| Hello | |
| Subject: Hello Thu Oct 07, 2010 2:21 pm | |
| to simon ....and griff , just to let you know i'll be in the other section if you need me ..lol | |
| Subject: Re: Hello Thu Oct 07, 2010 2:33 pm | |
| Guffaw!! | |
| Subject: Re: Hello Thu Oct 07, 2010 3:20 pm | |
| Subject: Re: Hello Thu Oct 07, 2010 3:37 pm | |
- to simon ....and griff , just to let you know i'll be in the public toilets waiting for some action ..lol
Im a Mod of this area now fella, so this means i can edit posts in here. | |
| Subject: Re: Hello Thu Oct 07, 2010 5:10 pm | |
| I didn't know you had a scooter ...lol
watercooled question .......my lt 28 with a 5 cylinder turbo'd deisel engine is suffering seriously from turbo lag ....can i fit one of them plug in re-mapping box thingies ,and if i do will it make a difference ....if not ,what can I do ? | |
| Subject: Re: Hello Thu Oct 07, 2010 7:59 pm | |
watercooled question .......my lt 28 with a 5 cylinder turbo'd deisel engine is suffering seriously from turbo lag ....can i fit one of them plug in re-mapping box thingies ,and if i do will it make a difference ....if not ,what can I do ? To reduce lag on the beast you could reduce the boost pipes in length, or even clean the inside of the pipes, they may be clogged up with oil. If your after more power then i would suggest removing the govener, modifing the fuelling pin in the diesel pump to allow max fuel, fit a manually controlled boost controller, fit a bigger diameter downpipe mated to a free flow exhaust system. To be honest with you i just made all that up. But im sure some of it may fix your problem?! | |
Number of posts : 1435 Age : 45 Location : Sitting in a room, in Exeter! My Ride(s) : 2005 T5 Transporter, 67 very original ozzy bug running a 1914 lump.. Registration date : 2007-05-07
| Subject: Re: Hello Fri Oct 08, 2010 3:57 am | |
- I didn't know you had a scooter ...lol
watercooled question .......my lt 28 with a 5 cylinder turbo'd deisel engine is suffering seriously from turbo lag ....can i fit one of them plug in re-mapping box thingies ,and if i do will it make a difference ....if not ,what can I do ? in a short answer to your question.... No due to the nature of it being an old crap pile, it must be scrapped! P.S on a serious note, i got a spare on of them plug in thigs if you want it 20 bucks its yours! Ive just had mine remapped from 104 to 152 bhp | |
| Subject: Re: Hello Mon Oct 11, 2010 5:05 pm | |
| just found out ,it won't work .....as mine has a machanical fuel pump ....not electronic ....bummer | |
| Subject: Re: Hello Mon Oct 11, 2010 9:04 pm | |
- just found out ,it won't work .....as mine has a machanical fuel pump ....not electronic ....bummer
Adjust to maximum fuel | |
| Subject: Re: Hello Tue Oct 12, 2010 5:47 pm | |
| wouldn't that make the tick over go up? | |
| Subject: Re: Hello Tue Oct 12, 2010 7:44 pm | |
| Didnt on my old mk1 Caddy. I lifted the gov, then turned the fuel pin in the pump 180 degrees to give it max fuel. | |
| Subject: Re: Hello Tue Oct 12, 2010 9:20 pm | |
| It'll smoke like a bastard when you boot it though!! | |
| Subject: Re: Hello Wed Oct 13, 2010 7:55 pm | |
| Nobody sits on your back bumper though! | |
| Subject: Re: Hello Wed Oct 13, 2010 7:59 pm | |
| Well, maybe only once!!! | |
| Subject: Re: Hello | |
| Hello | |
