back in YET????
So close and we can't wait forever, need to disown your family and spend all your waking hours in the garage. (No sleeping then)
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptyThu Oct 05, 2017 8:58 pm
Ha ha! I've finished for the weekend.
The tinware was finished after I had to get a second lot powder coated after the rear tine was shagged by someone who thought they could weld it.
The final bits for the fuel pump loom arrived today so I'm up in the morning, getting her out on the drive and up on stands/ramps.
Finish mounting the pump and filter. Then run the new fuel lines, and wire it up.
Then it's engine in, new throttle cable to go in too and finally the exhaust on.
Looking forward to hearing it purr with the VS fitted.
71 Early Bay (formerly known as Superdry) - Page 24 Pbucket
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptyThu Oct 05, 2017 9:02 pm
Nearly there then, get the beer ready for a good celebration. Very Happy
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptyThu Oct 05, 2017 9:06 pm
Oh Yes mate. Can't wait to start running it in.
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptyFri Oct 06, 2017 8:48 pm
Had a few distractions today but made some progress.
Fuel pump is fitted and plumbed in. The wiring is all now in place too, I just need to decide where to fit the priming switch.
Ran out of daylight today so just have to sort the priming button and then I think I'm ready to get the motor in.
I do have a slight issue with the carb linkage fouling the tinware but I think it can be 'persuaded' to clear it.
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptySat Oct 07, 2017 8:40 pm
Scoops this has to be the longest thread ever, that still has no result. lol!
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptySat Oct 07, 2017 8:42 pm
HA ha! I know. But it'd be boring if it was all done in one go, or one year! :LOL!:
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptySat Oct 07, 2017 8:43 pm
Sounds like an engineer build all talk no action!!!!!!!!
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptySat Oct 07, 2017 8:52 pm
I was off all day today with Weston AFC, Will is playing in the morning, but I'm back on it tomorrow afternoon.
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptySun Oct 08, 2017 4:38 pm
71 Early Bay (formerly known as Superdry) - Page 24 ABB31154_1_EA3_4_F84_8_F35_21_B1_E7_F57_AC4
71 Early Bay (formerly known as Superdry) - Page 24 93_FD84_AB_18_C1_43_F9_8_B17_E7_DFF6_BB7088
71 Early Bay (formerly known as Superdry) - Page 24 4_F813_B75_D823_49_F3_995_B_556_DDD36_EACF
Fuel pump is mounted, relay and electrics sorted and in place.
Priming button mounted.
Heater tubes fitted, although I think I need to reword/remount my hot start relay.
Got the new throttle cable fitted too.
Just needs the engine putting in place now, 2 man job as it’s on a stand and I can’t lift the fecker off on my own. All in hand though go, hopefully this week!!!!
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptySun Oct 08, 2017 9:25 pm
Sweet, nice work sir.
That engine bay is bloody clean (mind you, you've had a bit of time to clean it)
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptySun Oct 08, 2017 9:27 pm
Oddly, it is filthy in there, the pics make it look clean and the firewall is freshly powder coated.
It's full of sand and dust at the moment.
I'll give it a clean up and a coat of wax to spruce it up before the engine goes in.
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptySun Oct 08, 2017 9:33 pm
Looking good dude! afro
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptyThu Oct 12, 2017 9:13 pm
Last little bit of wiring to sort behind the dash tomorrow afternoon and then I need a hand to lift the fecker off the engine stand and in.
Then it's connect the coil and alternator to the fuel pump, remembering to fit the temperature fuse to the coil wire.
Then it's time to fit the last 2 bits of tinware. Tweak the fan housing again to clear the bloody carb linkage.
Serpentine belt on, mount the oil filter, cut and install the new oil lines and install the oil pressure sender.
Wire the sender and the temp sender and it's time to fire her up again!
I'm thinking about fitting two 'skid plates', mounting them either side between the engine support bar and the chassis.
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptyThu Oct 12, 2017 9:58 pm
Almost there dude! If you're working on it tomorrow afternoon and want a hand getting the engine in, I might be able to spare half an hour after work before I take Jack swimming. Depends how the job goes tomorrow, I'll let you know
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptyFri Oct 13, 2017 8:22 pm
Got these puppies wired up and working today.
71 Early Bay (formerly known as Superdry) - Page 24 79141_A2_E_D42_F_4_CEC_B6_E7_B0_EF4_E1266_D2
Just need to check this works and wire it up and the dash/front end electrics will be sorted.
71 Early Bay (formerly known as Superdry) - Page 24 540_CD6_AD_ED53_4578_8_EA8_872_E11_DE7406
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptyFri Oct 13, 2017 10:10 pm
Sorry mate, I didn't see this until this evening Dude, but good to see you this afternoon anyway.
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptyTue Oct 17, 2017 7:39 pm
D'oh! Schoolboy error!
No clutch bolts......... F*$& and C%@ts!!!
Going to get new engine bolts, for the gearbox and the engine bar and some extra fuel line.
Last things are the exhaust fitting kit and a spare serpentine belt
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptySun Oct 22, 2017 9:44 pm
So although I meant to get out there this morning Mrs C has arranged a double glazing bloke to come and talk to use as we want replace our scabby front door
I didn't get out there until 2pm, but the got the clutch sorted, the front tinware bolted up and then with a bit of a struggle I got the engine in the engine bay.
I need a hand to get the heater pipes lined up as well as the engine/gearbox.
Stefan is popping round Tuesday after work so that should be sorted then.
Just need to sort the fuel hose from the fuel pump to the carb, the throttle cable and the electrics.
Then it's on with the oil filler, the exhaust and the rear engine bar.
New oil pipes to be cut to length once I sort the route and whether or not the oil lines need protecting with exhaust wrap from the heat of the exhaust.
Hopefully I'll knock a hole in the jobs Tuesday night and then finish them off Friday afternoon and get it back down on its wheels.
This is where it currently sits.....
71 Early Bay (formerly known as Superdry) - Page 24 22687910
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptySun Oct 22, 2017 10:42 pm
Looking good dude.
Before you go any further, I would recommend using 8mm internal diameter fuel hose to the carbs.
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptySun Oct 22, 2017 11:01 pm
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptyTue Oct 24, 2017 7:07 pm
71 Early Bay (formerly known as Superdry) - Page 24 C23_A723_D_A522_4107_984_A_D15767404_FB0
Final stretch now.
New fuel line to run from the pump, worry gauge wiring to sort, ht leads to fit and route, carb linkage to adjust, oil filler to fit, breather to fit, oil filter to mount and new oil lines to cut and route.
Just going to keep chipping away to get it done.
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptyTue Oct 24, 2017 8:28 pm
Gungemyster wrote:
Looking good dude.
i took the 5mm back and swapped it out for 8mm today Dude
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptyWed Oct 25, 2017 9:36 pm
Just ordered some heat shield and also some exhaust wrap to stop the oil lines getting too warm as they are going to have to be run pretty close to the exhaust / heat exchanger on the nearside.
Also had to source a new oil filler as the stock filler doesn't quite line up with the hole in the aftermarket tinware.
I know I could do it all quicker if I threw it together but want to get it done properly
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 24 EmptySat Oct 28, 2017 7:48 pm
Exhaust wrap, aftermarket oil filler and left hand carb conversion kit arrived today.
Will's got a match in the morning but roll on tomorrow afternoon and I can get it all fitted up.
I'm going to try and start the exhaust wrap curing with a heat gun.
Page 24 of 25Go to page : Previous  1 ... 13 ... 23, 24, 25  Next
» Emery Early Bird Classic
» Silverthorn/Nike Early Bird
» 2011 Early Bird Classic at Father Henry Carr
