 71 Early Bay (formerly known as Superdry)
Go to page : Previous  1 ... 11 ... 18, 19, 20 ... 25  Next
71 Early Bay (formerly known as Superdry) - Page 19 Empty
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptyThu Feb 19, 2015 6:36 pm
Like a proper spin on fram jobbie
So is the tea strainer that bad at doing its job then
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptyThu Feb 19, 2015 8:35 pm
71 Early Bay (formerly known as Superdry) - Page 19 F2792E69-E959-4CC3-990F-C2D7582857A1_zpspyyk6ami
swap the elbow from a 90 degree to 45 and have it coming out of the case at 10 o'clock position so it's above the bar??
71 Early Bay (formerly known as Superdry) - Page 19 B9d2fd24
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptyThu Feb 19, 2015 9:06 pm
They're not brilliant. A little extra cooling from the oil lines and the improved filtration of a Fram is all going to help with the longevity of the engine.
That's not a bad shout Stef, I'll have a look, these were just bits I had lying around.
71 Early Bay (formerly known as Superdry) - Page 19 Pbucket
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptyFri Feb 20, 2015 10:06 am
Are you using the Orange HP1 fram filter ? I use that on my engine and it increases the oil quantity by a decent amount ! with the lines and the filter I think it was another litre or so ?
When you fit the filter for the final fit make sure you fill it up with fresh oil prior to install.
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptySat Feb 21, 2015 9:48 am
I might be being dense - all the kits have a take off pipe from the oil pump housing, where does the other pipe go?
(Since my engine is in bits I have the chance to sort one for the van)
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptySat Feb 21, 2015 9:56 am
The case is tapped in the oil gallery's for the return
Looking at the oil gallery follow the gallery to the left ! Scoops has your case been tapped for full flow ?
Also you need to put a bung inside the before the oil pump goes in as you want all the oil to go out the pump cover plate through the filter then back into the case
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptySat Feb 21, 2015 5:53 pm
I'm going to run a CSP conversion that replaces the oil pressure relief valve for the return and the oil comes out from the pump, no need for tapping and drilling.
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptySat Feb 21, 2015 7:18 pm
Ah yes I have seen those Wink
I run a maxi 3 pump on mine
It has in and out on coming off the pump cover Wink
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptySat Feb 21, 2015 8:36 pm
I have got a Maxi Pump cover but the engine support bar would the lines.
May be able to do something if I use rubber lines, but want to use the braided lines if poss.
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptySat Feb 28, 2015 4:46 pm
Had a little bit of time this afternoon so I decided I needed to get a bit done on the engine.
I whipped out the 5 exhaust studs that were in the heads and fitted all new 8 new ones, with a smear of good old copper slip on each stud.
This reminds me, I need to source the slim line exhaust nuts that have the allen key pattern in the end.
Next was to start dry fitting up the tinware to make sure it all goes together ok prior to getting it coated.
71 Early Bay (formerly known as Superdry) - Page 19 A30845A3-A68A-4602-BF3A-6EC1957AC64C_zpsea8i7vsn
I know it all looks a bit manky but I'm going to clean the case etc when the tinware is being done.
Popped the oil cooler in place and nipped up one nut to hold it in place.
71 Early Bay (formerly known as Superdry) - Page 19 6BA03043-0B23-4E5C-B134-E6A507B27C75_zpsbh8tiyln
Then put the fan housing in place. Doing this made me realise one side requires the bottom front edge to be straightened out.
71 Early Bay (formerly known as Superdry) - Page 19 55234392-2411-4CCD-BE48-1A72596135A3_zps5ohznaqm
I started looking at the areas that require a mild 'fettling' to get it to all fit together properly.
71 Early Bay (formerly known as Superdry) - Page 19 61039E2C-0AE7-444C-BB02-ADE6AEAD3C3C_zpsrqxthocc
71 Early Bay (formerly known as Superdry) - Page 19 06FD2674-A0D0-486F-AFD6-015FE32B003F_zpslcnwws1n
71 Early Bay (formerly known as Superdry) - Page 19 5D675298-5618-46F6-987A-5EF35815F2C8_zpsywb5ow1r
This is where we are at the moment
71 Early Bay (formerly known as Superdry) - Page 19 287A0370-7195-4C9F-9063-63F8AF954BE3_zpscst86oqe
I've been offered a full set of tinware that's already been powder coated but I'm waiting to find out if it's a brand new set up that's been done, if it's og or if it's had it's fettling and fits straight on.
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptyFri Mar 06, 2015 8:28 pm
Had a bit more a furkle with the tinware this afternoon.
The tinware on the side of 3 & 4 is all sorted now.
Just need to sort out blanking the holes in the rear tinware where the heat risers would have been and then get the other side done.
Didn't take any pics today, but will do if I get on it on Sunday afternoon.
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptySat Mar 07, 2015 1:19 pm
Text me the size and a pic of the holes and I'll seenif we have any plastic caps at work?
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptyWed Apr 01, 2015 8:32 pm
The tinware is more or less there I think, ready for stripping back down and then going for powder coating.
71 Early Bay (formerly known as Superdry) - Page 19 59124646-7620-404C-80F6-E6AE742464B2_zpsckdqzqu0
Engine needs a clean then, then the rockers to fit, the carbs to rebuild and fit and then get the ancillaries back on there.
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptyWed Apr 01, 2015 8:50 pm
have you covered the heat riser holes yet?
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptyWed Apr 01, 2015 9:13 pm
Used a new piece of tinware.
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptyThu Apr 02, 2015 3:52 pm
liking the tidy and clean up
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptyThu Apr 02, 2015 4:14 pm
Cheers Dude
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptyThu Apr 02, 2015 8:10 pm
Chop chop, if you're going to have it ready for Wednesday!
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptyThu Apr 02, 2015 8:19 pm
Won't be there for Wednesday.
Em and the kids might be coming so might bring her Beetle.
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptyFri Apr 03, 2015 8:45 pm
Went at the tinware with the dremel again this morning until I was happier with the fit.
Then stripped it all back off the engine and now have it boxed up and ready to drop over to Nailsea next week for powder coating.
71 Early Bay (formerly known as Superdry) - Page 19 AAC9E0D6-76D0-4249-A898-A66D0D5A4EF8_zpskqyfud1z
Going to wander over to Oldmixon Crescent next week and get a 45 degree one of these. If I use this it will hang below the level of the support bar.
71 Early Bay (formerly known as Superdry) - Page 19 262C3F89-FB85-412F-8BF8-F8A7AE0DB10D_zpspxhdelno
I can crack on next with getting the block cleaned up....
71 Early Bay (formerly known as Superdry) - Page 19 8080A6C4-42DF-4DE6-8885-357B9EE1CF08_zpsixyf6fbl
71 Early Bay (formerly known as Superdry) - Page 19 D8599961-EFF2-4F5A-8FBB-16D60D25DCA8_zpsugqpvx9b
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptyFri Apr 03, 2015 9:22 pm
Looking good, you'll have to tart up the outside if you make the engine bay any shinier!
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptyFri Apr 03, 2015 9:28 pm
My Mrs simply doesn't understand why I want to tart the engine bay up and leave the outside as it is!
Made I larf!
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptyFri Apr 03, 2015 9:41 pm
Steps Dad always wheels out a story about how his colleague used to clean under the bonnet more than the rest of the car because you always break down in your best clothes.
I only do it so I can see where this weeks leak comes from!
PostSubject: Re: 71 Early Bay (formerly known as Superdry)   71 Early Bay (formerly known as Superdry) - Page 19 EmptySat Apr 04, 2015 7:38 am
Ready in time for Big Bang?
Page 19 of 25Go to page : Previous  1 ... 11 ... 18, 19, 20 ... 25  Next
» Emery Early Bird Classic
» Silverthorn/Nike Early Bird
» 2011 Early Bird Classic at Father Henry Carr
