| Subject: Re: 71 Early Bay (formerly known as Superdry) Mon Jan 07, 2013 12:51 pm | |
| Got a set of Tor-Q bits, along with a grease cartridge and a new hole punch for when the waistline trim goes on. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Mon Jan 07, 2013 12:53 pm | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Mon Jan 07, 2013 1:08 pm | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Mon Jan 07, 2013 8:32 pm | |
| CSP replied to me today regarding the pin at the base of the shifter not clearing the reverse plate. I can move the position of the pin by rotating the t-handle shifter. Each full rotation will move the pin position by 1.5mm | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Jan 12, 2013 9:14 am | |
| It worked. Needs a road test but I think it's nailed now. I also drilled the door and fitted the pillar spot. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Feb 09, 2013 5:45 pm | |
| Fitted the 56Deluxe steering raiser today after Mrs C picked it up from the Post Office for me. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Feb 09, 2013 8:11 pm | |
| Did they have any shorter bolts? | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Feb 09, 2013 8:13 pm | |
| I'd just mark them up and cut them shorter Job done! | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Feb 09, 2013 8:14 pm | |
| Or get Nomates to turn them down into spikes | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sat Feb 09, 2013 8:20 pm | |
| The bolts do look a bit shit, but then, Bays are shit anyway. I'm going to order up some shorter bolts, as they look neater than if I just chop them down. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Feb 10, 2013 1:34 pm | |
- The bolts do look a bit shit, but then, Bays are shit anyway.
I'm going to order up some shorter bolts, as they look neater than if I just chop them down. How? ....if you cut straight and file after they will be as good as shorter one (because they will be ...lol) | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Feb 10, 2013 3:34 pm | |
This^^^ | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Feb 10, 2013 4:07 pm | |
| You're right, but being a bit sad/nerdy I want all the bolts cock on the same length.
Unless I mark them and chop them off with a Dremel. [penny drops] | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Feb 10, 2013 4:15 pm | |
| and take some better pics of the light on the door
P.s (whats wrong with marking the bolts and using a junior hacksaw? have you get a vice? | |
| - tango_van wrote:
- Or get Nomates to turn them down into spikes
I'm all spiked out dude .......they took ages to make .....lol | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Feb 10, 2013 4:32 pm | |
| I have got a vice and hacksaw. I'll whizz them back out and redo them.
It was a pain as the heads had been polished I think and the Allen key didn't fit properly.
I'll put the light back together as I have been trying to find an led bulb for it.
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Feb 10, 2013 5:29 pm | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Feb 17, 2013 8:29 pm | |
| you could use this to hold your deluxe trim on chap.. they use it to bond solar panels to caravan roofs... a little bit of deluxe trim should be no problem!
http://www.amazon.co.uk/Sikaflex-Caravan-Adhesive-Caravans-Trailers/dp/B0036KGDH0 | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun Feb 17, 2013 8:40 pm | |
- This the bulb Im trying to find an led alternative for
looks just like a workshop inspection light bulb | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Fri Mar 01, 2013 10:49 pm | |
| Fitted some bling to the front of SuperDry today(grill trim surround) Then fitted some round the back too And set up my GoPro, ready for the get-together tomorrow afternoon | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Fri Mar 01, 2013 11:04 pm | |
| go-pro looks good is it tethered to the inside of the door? | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Fri Mar 01, 2013 11:12 pm | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Tue May 14, 2013 7:50 pm | |
| SuperDry now has a nice new MoT certificate. I also had the gearbox oil flushed and replaced. Apparently the stuff that came out was minging, and was frothy! That ain't right! It can only help with my dodgy gear shift that I've never been able to quite nail since I've had the van. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Sun May 19, 2013 9:17 am | |
| In my quest to improve the gear shift I replaced the front section of the gear shift rod and the front bush. Didn't get a chance to take it out as we were out last but might drag it out this evening when Mrs Scoops comes back. | |
| Subject: Re: 71 Early Bay (formerly known as Superdry) Tue May 21, 2013 9:23 pm | |
| Tonight I have been out and tightened the wing nut by 1.5-2 turns on the clutch cable.
Took it out for a spin and it seemed fine, but think I need a run up the motorway. I was going to take it to work on Friday morning but I'm stopping in Bristol on Thursday night.
Might scoot down to Apex or somewhere at the weekend. | |
