 Shorty's '71 Early Bay
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Shorty's '71 Early Bay - Page 8 Empty
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyFri Apr 13, 2012 5:33 pm
I try not to let any of my bus out in the rain! lol!
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyTue Apr 17, 2012 8:36 pm
I've started on the interior tonight.. first job = remove the old one!
As it started:
Shorty's '71 Early Bay - Page 8 DSC02192
Shorty's '71 Early Bay - Page 8 DSC02195
Shorty's '71 Early Bay - Page 8 DSC02196
Shorty's '71 Early Bay - Page 8 DSC02198
Sink / Cooler unit & Passenger seat removed
Shorty's '71 Early Bay - Page 8 DSC02199
Buddy Seat Removed
Shorty's '71 Early Bay - Page 8 DSC02200
Table removed
Shorty's '71 Early Bay - Page 8 DSC02201
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyTue Apr 17, 2012 8:44 pm
And here's some new stuff to put into the bus when I put it all back together...
There's 15 items here (A pair, or a bag of 'things' count as 1 item).. How many can you guess correctly?
Shorty's '71 Early Bay - Page 8 DSC02194
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyTue Apr 17, 2012 8:53 pm
1. Headlamps
2. Front side reflectors
3. Rear side reflectors
4. Bumper step rubbers
5. No drill spot lamp brackets
6. Shiny spot lamp
7. Electronic ignition
8. Clear front indicators
9. Orange indicator bulbs
10. Door seals
11. Spot lamp cover
12. Front indicator seals
13.
14.
15.
I cant work out the White thing (top right) and the 2 bags of fasteners (shiny things) above the door seals.
Shorty's '71 Early Bay - Page 8 Pbucket
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyTue Apr 17, 2012 9:38 pm
Isn't the white thing top right just a piece of card that holds bulbs? Cant really see on my phone.
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyTue Apr 17, 2012 10:33 pm
1.Shiny Spot lamp
2. Spot lamp brackets (Pair)
3. front bumper step rubbers (Pair)
4. Headlamps lense(Pair) sealed H4 Hella..late type so have you got tabs in the headlamp bowls?:LOL!: and are you using the existing headlamp rims.. as only will need later type with 1 screw hole fixing..
5.Clear front indicator lenses (Pair)
6.new indicator seals (Pair)
7. orange indicator bulbs (pair)
8.side light bulbs
9. stainless indicator lense bolt kit
10. electronic iginition
11.front door rubbers (pair from VoWo)
12.Front side reflectors US spec Orange (Pair)
13.Rear side reflectors US spec Red (Pair)
14. packet of stainless nuts, washers, bolts 10mm ... not sure what for.. front brackets? or reflectors..
15. spot lamp in cover...
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyTue Apr 17, 2012 10:36 pm
So,
what's the plan for the interior then? complete removal or just partial?
how much are you going to change it?
make sure that you seal up that hole in the floor from the sink waste pipe...
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyWed Apr 18, 2012 6:10 am
1.Shiny Spot lamp - yes
2. Spot lamp brackets (Pair) - yes
3. front bumper step rubbers (Pair) - yes
4. Headlamps lense(Pair) sealed H4 Hella..late type so have you got tabs in the headlamp bowls?:LOL!: and are you using the existing headlamp rims.. as only will need later type with 1 screw hole fixing.. - yes
5.Clear front indicator lenses (Pair) - yes
6.new indicator seals (Pair) - yes
7. orange indicator bulbs (pair) - yes
8.side light bulbs - no wrong!
9. stainless indicator lense bolt kit - yes
10. electronic iginition - yes
11.front door rubbers (pair from VoWo) - no wrong!
12.Front side reflectors US spec Orange (Pair) - yes
13.Rear side reflectors US spec Red (Pair) - yes
14. packet of stainless nuts, washers, bolts 10mm ... not sure what for.. front brackets? or reflectors.. - no! Close but no cigar
15. spot lamp in cover... - not allowed! Part of the spot lamp!
You got most right (see above), although the spot lamp cover goes with the spot lamp...
As for the headlights.. I've got a repair panel on the front of my bus which has late bay headlamp bowls.. I already have the single screw rings as a result of this..
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyWed Apr 18, 2012 6:16 am
yes, but what are the bulbs for...............? no one has guessed this correctly yet! Very Happy
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyWed Apr 18, 2012 7:34 am
clear indicator lenses.
you will need the mirror effect ones otherwise you will see th bulb through.
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyWed Apr 18, 2012 8:30 am
Rubber seal is for sliding door then ...
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyWed Apr 18, 2012 9:01 am
Correct!
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyThu Apr 19, 2012 8:32 pm
I've been busy with the spanners and screwdrivers again!
Shorty's '71 Early Bay - Page 8 DSC02202
Shorty's '71 Early Bay - Page 8 DSC02203
Shorty's '71 Early Bay - Page 8 DSC02205
Shorty's '71 Early Bay - Page 8 DSC02206
Let there be light!
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyThu Apr 19, 2012 8:34 pm
And a sneak preview of the new seats!
Shorty's '71 Early Bay - Page 8 DSC02204
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyThu Apr 19, 2012 8:40 pm
were the runners the same?
Shorty's '71 Early Bay - Page 8 B9d2fd24
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyThu Apr 19, 2012 8:42 pm
For the passenger seat there's not a problem.. the drivers side needs new late bay runners.. ARSE!!!! lol!
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyThu Apr 19, 2012 10:49 pm
Careful now!!!
First it's the late front panel, then it's the seat runners..... Next you'll be adding a brake servo, high indicators and paying road tax lol!
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyThu Apr 19, 2012 10:51 pm
I just used the ones that came with my electric Porsche seats Wink
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyThu Apr 19, 2012 10:56 pm
So....
What's the plan?
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyFri Apr 20, 2012 4:32 am
I've got a brake servo - mines a '71!!!
Plan: full width RnR Bed, new buddy seat, ICE, table etc etc...
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyFri Apr 20, 2012 5:42 am
Sounds good to me!
Just what I'd do Wink
Are you going to keep the headlining and panels? I just recovered mine, but need to work out a new rear overhead replacement locker to cover the gap.
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyFri Apr 20, 2012 5:45 am
I might be able to help you out there fella... I'm going tontake some measurements off mine, create 3D models and drawings, then get the parts CNC cut...
Watch this space...
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyFri Apr 20, 2012 7:03 am
I know a company that can do that from your drawings. I'll get their number.
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyFri Apr 20, 2012 7:06 am
Don't worry, I've already got one!! But thanks all the same!
PostSubject: Re: Shorty's '71 Early Bay   Shorty's '71 Early Bay - Page 8 EmptyWed May 23, 2012 7:20 am
I'd like to take credit for the following work, but I won't! The seats were fitted by Mark and his Dad at the Howling Wolf Speedshop, and the canvas was fitted by 'faux' from the EarlyBay.com forum.
Shorty's '71 Early Bay - Page 8 718ded39
Old canvas:
Shorty's '71 Early Bay - Page 8 95044d90
New canvas:
Shorty's '71 Early Bay - Page 8 9c3cfd83
Page 8 of 9Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
» Emery Early Bird Classic
» Silverthorn/Nike Early Bird
» 2011 Early Bird Classic at Father Henry Carr
